Rubicon tranny problems
All Forums >> [Most Popular Discussions] >> Tech Questions >> Rubicon tranny problems Page: [1]
Rubicon tranny problems - 8/12/2006 1:43:17 AM
hmrubicon
I have a 2001 Honda Rubicon that I got in Sept. 2000 it has 6400 miles on it. It has never given me any major trouble at all till now. The problem is my dash display blinks -- D1,D2,ESP and it will not shift gears. It will pull but it stays only in one gear. In low it won't go over about 6-8 mph then the rpms get high and won't shift. When I put in drive it goes about 14-16 mph and revs high but won't shift. Also in reverse it sputters like its running out of gas, or like some Polaris' I've rode where reverse sputters unless you push and hold another button.I had this problem once before, I tried reset it wouldn't work, I checked the fuse it looked milky white I cleaned it did reset, it worked fine ever since.I checked fuses they're ok. I understand that it could be in a "error" mode. I have tried the reset procedure, but I never hear the ecm or angle sensor try to adjust, just silence. So I retrieved the error code and it blinked 5 times, error code 5. I understand it could be an angle sensor,ECM, wire harness,control motor,motor transmission section, or auto tranny unit according to the list. Now I would like to know from anyone who has experienced this problem what is  most likely the problem with their experiences with the Rubicon. If their is no clear answer, what would be the list for the easiest thing to check first, hardest last. I did a search but really couldn't find a clear answer. From what I was able to gather it probably is the angle sensor. But I would hate to purchase parts only to find out that is not the problem. Do dealerships  have a way to test the parts to see if their ok? Or is there a way we can test this with automotive electric current meter? I'm sorry for the long post but I wanted to give the best details that  I could.I appreciate any help you can give me. I just need to know what to check first, and/or what most likely is the real problem.
RE: Rubicon tranny problems - 8/12/2006 8:03:27 AM
gotmuddy
To me it sounds like the angle sensor.
www.GotMuddy.com
Tires for sale
ORIGINAL: baf004
That'll buff right out.
(in reply to hmrubicon)
RE: Rubicon tranny problems - 8/13/2006 4:01:15 PM
Rubicon02
Thats exacly what mine did and it was the bearings that are inside the Hondamatic unit, and you can't even buy them, I had to buy a completely new Hondamatic Unit.  They thought that it was the angle sensor on mine to, but it wasn't.  The way you descrided it is what mine did.  You could pull the engine and see if it is the bearings outside of the trannsmission, because you can buy those.
2002 Honda Rubicon
RE: Rubicon tranny problems - 8/13/2006 5:43:39 PM
Honda Mechanic
Here is section #23 which covers the Hondamatic tests from the 2001 Honda TRX500FA PDF shop manual ..
http://www.sendspace.com/file/c0m9x2
(in reply to Rubicon02)
RE: Rubicon tranny problems - 11/10/2007 4:07:44 PM
Taupo
Hi,
Did you get this problem fixed??? Mine is doing exactly the same thing. I know my wiring and ECM are working fine (we changed units) but the error message still blames the ECM.
I am guessing that if we go lookin for faulty angle sensors etc, its a full strip of the hondamatic box anyway??
Anyone got any ideas???
Cheers
RE: Rubicon tranny problems - 11/10/2007 5:43:48 PM
englewoodcowboy
I have an 07 Rubi with no problems. My dad had one of the first rubis to hit SW FL when they were released and what he dosent know wont hurt him as to what I put it through. He just traded it for an 07 after he saw the changes they made over his gen 1 Rubi. Think his had something like 800+ hours on it and the only problem was a carb rebuild and a spark plug and a couple torn boots. As for your problem, if the sensors etc. are failry easy to change, find a buddy with a good Rubi and swap the sensors, you may get lucky and find the problem. Other than that I have a strong feeling it is the tranny unit. JMHO. Good Luck!
Work hard, Play harder, Hunt whenever you can!
2002 F250 Crew Cab 4X4 7.3L Super Chips and 36"
BFG AT
84 Jeep Cherokee Swamp Buggy
2006 Honda Rancher AT
2007 Honda Rubicon Camo
2008 Yamaha Rhino Ducks Unlimited, 27" Mudlite XTRs on Vision 161 Black, Hunter works Machined Sheave, Viper Max 4000# Winch w/Amsteel Synthetic Rope, Double Gun/Bow Rack, Rear Window, Over Fenders, Floor Mats, Benz Silent Rider Exhaust "The Perfect 50mph Hunting Machine"
(in reply to Taupo)
RE: Rubicon tranny problems - 11/30/2007 6:55:16 PM
landscaper
I have the same problem with my Rubi. I have to turn if off and keep turning the key to the on/off position until the computer resets and stops flashing all three selector settings in the display. Has anyone solved the problem yet?
Thanks
(in reply to englewoodcowboy)
RE: Rubicon tranny problems - 11/30/2007 6:57:32 PM
landscaper
Did you find A fix yet for the tranny prob? I am having the same trouble.
Thanks
RE: Rubicon tranny problems - 12/12/2007 9:13:12 PM
hmrubicon
Yes I got the Rubicon fixed in the spring of this year.
