Rinny650
If you mud ride it will keep the radiator from getting slogged up with mud. With a rincon specifically the oil cooler is mounted so close on the front of the radiator that it will get mud trapped behind it and that will cause the bike to run very very hot. Also with the rad above the rack its much easier to clean. If you dont want to relocate your rad then you can pull the 4 bolts that hold the oil cooler and put a few washers on each bolt between the oil cooler and rad to space it out and then you can clean it easier.
Team C.I.C. 2004 F-150 6" Fabtech 2" Daystar 36x12.50x18 Baja Claws 1984 Ranger 5.9 360 big block/ C6 3 speed 6" superlift 33x12.50x15 TSL's Previous Quads 2004 V-force 900cc, 26" Skat Trak Haulers 2005 Rincon 702cc,GR, 26x12 Laws 2007 Popo Sportsman,28x9.5 Laws 2002 Foreman, GR, 475 BBK, 27x12.5 Laws
