RZR, no 4wd in reverse
All Forums >> [OEM Discussions] >> RUVs (Recreational Utility Vehicles) >> RZR, no 4wd in reverse Page: [1]
RZR, no 4wd in reverse - 8/24/2008 11:51:49 AM
megagrizz
Ive got a friend that just called and said he has no 4wd in reverse on his rzr, i dont know alot about this machine so once again , im turning to this forum for help.
Any thoughts?
06 Grizzley, 29.5 laws, HL clutch kit, HMF pipe and jets, snorkled, radiator on rack, HL temp guage
6 inch **** lift, 1.5in spacers
06 foreman 500, 28 laws, clutch kit, HMF pipe/jets, 2" lift, HL springs, snorkled
Too often, we lose sight of lifes simple pleasures. Remember when someone annoys you it takes 42 muscles to frown, but only 4 to extend your arm and smack the crap out of the guy.
RE: RZR, no 4wd in reverse - 8/24/2008 1:05:41 PM
teamcovert
I'm not sure but I know the ATV's only have 4wd in reverseunless u hit the override button. I know the RZR doesn't have one but sry I can't help
02 Grizzly 660
27" Vampires on C-Series type 4
1.5" wheel spacers front, 1" wheel spacers rear
Pro Flow K&N filter
Edlebrock Carb
HMF full pipe
EPI clutch
Full Alum skids
3.0 Warn
PROCOM CDI & Rectifier
Works Perfromance AT-Steeler shocks
00 Team Alba Wolverine
08 Polaris RZR
26" Mudzillas on Vision 161
Red HL roof
(in reply to megagrizz)
RE: RZR, no 4wd in reverse - 8/24/2008 1:42:35 PM
Payton1906
If the battery does not have enough volts it will not engage in 4wd seems a lot of people have had this problem hook it to a charger and and see what happens then. Also is takes like 3500 RPM or something like that before the rzr starts charging the battery. If this is the case tell him to upgrade to a oddysey 925 battery, I had zero problems with mine and it fits in the stock holder just have to mount it sideways.
08 White Carbon Polaris RZR
Looney Tuned Dual Exhaust
Modified Air Intake With K&N Filters
EPI Clutch Kit and Belt
Power Commander Programmer
MPI Programmed ECU
Autometer Water Temp, Volt, and Wideband A/F Gauges
Polairs Rear Bumper, Lock and Ride Box, and Sport Roof
Maier Fender Flares and White Carbon Fiber Plastic
14in ITP SS112 with 26in Bighorns
12in ITP SS112 with 28in Outlaws
EMP Alum Skid and Alum Products A-arm Gaurds
Rubbadown 2in Lift and Highlifter Springs
(in reply to teamcovert)
RE: RZR, no 4wd in reverse - 8/24/2008 3:06:29 PM
megagrizz
thanks, ill let him know , and post what he comes up with.
(in reply to Payton1906)
RE: RZR, no 4wd in reverse - 8/24/2008 5:56:06 PM
02Sleeper
Voltage maybe but it could be a broken cage or the ring gear out of alignment. I know mine was on again and off again. Found out it was the ring gear was sliding over and allowing the cage to move away from the armature plate. Took it apart to find this.
2008 RZR -
29.5 Laws, SS 212's Snorkle, Extreme lift, spacers, HL Lift springs, Warn 4.0 (Sold)
2006 Rhino 450
Extreme lift, EVO Big Gun Pipe, clutch kit, Snorkled and a ice chest. ITP Type VI, 28" Mud Hogs
(Sold)
2007 Grizzly 700
Sitting on 29.5's and SS112's
Snorkled, piped.
2004 Bombardier 400 XT
Custom "Wild Thing" paint scheme (sold)
2003 Kodiak 450
Piped and Snorkled
28" Outlaws
2003 Arctic cat 300 4x4
Snorkled, EDLS, pipe etc...
RE: RZR, no 4wd in reverse - 8/24/2008 9:46:03 PM
Jfree
02sleeper, is that in the tranny itself or in the front end.  Noticed Mine would not go into 4wd in reverse this weekend as well and I just got it  back from a tranny overhaul from the dealership within the last couple of weeks.  They are saying its a faulty gear indicator switch that's not allowing it to sense that it is in 4WD.  Any thoughts on this?
(in reply to 02Sleeper)
RE: RZR, no 4wd in reverse - 8/24/2008 9:55:55 PM
02Sleeper
ORIGINAL: Jfree
If its mechanincal I would say its the dif. Did you run the diagnostics on it for codes. The speedo will tell you if its reading. Actually is the 4wd indicator coming on when in reverse? If it is not then its electrical (gear switch). On mine the 4wd showed to be active but had no 4wd.
I know dirty fluiid will cause a lot of the same symptoms.
2008 RZR -
2006 Rhino 450
(Sold)
2007 Grizzly 700
Snorkled, piped.
2003 Kodiak 450
Piped and Snorkled
28" Outlaws
(in reply to Jfree)
RE: RZR, no 4wd in reverse - 8/24/2008 10:12:58 PM
snowhite
i know of a guy that had the same problem,  check to see if ur display says that it is in "R"  or if it is just blank.....  get it to show "R" and u should be good to go!
www.I45Racing.com
Pit Proven Performance Custom Dynojet Tuning and Clutching
RE: RZR, no 4wd in reverse - 8/25/2008 9:35:12 PM
Jfree
Thanks, the gear indeicator is not working and they (the dealership) is supposed to have that part on order.  Thats all I was hoping it was/is.
(in reply to snowhite)
