sscard
loose cable on the main power system, add some d grease to the frame ground and check all battery and solenoid connections, not the bulb, it should have no power sent to it unless your hitting break (assuming this is on the bb) or the headlights are on, still should remove it but not the problem here have you gotten the pod wet lately? Im guessing no since the broken arm and all
04 Grizzly 660 camo Snokl'd,Law'd,5.5 Primate Lift'd, and Rilla'd TRIPLE Flow HMF , HL Xtreme Clutch Kit,StrobesJTM custom stereo The Wifes 02 Rancher 350 4x4 ITP SS106, 26" Terra Cross, Warn 424, K&N Snorkl'd, Jett'd, Lift'd,and Pip'd Pink Dipped Plastics JTM Custom Dipped Stereo 4-6x9's
