warriorp
I have a Rule 3300 lb winch on my foreman. I have 12.5volts at the solenoid and at the twist switch. I took the switch aprat last night and cleaned it. However, both before and after, I get a voltage fdrop to 6.75 volts when I engage the switch in either direction. This is a brand new battery I just installed last week. I have the same voltage at the winch motor. I need to perform one additional check before replacing the solenoid: place voltage directly on the winch and see if the motor still works. Any other suggestions?
