4man0822
ORIGINAL: 04 400 4x4i I was wondering how you guys were getting the belts to ride higher on the secondarys. Is this what is refered to as shimming? It is now stock. To make it ride higher do I need to add, remove, or what. Where are these shims located and if I need to add some are they possible to make? Just trying to get lower gearing without breaking into the diffs. It is prolly the best Bang For The Buck mod you can do!!! Along with other key mods, it turns into a badazz, kickazz combo, fo sho!! Good luck & GWC is correct, it's the primary you do the shim mod to Brandon
I'm just some dumb, not plumb dumb, huh!! My new ride= 08 750 King Quad Belt snorked, VDI, M109R injector, EPI yellow spring, 18 gram weights, 2mm shim mod(Coop 45 mod) Twin Air & Yoshi=WOW! 4 a single, she hauls!! "STOLEN"--- 07 700 Camo King Yoshi Pipe, PC3, UNI filter, 27" Swamp Fox Plus, ATV Audiopipe, with the Bazookas(I love this thing)& Gorilla 2500XT W/syn rope 05 500 Foreman 26"589 M+S 0n black C-4's, HMF Utility series, with jet, & UNI filter, boot guards& kimpex b
