Problems in semi-deep water.......
All Forums >> [OEM Discussions] >> Honda >> Problems in semi-deep water....... Page: [1] 2 3   next >   >>
Problems in semi-deep water....... - 7/23/2008 8:37:52 PM
B.W.L 500
When i get in water just over the floorboards it spits and sputters and then turns off,the minute I get out the water it is running perfect,like nothing happened,can yall tell me what is going on here,and how to fix it??
Brian
06 Red Foreman 4x4 S
-Dynojet
-HMF swamp Series
-Cupholder
-Stick stoppers
-Back rack box
-Custom back rack icechest
-Duplicolor lined racks
-Custom tow hook
-Removed hitch
-Custom trimmed plastics
-26" ITP 589s
-12" ITP type 5 rims
-All vent lines to pod
Future mods
-27" Laws
-Audiopipe
-Highlifter springs
-Slick snorkel
PM me if yall are goin on a ride by Breaux Bridge
http://www.myspace.com/honda500rider
RE: Problems in semi-deep water....... - 7/23/2008 8:39:30 PM
dcfox
Steam is getting sucked into the intake.
Only solutions are to either snorkel it or stay out of the water.
--David
Add me on Myspace
(in reply to B.W.L 500)
RE: Problems in semi-deep water....... - 7/23/2008 8:40:55 PM
B.W.L 500
ORIGINAL: dcfox
No way,its never done that before!!!Alright,if this is the problem,how can I solve it WITHOUT snorkeling it?
Brian
-Dynojet
-HMF swamp Series
-Cupholder
-Stick stoppers
-Back rack box
-Custom tow hook
-Removed hitch
-26" ITP 589s
Future mods
-27" Laws
-Audiopipe
-Highlifter springs
-Slick snorkel
(in reply to dcfox)
RE: Problems in semi-deep water....... - 7/23/2008 8:42:38 PM
dcfox
Not sure.
My buddies Foreman was doing the same thing...and the snorkel fixed it.
How about a stealth snorkel up under the pod?
--David
Add me on Myspace
RE: Problems in semi-deep water....... - 7/23/2008 8:43:34 PM
B.W.L 500
Alright,how do I do that?Does someone have pics of how they did a hidden snorkel,and what they used?
Brian
-Dynojet
-HMF swamp Series
-Cupholder
-Stick stoppers
-Back rack box
-Custom tow hook
-Removed hitch
-26" ITP 589s
Future mods
-27" Laws
-Audiopipe
-Highlifter springs
-Slick snorkel
(in reply to dcfox)
RE: Problems in semi-deep water....... - 7/23/2008 8:47:08 PM
dcfox
A hidden snorkel should be easier than an exposed one...because you don't have to cut the fender,and you don't have to switch the pipe from flex to rigid.
Worst thing you would probably have to do is trim a little off of the bottom side of the pod to make room for the flex to be shoved up in there.
--David
Add me on Myspace
RE: Problems in semi-deep water....... - 7/23/2008 8:51:31 PM
B.W.L 500
so,do I run it under the gas tank or what,which route do I need to take?
Brian
-Dynojet
-HMF swamp Series
-Cupholder
-Stick stoppers
-Back rack box
-Custom tow hook
-Removed hitch
-26" ITP 589s
Future mods
-27" Laws
-Audiopipe
-Highlifter springs
-Slick snorkel
(in reply to dcfox)
RE: Problems in semi-deep water....... - 7/23/2008 8:54:45 PM
dcfox
under the plastic...around the lower right side of the gas tank...then flex it up under the pod.
--David
Add me on Myspace
RE: Problems in semi-deep water....... - 7/23/2008 9:02:28 PM
B.W.L 500
cool,what type of hose do I use?
Brian
-Dynojet
-HMF swamp Series
-Cupholder
-Stick stoppers
-Back rack box
-Custom tow hook
-Removed hitch
-26" ITP 589s
Future mods
-27" Laws
-Audiopipe
-Highlifter springs
-Slick snorkel
(in reply to dcfox)
RE: Problems in semi-deep water....... - 7/23/2008 9:12:42 PM
buzz007
Yep!!! Mine was doing the same thing. I did not want to snorkle it either but sure enough that fixed it.  Man you have no Idea how long I looked at other thing before giving in to the snorkle. No looking back now.
