SNORKELIN A 04 FOREMAN 450????????
All Forums >> [OEM Discussions] >> Honda >> SNORKELIN A 04 FOREMAN 450???????? Page: [1]
SNORKELIN A 04 FOREMAN 450???????? - 8/27/2008 8:10:32 PM
STUMP KNOCKIN 450
does anyone have any pics or instructions on how to snorkel a foreman 450?
06 Yamaha Kodiak 450 Outdoorsman Edition
Custom Full Snorkles
Custom Bumper
Custom Strobes
Custom Audiopipe
2 inch HL lift
2.5ci WARN winch
Amsteel Blue
HMF pipe
DynoJet Kit
Twin Air filter
EBC severe duty brakes
28 inch EDLs
1.5 inch wheel spacers
HL outlaw clutch kit
1979 CJ5
2002 Chevy Avalanche Z71
MY PICS:
http://community.webshots.com/user/STUMPKNOCKIN450
RE: SNORKELIN A 04 FOREMAN 450???????? - 8/27/2008 8:49:02 PM
minitrk
look here...
http://hondaforeman.com/phpBB2/viewforum.php?f=24&sid=e9aa152bb832d56809c7f2bb8f7937e3
04 foreman 450 yellow
- disk brakes
- clutch kit
- Triangle atv snorkle
- jet
- uni filter
- perfex ltk
- hl springs
- 27 bi/tri claws on type 4s
- warn 3.0
- warn bumper
- plasma rope
- sealed pull start
- back up light
- hmf eco
- rear box/seat
- fener protectors
- f&r tow hooks
- pod light shut off switch
- full prm armour
- reverse button override
(in reply to STUMP KNOCKIN 450)
RE: SNORKELIN A 04 FOREMAN 450???????? - 8/31/2008 8:02:40 AM
STUMP KNOCKIN 450
it says i need to log in.
Custom Bumper
Custom Strobes
Custom Audiopipe
2 inch HL lift
2.5ci WARN winch
Amsteel Blue
HMF pipe
DynoJet Kit
Twin Air filter
28 inch EDLs
1979 CJ5
MY PICS:
(in reply to minitrk)
RE: SNORKELIN A 04 FOREMAN 450???????? - 9/1/2008 7:51:08 PM
minitrk
hmmm sorry, heres a copy... but theres no pics for some reason so it might not be of any help. it is supposed to be a copy of the triangle one, so maybe yo can look at theuir pics on the site??? but IDK as I bought mine from triangle.
This snorkel is for a Foreman 450
This snorkel was built as entirely experimental and has not yet been used...TRY AT YOUR OWN RISK!!!
I have had water enter my Foreman’s engine, even with my snorkel on!!! Be aware!!
List of stuff to buy:
2 45 deg. 2in. PVC elbows
2 90 deg. 2in. PVC elbows
3 threaded 2in couplers
1 2in to 1 1/2 PVC reducer
2 22.5 deg. 1 1/2in. PVC elbows
1 1 1/4 to 1 1/2in. PVC reducer
2in. PVC pipe at least 6ft in length
1 1/2in. PVC 3or4 ft. long
1 1/4in. PVC 3or4 ft. long
You are on your own as far as a mounting bracket goes. Mine is a flat aluminum plate 4x6, with an aluminum threaded pipe welded in the middle of it, at an angle. There are also 2 ubolts that fasten it to the racks.
Start out by taking the 90d elbow, and cut about 3inches of 2in pipe and connect the 90 and the 45. Just dry fit it, at this point. (Do not glue yet).
Next cut another 3in piece of 2in pipe and connect the other 45d. If you look at the pics, I am sure you will see what Aim talking about.
Next you will connect the 1 1/2 to 2in reducer to the 90d elbow. Now cut approx 13in. of 1 1/2in pipe and connect it to the reducer.
Next you will slide the rubber coupler on to the end of the 13in. pipe.
Next cut about 10 1/2inches of 1 1/2in pipe. Now connect one of the 22.5in elbows to one end of the 10.5in pipe. Now cut approx. 2 1/4in of 1.5 pipe and connect it to the other side of the 22.5 elbow. Now connect the other 22.5 elbow to the 2 1/4 pipe. Make sure you look at the pic to see how the bend is.
Next you will connect the 1 1/4 to 1 1/2in reducer to the 22.5 elbow. Now cut approx 5 3/4in of 1 1/4in pipe. This will give you a complete snorkel from under the fender to the air box.
Now you will need to decide how you will come through the fender and how you will secure it to your racks. You will have to trim some fender off to get it to the air box as well as some mud flap. Reference the pictures below on where the snorkel goes through the fender. As far as rejetting goes, I didn’t have to. The instructions that come with the kit this one duplicates said to move the clip on the carb needle down to the first slot. They provided another small washer just like the one that is already on the needle. And it said to put both washers under the clip
I know this sounds like a lot, but in reality it took me about 2 or 3 hours to build. Oh by the way.....all measurements that given were approximates, so double check your own measurements. It will more than likely take you awhile to get the 90 and 45's lined up just right to miss the shocks, so take your time, also the 22.5 elbows have to be just right, so pay close attention there also.
< Message edited by minitrk -- 9/1/2008 7:54:44 PM >
- disk brakes
- clutch kit
- jet
- uni filter
- perfex ltk
- hl springs
- warn 3.0
- warn bumper
- plasma rope
- sealed pull start
- back up light
- hmf eco
- rear box/seat
- fener protectors
- f&r tow hooks
- full prm armour
RE: SNORKELIN A 04 FOREMAN 450???????? - 9/2/2008 8:41:48 PM
MondexBruteForce
I just snorkeled my buddies 450. I pretty much followed the intructions above. I used white PVC & spayed undercoat spray on it looks sweet. I will put pics in the next couple days!
RIP ~ '05 BRUTE FORCE 750 that I spent WAY TOO MUCH MONEY on!
'85 HONDA BIG RED 250ES (305 now) 26"laws, fully snorkeled
'99 HONDA FOURTRAX 300 4X4, FOR SALE! $2000
'86 HONDA 250R lonestar/ elka rolling chassis FOR SALE $2500
http://community.webshots.com/user/mondexbruteforce
RE: SNORKELIN A 04 FOREMAN 450???????? - 9/10/2008 3:13:05 PM
EZMUDDER
It's really very easy........I did my own!  lol
Polaris Sportsman 800 Triangle ATV Edition
CATVOS Custom Lift, Gorilla Axles, Snorkit Custom Sound System with integrated Snorkels, 31" Outlaws, Lights, Camera, Phone, Lighted Wet Bar, Drain pump....
All the bling with awsome sting!
Triangle ATV "Goin' Deep!"
(in reply to MondexBruteForce)
RE: SNORKELIN A 04 FOREMAN 450???????? - 9/10/2008 8:37:07 PM
STUMP KNOCKIN 450
i built it out of scratch.  ive done all the snorkeling on my kodiak, just wanted to see how yall did yalls.  he didnt want me to cut his plastics, so i ran it out the left side and went up the outside of the fender and then to the rack and up from there.  for doin it in about 20 minutes by myself id say it ended up pretty good.  i dont like seein that much pipe, but to everyone their own.  but thanks guys.
Custom Bumper
Custom Strobes
Custom Audiopipe
2 inch HL lift
2.5ci WARN winch
Amsteel Blue
HMF pipe
DynoJet Kit
Twin Air filter
28 inch EDLs
1979 CJ5
MY PICS:
(in reply to EZMUDDER)
