4man0822
ORIGINAL: BEAST STATUS LOOKING FOR A GOOD COMBO! I WANT A BIT MORE POWER OUT OF IT THANKS FOR THE HELP Man I'd recommend geting the VDI. It'll only run you bout $200 more than the PC3, & comes with alot more benefits! Corrects the retarded timing, which in turn causes it to run cooler, & gives it a waaaaaaay better lowend! Add this to the other mods in my sig & you've got a helluva fast, powerful single cylinder bike capable of running with/outrunning an 800 Can-Am in 300 ft!  As far as a pipe goes, the Pro Circuit is supposed to give the best gains, with Yoshi in a close 2nd, & HMF utility in 3rd! Now this is via dyno on the same bike, same same dyno, on the same day! I just got my Yoshi installed & it's Awesome, to say the least! Good luck, I hope this helps with your decision & holler if you need anything else! Brandon
I'm just some dumb, not plumb dumb, huh!! My new ride= 08 750 King Quad Belt snorked, VDI, M109R injector, EPI yellow spring, 18 gram weights, 2mm shim mod(Coop 45 mod) Twin Air & Yoshi=WOW! 4 a single, she hauls!! "STOLEN"--- 07 700 Camo King Yoshi Pipe, PC3, UNI filter, 27" Swamp Fox Plus, ATV Audiopipe, with the Bazookas(I love this thing)& **** 2500XT W/syn rope 05 500 Foreman 26"589 M+S 0n black C-4's, HMF Utility series, with jet, & UNI filter, boot guards& kimpex b