2006 foreman 500 es Copy-cat snork
HMF SWAMP SERIES
27'' swamp witch on vision wheels
ramsey wireless
hlp leak sheild
moose hand gaurds
k&n w/t outerwear
dinojet kit
"W / TUNES "
RE: Problems in semi-deep water....... - 7/23/2008 9:14:42 PM
dcfox
blue 1 1/2" spa hose...available at Lowe's...and whatever PVC fittings you need to convert it to the 2" inlet of the airbox.
--David
Add me on Myspace
(in reply to buzz007)
RE: Problems in semi-deep water....... - 7/23/2008 9:14:57 PM
B.W.L 500
cool,im gonna run it out by my gas tank on that black plastic peice.....
Brian
-Dynojet
-HMF swamp Series
-Cupholder
-Stick stoppers
-Back rack box
-Custom tow hook
-Removed hitch
-26" ITP 589s
Future mods
-27" Laws
-Audiopipe
-Highlifter springs
-Slick snorkel
RE: Problems in semi-deep water....... - 7/23/2008 9:16:16 PM
B.W.L 500
thanks for the help yall,really appreciate it....
Brian
-Dynojet
-HMF swamp Series
-Cupholder
-Stick stoppers
-Back rack box
-Custom tow hook
-Removed hitch
-26" ITP 589s
Future mods
-27" Laws
-Audiopipe
-Highlifter springs
-Slick snorkel
RE: Problems in semi-deep water....... - 7/23/2008 9:19:17 PM
dcfox
Or...if you decide to run a regular snorkel...and want to go the easy way out...Triangle ATV sells a really nice kit specific to your bike.
--David
Add me on Myspace
RE: Problems in semi-deep water....... - 7/23/2008 9:23:04 PM
B.W.L 500
yea,but not lookin to spend 100+ for something I can do for less than 20.00,thanks though,your a good help....
Brian
-Dynojet
-HMF swamp Series
-Cupholder
-Stick stoppers
-Back rack box
-Custom tow hook
-Removed hitch
-26" ITP 589s
Future mods
-27" Laws
-Audiopipe
-Highlifter springs
-Slick snorkel
(in reply to dcfox)
RE: Problems in semi-deep water....... - 7/23/2008 9:27:17 PM
dcfox
I agree completely...but some people woud rather write a check...than do a little fab work of thier own.
I enjoyed designing/installing my snorkel.
oh...and you're welcome.
--David
Add me on Myspace
RE: Problems in semi-deep water....... - 7/23/2008 10:16:50 PM
gmcz71
my 300 die(d) when I hit water and I had a snorkel... just thinkin it could be a sparkplug boot problem?
2005 Yamaha Kodiak 400
- 26x9.5x12 Vampires on all 4
- 12" ITP Type 4's black
- HMF Utility
- Jet kit
- K&N (about to be replaced with UNI)
- HL lift kit
- HL clutch kit
- my own custom belt snorkel design
My Pics...
(in reply to dcfox)
RE: Problems in semi-deep water....... - 7/23/2008 11:00:40 PM
Flordia__redneck
Maybe it one of the vent lines from the carb. First time I heard of that whole steam stuff, I dont belive steam could do that.
GiT-R-DiD
ORIGINAL: M_R_M
somebody must of pee'd in his dew
(in reply to gmcz71)
RE: Problems in semi-deep water....... - 7/23/2008 11:07:23 PM
dcfox
It's common on the Rincon for the steam to kill the engine when you get in water that's a little deep.
And it happened repeatedly to my buddies Foreman.The only change we made was the snorkel...and it solved the problem.
--David
Add me on Myspace
(in reply to Flordia__redneck)
RE: Problems in semi-deep water....... - 7/23/2008 11:10:00 PM
Flordia__redneck
But when you snorkeled it did you also re-run all the vents? So does the rincon die running in the early mornings on a foggy day?
