Polaris 400 Sportsman 4x4 not working 2001
All Forums >> [OEM Discussions] >> Polaris >> Polaris 400 Sportsman 4x4 not working 2001 Page: [1]
Polaris 400 Sportsman 4x4 not working 2001 - 7/25/2008 10:40:13 AM
guard278th
Does anyone know how to bypass the speedometer so that i can engage my 4x4 without buying a new one Thanks Alot if you can Help!! ASAP
RE: Polaris 400 Sportsman 4x4 not working 2001 - 7/25/2008 12:02:26 PM
Rat
There are a couple wires under the plastic.   These wires come from the coil assemblies in the front hubs for the awd.   One is ground and the other is power.   Hook a battery power to the power side and ground to the other side and your set. Wire a switch of some sort in the power line.
....SNORAT....
For further help please direct any question for me, to me at www.atvnation.com
(in reply to guard278th)
RE: Polaris 400 Sportsman 4x4 not working 2001 - 7/25/2008 2:41:41 PM
Big_T
This should actually work for the newer ones, correct?
Split audiopipe (self built)
Heelclicker
(in reply to Rat)
RE: Polaris 400 Sportsman 4x4 not working 2001 - 7/25/2008 3:14:13 PM
Rat
Come on T, I know you know better.    But to answer your question.   Yes apply a switchable battery voltage to the coil assembly and hardwire the ground rathern then rely on the ground going through the system and it will work.
if memory serves me correct it was the ground that ran through the speedo or other control systems.
I would have to dig a manual out to make sure but I think that is why the awd doesn't work when the speedo goes out sometimes.
Yeap, I just dug out the manual.   Power runs from the awd switch to the coils then to the speedo then it goes to ground through the speedo.
So try wiring up a hard ground first.  The wire coming from the hubs goes to Pin E at the 6 pin (larger connector) on the back of the speedo.
Some times the speed sensor (goes to the right front wheel) can cause awd engagment problems.   Not every time but it has.
Does the speedo log hours properly?   If not then the fault is 9 time out of ten the speedo head itself.   If it logs hours but the trip meter and MPH does not work then the issue may be in the speed sensor on the right wheel.   It is located on the brake caliper bracket.
The speedo head on these models is also the Hub engagment RPM limiter. The models that do not have a speedo use a seperate module to control the hub engagment rpm limiter.
What this limiter does is not allow the awd to engage above a certain rpm.
This is why the awd stops working sometimes when the speedo head goes bad.
....SNORAT....
(in reply to Big_T)
RE: Polaris 400 Sportsman 4x4 not working 2001 - 7/25/2008 4:00:12 PM
REDNECK0731
HAY RAT
IF YOU WIRE IT THAT WAY IT WILL STILL BE ENGADED IN REVERCE WITHOUT PUSHING THE OVERRIDE BUTTON RIGHT
BECAUSE IF THAT IS THE CASE I GOING TO REWIRE MINE AGAIN
99 SPORTSMAN 335 (5300 + MILES)
08 GRIZZLY 350 (WIFES QUAD)
(in reply to Rat)
RE: Polaris 400 Sportsman 4x4 not working 2001 - 7/25/2008 4:32:37 PM
Rat
The 99 maybe different pending on how your speedo is driven.
If yours has the circuit board below the headlight pod then there is an easier way to dissable the reverse limiter.
....SNORAT....
(in reply to REDNECK0731)
RE: Polaris 400 Sportsman 4x4 not working 2001 - 7/25/2008 4:41:21 PM
guard278th
Thanks guys for the help !
0.219
