Rincon with 28 qusetion?
All Forums >> [OEM Discussions] >> Honda >> Rincon with 28 qusetion? Page: [1]
Rincon with 28 qusetion? - 8/26/2008 8:40:29 PM
SS_CapGun
I have 28x10x12 in the front sbacks; they rub if I turn to hard. I want to know if just a lift will fix the problem or will i need a lift and wheel spacers? Ohh yeah I also have aftermarket wheels, THANKS!
RE: Rincon with 28 qusetion? - 8/26/2008 8:51:28 PM
meatman
a lift will help, try a 2'' first, i don't like spacers but my 27x10x12 bugs on stock wheels rub the fender well a little ans i have a 3'' lift.
07 honda rincon 680, 3" lift, 27" mud bugs, full skid plates, daul "no cut" snorkels, and then some
(in reply to SS_CapGun)
RE: Rincon with 28 qusetion? - 8/26/2008 8:53:30 PM
SS_CapGun
Where did you get your 3" lift from?
(in reply to meatman)
RE: Rincon with 28 qusetion? - 8/26/2008 9:00:08 PM
muddin011
R u b b e r d o w n Customs im sure, Thats without the spaces also
RE: Rincon with 28 qusetion? - 8/26/2008 9:03:05 PM
meatman
e-bay from a guy named xtremeatver. sience you have a rincon you should go to
www.rinconriders.com
there is a wealth of info about your bike and a lot of great people, in fact xtreamatver is a member. o and i wanted to say if you weight less than 225lbs you might wanna get the 2'' the 3'' puts a strain on your axles untill my 275lbs self sits on the bike and brings it down.  a guy called rubber down customs makes a 2'' and 3'' lift also ut it cost a little more.
RE: Rincon with 28 qusetion? - 8/26/2008 9:08:29 PM
SS_CapGun
Alright bro thanks for the info, I gonna check out rinconriders!
RE: Rincon with 28 qusetion? - 8/26/2008 11:00:53 PM
dcfox
The xtremeatver 3" lift is a good lift...but I wouldn't go that route unless you're a pretty big guy.
The seller will tell you the same thing.
That lift is designed for heavier riders as it puts the cv joints in a pretty tight angle.
He also makes a 2" lift.
I'd bet the biggest place you're rubbing is on the fender brackets.You can gain some clearance on the stock brackets with an adjustment using a BFH.
I'm running the above mentioned RD lift...and have 1" spacers,aftermarket wheels and 28x12x12 up front...and I still rub a little when under a load.
--David
Add me on Myspace
RE: Rincon with 28 qusetion? - 8/27/2008 6:28:44 PM
grant2270
Something else that might help is the fender bracket kit that they sell on this site. It adds a little more clearance on the fenders.
Like dcfox said, the 3" extremeatver lift is nice if you can weigh it down, but you really only need about 200#  to compress it enough to get the cv joint angles back in alignment. I know that from experience. It is a true 3" lift that is why it pushes the angles up to the max.
Definitely check out rinconriders.com, almost everyone that answered you on this thread is a member on that site too!
2006 Honda Rincon 680
Dynojet Power Commander w/modified map
2>1 1/2>2" custom snorkle
UNI filter
2" exhaust power tip with drilled exhaust
28x12x12 Outlaw MST's
12x8 Vision Outbacks
3" XtremeATVer lift with fender bracket kit
HL high capacity springs
Aluminum Products front and rear boot guards
ATV Guru front and rear bumpers and 2" receiver
Quadboss cargo box and seat
(in reply to dcfox)
RE: Rincon with 28 qusetion? - 8/27/2008 9:00:38 PM
SS_CapGun
I need some kinda solution fast!!!
(in reply to grant2270)
RE: Rincon with 28 qusetion? - 8/27/2008 9:04:50 PM
lovnmud
ORIGINAL: SS_CapGun
heres a solution.HAMMER!!!come on i wanna hit something,lets hammer it then you can order the HL fender kit.Deal .....cool ill bring the sledge
_________________MUDAHOLICS_____________
2008 Rancher 420 es 4x4 camo
highlifter 2 inch lift kit
highlifter 2 inch wheel spacers
highlifter lift springs
10000k H.I.D kit
28 inch outlaws
highlifter xl2 alum. wheels
Power commander III
HMF pipe
snorkle
uni filter
audiopipe
other goodies......:)
______________"There is no cure"____________
RE: Rincon with 28 qusetion? - 8/27/2008 9:26:43 PM
b0bbymc
Short term solution: Sharp knife and BFH
Long term solution: HL Fender Bracket Kit and HL 2" lift. Gotta rep Highlifter!!!!(This is their forum u know.)
2007 Rincon, Camo, ATV-guru.com Front Bumper (Tree Deflector), Pro Box Redneck Rider, 2" HL lift, 28" Super Lights, Black MA Trooper Wheels, .99 cent beer holder, 20hp sticker mod, and plenty of Liquid Courage strapped down in the ice chest..."Let It Eat!!!"
They're only 12"s... But I keep 'em clean!!!
(in reply to lovnmud)
