Sealing the airbox
Sealing the airbox
All Forums >> [OEM Discussions] >> Suzuki >> Sealing the airbox Page: [1]
Sealing the airbox - 8/18/2008 9:32:29 AM
03_VINSON
I put silicone on my airbox and had it over the seat for the 1st time saturday and it still leaked..What do yall seal yours with?
--SUZUKI VINSON--
HMF
UNI FILTER
SNORKEL
DYNO JETS
RE: Sealing the airbox - 8/18/2008 12:54:41 PM
camozuki
Just the factore o-ring works fine for me with a little dow 111.
2005 Suzuki Vinson
2007 GMC Classic CCSB 4X4 Duramax/Ally
(in reply to 03_VINSON)
RE: Sealing the airbox - 8/18/2008 1:23:34 PM
Freestyle
Yeah but I still think u should silicone it bro!!! Its just a safety precaution!!!
08 750 King Quad
3" Xtreme Lift
30X9 Silverback's
Vision Buckshot Wheels
Twin Air Filter
Full Custom Snorkle
Crankcase mod with Filter
Sealed Pull Start
Greased Shifter
Sealed display
Took spark arrester out
Warn XT 25 rope winch
"Team Scuba"
www.myspace.com/thefreemans620
(in reply to camozuki)
RE: Sealing the airbox - 8/18/2008 2:50:43 PM
MudKing02
I'd use more silicone. Your bead must not be complete if it still leaks. I siliconed mine and it dont leak a drop. Just be liberal with the silicone. Its not the kinda thing you wanna skimp on.
07 Vinson Manual 2" HL lift, Gators on Douglas Rattlesnakes, snorkel, jets, K&N, Warn RT 2500, carb slide mod
(in reply to Freestyle)
RE: Sealing the airbox - 8/18/2008 3:44:47 PM
03_VINSON
The first time I just put some on the bottom where the o-ring is and then put it back on I don't think it sealed good because my snorkel makes the lid hard to snap back on.  When I do it again I'll put some on the outside 2.  Yall have any problems getting them back off with all the silicone?
--SUZUKI VINSON--
HMF
UNI FILTER
SNORKEL
DYNO JETS
(in reply to MudKing02)
RE: Sealing the airbox - 8/18/2008 4:48:54 PM
TeamMudd
i use either dielectric grease, or synthetic "red" grease.  run a thick bead along the inside of the top lip, re-install lid (it will ooze at this point), and wipe some of the excess off..........been working great for me!!  no leaks!
Jason
Team Mudd Racing Pres.
WWW.TEAM-MUDD-RACING.COM
MINE: '07 Vinson *29.5 Laws/28 mudlites *"TEAM MUDD" snorkel (my design)*Lift kit*18% Gear reduction*reverse lights*aux head lights*Moose cargo seat*EPI clutch kit*HMF*UNI filter*Jetted
HERS: '07 Vinson *26 XTR's *"TEAM MUDD" snorkel*reverse lights*custom seat back*UNI filter
RE: Sealing the airbox - 8/18/2008 4:52:08 PM
MudKing02
No I dont have any problems with it, but I dont make it a point to take it off to much so that everything stays put.
(in reply to TeamMudd)
RE: Sealing the airbox - 8/18/2008 5:08:48 PM
03_VINSON
What about PVC cement Put some on the outside of the lid after you close it ? I'll probably just use dielectric grease on the inside and silicone on the outside but jw if anybody ever heard of using PVC cement
--SUZUKI VINSON--
HMF
UNI FILTER
SNORKEL
DYNO JETS
RE: Sealing the airbox - 8/18/2008 6:29:36 PM
camozuki
I would use something non-hardening. With silicone or others that get hard they will tend to come loose from the lid or the box. With the Dow111 or some form of grease it will flex and stay attached to the surfaces its applied to.
2005 Suzuki Vinson
RE: Sealing the airbox - 8/19/2008 10:09:49 AM
03_VINSON
10-4..... I got another question  Went ridin this weekend and somebody wanted to no what all the lines ran up my snorkel were and he said the one off the radiator needed to be down or it would cause overheating problems?  Yall have yours ran to the top of your snorks dont you?
Thanks
--SUZUKI VINSON--
HMF
UNI FILTER
SNORKEL
DYNO JETS
RE: Sealing the airbox - 8/19/2008 10:32:40 AM
MudKing02
I only have the fan vent ran up to the pod. the overflow line is still down where it was stock.
RE: Sealing the airbox - 8/19/2008 5:26:42 PM
300club
ORIGINAL: TeamMudd
Thats what I do. The other good thing is you can take it off when your riding and put it back on without having to need more silicone.
TBC BOG TEAM
Suzuki Vinson - 650 Prairie
RE: Sealing the airbox - 8/22/2008 10:06:06 AM
03_VINSON
Where is that located? The overflow is the only one I see that is not connected to anything with both ends...What side of the radiator, top or bottom? Thanks
--SUZUKI VINSON--
HMF
UNI FILTER
SNORKEL
DYNO JETS
RE: Sealing the airbox - 8/22/2008 4:11:55 PM
UnConquered*King
use marine grade silicon adhesive....this stuff is awesome and hardens to where you can sand it if needed.....but if this is going on the air filter cap...just use a tube of rtv
'06 King Quad- building stage!
Full ABS Snorkel system
3" XP lift
HL Springs
SS108's w/ 28" laws 10.5's and 12.5's
Yahtzeeeeee!!!
http://s46.photobucket.com/albums/f111/scottyg36/Mock-Up/King%20Quad-Finished/
RE: Sealing the airbox - 8/22/2008 6:03:35 PM
new06kingquadblk
ORIGINAL: TeamMudd
use axle grease also, i read that in a magazine and i'm about to do it to mine too.
May Sell or Trade-----06 KINGQUAD 700FI
2.5ci WARN WINCH
14''RIMS W/27'' ITP MUDLITE Xl's
HMF slip-on
K & N air filter
audiotube
copperhead VDI (i love it)
snorkeled belt exhaust into utility box on rear
soon to come (truck nuts so i can go balls deep in mud)
-lift springs
wife's bike
2007 kingquad 700fi
27/10 mudlite xtr's on14"ss112
twinair filter
highlifter clutch kit
hmf
dynojet controll mod.
fully snorkeled
reverse light
winch
http://s188.photobu
