duckman06
ORIGINAL: rzrdawg If your left brake and turn signal works, then it isnt a fuse. Both the left and right brake and turn signals work off the same fuse. The park(running lights) are seperate from the turn signal and brake fuse. It is prolly and most likely going to be the bulb. Yes the left side works find (turn & brake signal) but again right side is not working! So what u are saying is that it want be a fuse due 2 this fact! I just changed both the side bulb & the main bulb about 3-4 months ago but if u think this is the problem I will check!!! What about the rusty ball??? Is there anyway this could be possiable???
You have to pay to Play!!! Play hard or don't play at all!!! Everything happens for a reason!!! I work hard but play even Harder!!! 06 Rancher E.S. 4x4, with 2 inch lift, H/L springs, Jet Kit, K&N air filter, clutch kit, F/R Snorkel, HMF pipe, front brake kit, Warn 424, 26 inch Outlaws MST's on rims, Rule winch, ball hitch lift, Audio Formz Radio. 07 Big Bear 4x4, 2 inch lift, 27inch 589's, ITP Rims, H/L Springs, Jet Kit, Clutch Kit, Snorkel, HMF Pipe, K&N air filter, Warn Winch
