dennyb_of_raleigh
ORIGINAL: Hatchie I know there is a modification where you don't have to mash the brake pedal to shift into reverse on an Old Kodiak.....WHAT IS IT? There should be a cable that runs from the gear shift mechanism over to the foot pedal ... remove that & you should be good to go.
Old Skool ('97) Yamaha Kodiyakyak ... thought it was used, turned out to be abused!! 27 in. 589's, ITP type 4 rims, 2 in. lift, snorkeled, DG muffler, K&N, rejetted (115 main), DG bumper, temp gauge, EPI perf. clutch kit, relocated oil cooler & fan, custom front disc brake conversion, fresh top end rebuild with 85mm BBK (10.5:1 CR) from JE, 88 grind webcam w/tit. retainers & all the fixins !! ...never finished ....