GiT-R-DiD
ORIGINAL: M_R_M
(in reply to dcfox)
RE: Problems in semi-deep water....... - 7/23/2008 11:14:22 PM
croc_j2001
lol
2008 Honda Foreman 500
Power Steering
27x12x12 Outlaws
2 inch lift
Supertrapp pipe IDSX (junk)
Heated Handlebars
Itp Rims
Skid Plates
Jet Kit
Waterproof Stereo
Mod's To Come
Gear Reduction
Lockers
Snorkel
Better Shocks
Louder Pipe (mine is too quiet)
RE: Problems in semi-deep water....... - 7/23/2008 11:20:36 PM
dcfox
He had already extended all the vents...before we snorkeled it...and it was still stalling when he hit water nore than about 6" above the floorboard.
As for morning fog...there's a little difference between a foggy morning and an instant shot of heavy steam right in the intake.
But I'm not going to argue with you about it.You have more posts than I do and have been a member here longer.
So apparently I don't know what I'm talking about.You're right...I'm wrong.
--David
Add me on Myspace
(in reply to croc_j2001)
Post #: 22
RE: Problems in semi-deep water....... - 7/23/2008 11:23:36 PM
foremanten10
take a skrew and put in the bottom of the hose of the drain to the carb and block it off. if that dont work then SNORKLE that thing and go deep.
Post #: 23
RE: Problems in semi-deep water....... - 7/23/2008 11:35:38 PM
Flordia__redneck
ORIGINAL: dcfox
Im not trying to argue with you, it just dosn't make sence that a bike will die from a little bit of steam. Your probably right because I dont own a rincon and its probably happened to you.
GiT-R-DiD
ORIGINAL: M_R_M
(in reply to dcfox)
Post #: 24
RE: Problems in semi-deep water....... - 7/23/2008 11:38:55 PM
dcfox
Sorry I snapped...I'm tired and should really go to sleep.
Truthfully...with the location of the factory intake on a Rincon(Foreman is in the same place),coupled with the shape of the seat,water hitting the hot engine actually sends quite a bit of steam directly into the intake.
--David
Add me on Myspace
Post #: 25
RE: Problems in semi-deep water....... - 7/23/2008 11:41:10 PM
Flordia__redneck
Thats just messed up, dieing in knee deep water. Never had the problem on my rancher, that thing went to about rack deep and then it die. But then its rebuild time, so I would rather the bike die in knee deep water then waist deep.
GiT-R-DiD
ORIGINAL: M_R_M
(in reply to dcfox)
Post #: 26
RE: Problems in semi-deep water....... - 7/23/2008 11:43:23 PM
dcfox
Well...I fixed the problem on mine...now submerging the racks isn't an issue.
--David
Add me on Myspace
Post #: 27
RE: Problems in semi-deep water....... - 7/24/2008 12:36:12 AM
croc_j2001
i wouldn't put a screw in the drain hose.  it's there for a reason.  steep grades and wheelies, it's there to let excess fuel out
Power Steering
27x12x12 Outlaws
2 inch lift
Heated Handlebars
Itp Rims
Skid Plates
Jet Kit
Waterproof Stereo
Mod's To Come
Gear Reduction
Lockers
Snorkel
Better Shocks
(in reply to foremanten10)
Post #: 28
RE: Problems in semi-deep water....... - 7/24/2008 6:23:59 AM
dcfox
Yeah...but what it does drain is usually just a drop or 2 at a time.
I have a golf tee stuck up in mine,and just check it after each ride.
The most I've ever had come out when I remove the tee is only enough to fill the tube about 1/4".
In my opinion...plugging it is a good idea...but with somethign that's easily removeable.
--David
Add me on Myspace
Post #: 29
RE: Problems in semi-deep water....... - 7/24/2008 8:19:08 AM
TexasEdition
This sounds exactly like what is happening to my Rancher ( 2006 )..everytime I hit water, even if it's 8" deep, over 5 miles an hour it will cut out, spit and spudder and loose power until everything dries off it seems..This time though it is continuing to cut out even after it dried out..so I'm just trying to think of the possibilities..
Hey Watch This....
06 Rancher 350FM
DynoJet Kit
HMF Utility Snorkeled Exhaust
#2500 WARN
Aluminum Front Winch Plate and Boot Guards
WARN 4-2-4 Un-Locker
Douglas Rockstar Wheels w/ 26x10x12 Executioners
(in reply to dcfox)
Post #: 30