I took it to a dealer and the dealer did some electrical tests on the various sensors and such.
The problem was the control unit. The big black electrical box under the rear body.
If I remember correctly it cost me about $250.00 including parts and labor.
But ever since it has worked excellent.
(in reply to landscaper)
RE: Rubicon tranny problems - 12/12/2007 9:28:09 PM
Mrmojorisan
ORIGINAL: landscaper
Thanks
When mine did that, it was the angle sensor.... actually, it was the wire running to the angle sensor...  it was routed too close to the exhaust and it melted causing the angle sensor to fail, so they replaced the wire and the sensor... 9 times out of 10, that problem turns out to be the angle sensor.
'08 Rhino 700 EFI
27" 589's
Aluminum Roof
Stereo
4000lb Viper Max Winch
Light Bar
Skinning / Gutting Lights
Bag Scabbard
Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, wine in the other, body thoroughly used up, totally worn out and screaming... ****, What a ride!!
RE: Rubicon tranny problems - 4/22/2008 6:33:04 PM
Rubicon 500
I have a 02 Rubicon and I am having similar prolems. My speedometer does not read most of the time now and sometimes when i tern then wheeler on the D1 D2 and ESP blink and will not shift and does not no what gear or mode it is in it also sputters in reverse. Anyone no what the problem could be?
(in reply to Mrmojorisan)
RE: Rubicon tranny problems - 5/5/2008 3:15:36 PM
Hank5697
My 2002 Rubicon Had the exact same problems that you are having, I found that the (ANGLE SENSOR) was bad. Bought a new one and installed it , Haven't had any problems since. Average cost for one is around $80 bucks. Hope this info will help you.
(in reply to Rubicon 500)
RE: Rubicon tranny problems - 5/19/2008 5:00:40 PM
Rubicon 500
what code was your machine comeing up with before you installed the new angle sensor?
(in reply to Hank5697)
RE: Rubicon tranny problems - 8/10/2008 7:41:25 PM
zebulan
i just got a d1,d2 esp flash on my screen and sputter in reverse,other than the sputter it ran great,any way stopped at the top of the hill and turned key off and on flash stops, reverse works great,good to go .got a clymer book, got codes.screen flashes 5 times 1 second 5 flashes 2 second intervale then the 2 sets of 5 again.****?can someone explain the sequence to me please?this is the first computer controlled rig i have had.i should have known better.if it has ****,tires,or a computer ya got trouble.
RE: Rubicon tranny problems - 8/28/2008 9:04:36 PM
Hank5697
Rubicon 500.... I had a flashing code of 5
God,Family,Union,Any Questions?
(in reply to zebulan)
RE: Rubicon tranny problems - 8/28/2008 9:43:53 PM
msrubicon89
mine was doing it i turned my bike off and cranked it right back up was fine for 5 minutes then sput sput cough cough fart fart ya you know. turned it off again and has ran fine ever since it happens about every 4-6 months it does it
2006 GREEN RINCON RUBBER DOWN LIFT HL SPRINGS C SERIES BLACK TYPE 7'S 28INCH OUTLAWS AND 27INCH 589'S
1985 big red 250es title in hand + both original keys
1982 185s < starts on first pull
2004 rubicon seat cover high lifter floor board kit 27inch outlaws hmf utility with swamp series tip with snorkel, 1.5in rear spacers strobes in the 2 bottom lights 48 quart marine cooler snorkel done by mud predators flowood,ms bash plate <<<< SOLD IT
RE: Rubicon tranny problems - 10/4/2008 6:20:00 PM
frankdunbar
I have a 2001 honda rubicon 500. It has 3100 kms and i just got it repaired. It needed a new peice in the engine that honda olny sells for $1,400. I dont know what it is called but it was very expensive. I thought my problems were dont but i just got it out of the shop and the display keeps flashing D1, D2, and ESP. If i try to drive it like this it wont go very fast it just rev's high around 25km/h. I shut it off and on again and it stops. I would like to know why it is doing this? Is it just an electrical problem or if this continues will my machine blow up and cost me $3,500 to fix again?
I am very grateful for any advice that anyone can give me to getting my ruby up and running nicely.
RE: Rubicon tranny problems - 10/5/2008 4:39:43 AM
Honda Mechanic
You have to count the flashes...
(in reply to frankdunbar)
RE: Rubicon tranny problems - 10/5/2008 11:40:37 AM
frankdunbar
thats all you do is count the flashes....
is it like a high number.. cause i dono if its stops or not
(in reply to Honda Mechanic)
RE: Rubicon tranny problems - 10/5/2008 9:32:32 PM
lonegunman
what is the angle sensor and what is its function. i aint got a honda so i dont know
lonegunman
TEAM TOXIC MOTORSPORTS
WWW.TEXARKANAMUDHOS.BLOGSPOT.COM
www.myspace.com/lonegunman0717
2001 arctic cat 300 4x4
lift kit
26" dirt devils
rokstar wheels
snorkeled
jetted
ion halogen driving lights
2500 warn winch
2007 a/c 650 H1-RED
LE wheels
front brush guard
LE rear bumper
28 mudlites
warn winch
H.P.A.C.
It all seems hardpack when you ride a cat
