Running hot
Running hot
All Forums >> [OEM Discussions] >> Polaris >> Running hot Page: [1]
Running hot - 11/27/2008 10:51:56 AM
slim1983
I have an 05 polaris sportsman 800.  It sat up for a week and a half while I put a 3" lift and snorkles on it.  Started it up and took it for a ride around the yard and when I stopped to let it idle it started spitting out coolant and said hot on the display.  I took the thermostat out and cut it so the coolant would just free flow still runs hot.  Then I took the cover off the waterpump and checked the impeller it seems to be fine.  Anyone have any ideas?
RE: Running hot - 11/27/2008 11:11:19 AM
djhawthorn21
Is the fan running. Or the radiator may be clogged with mud
07 POLARIS 700
29.5 12 OUTLAWS ON ALL FOUR
VISION RIMS
SNORKLED THROUGH SPEAKER BOX
AAEN PIPE
(in reply to slim1983)
RE: Running hot - 11/27/2008 11:17:19 AM
slim1983
The fan runs for about 10 seconds then cuts off and the fluids starts coming out
(in reply to djhawthorn21)
RE: Running hot - 11/27/2008 11:32:34 AM
djhawthorn21
How does the fan sound when it is running?  Run a wire to the fan from the battery and see if the fans runs continously.  On my bike the bearings in the fan where bad and it would run for a little while and then lock up.
07 POLARIS 700
VISION RIMS
AAEN PIPE
RE: Running hot - 11/27/2008 12:21:53 PM
slim1983
I'm gonna put it on a switch and see what that does
RE: Running hot - 11/28/2008 4:20:21 PM
vieux-mag
Also check your fan sensor
2004 Mossy Oak Sportsman 700 EFI. 800 intake and 800 exhaust
RE: Running hot - 11/28/2008 7:31:12 PM
stealth500ho
take your front end apart soak the rad  then use a air gun spray it you then soak it again then air gun and so  on till you can see right through it
2008 polaris sportsman 500
ss108 12"
2"lift
spring adjusters
26" swamplight
1"wheel spacer
k&n filter
powermad hand guards
polaris 2500 winch
nylon 3500 rope
60" glacier 1 plow
COMEING SOON !!
hsp exhaust
heel clicker clutch kit
27" gator/vamps
snorkles
(in reply to vieux-mag)
