Oil Pressure Regulator Mod
All Forums >> [OEM Discussions] >> Can-Am BRP >> Oil Pressure Regulator Mod Page: [1]
Oil Pressure Regulator Mod - 8/28/2008 10:33:53 PM
Buck Nasty
Anyone know how to raise the oil pressure on these 800s.
Alcohol Injected Turbo Renegade 800 62+ HP
RE: Oil Pressure Regulator Mod - 8/28/2008 10:56:48 PM
outlanderrider
put more in than is recommended? LOL
2007 Can-Am Outlander 400 H.O. Max Xt
BRP Mirror
T-M-2 Front pre-load adjusters
BRP Rack Extension
RCM Shift Knob
BRP Fender Flares
2001 Honda Rancher 350
ITP Blackwaters
(in reply to Buck Nasty)
RE: Oil Pressure Regulator Mod - 8/28/2008 11:03:34 PM
James Chapman
.....no
Raising the oil viscosity is a temporary fix. But not what your after i dont think...i really dont know how much more it would raise it
Support our Military and their mission
00 Dakota 4wd
BFG A/T's
Cherry Bomb
She's fast . She's real fast.
Past bike 08 brute
(in reply to outlanderrider)
RE: Oil Pressure Regulator Mod - 8/29/2008 5:57:15 AM
JohnCannon
1) Locate the oil pressure regulator plug screw directly under the magneto cover
2) Remove the oil pressure regulator plug screw
3) Install a shim between the plug screw and the regulator housing
4) Reinstall and tighten the plug screw to the proper torque
The shim looks like a washer. I am not sure what the exact thickness is. Its a little thicker then a normal washer.
MaD MOTORSPORTS
.: www.MUDandDIRT.com :.
YouTube:. http://www.youtube.com/mudanddirt
MaD MOTORSPORTS CUSTOM EFI TUNING
07 Competition Sports/MaD Outlander X
PROUND SPONSOR OF
Team Gander Mtn
Bama Boggers
Matt Thompson
Brutewise
I support the troops 100%. You guys are my heros..
(in reply to James Chapman)
RE: Oil Pressure Regulator Mod - 8/29/2008 6:01:11 AM
rubicon03
why do you want higher oil pressure?
2007 polaris 800 with the goods
hers yamaha Grizzly with 5.5 Primate lift
Your Satisfaction Is Guaranteed
(in reply to JohnCannon)
RE: Oil Pressure Regulator Mod - 8/29/2008 11:00:16 AM
Buck Nasty
ORIGINAL: rubicon03
The new R's have higher oil pressure, so I figured I needed it too.......plus I have a turbo to lubricate!
(in reply to rubicon03)
RE: Oil Pressure Regulator Mod - 8/29/2008 11:01:26 AM
Buck Nasty
ORIGINAL: JohnCannon
Thanks John!
RE: Oil Pressure Regulator Mod - 8/29/2008 11:38:52 AM
mrrpm
The oil pressure regulator is only for limiting the pressure to around 65 psi I think. Shimming the spring just allows it to have a higher pressure to limit to. Mine at least, doesn't hold more than 40 psi when hot, and shimming the relief valve doesn't do a thing, as it isn't up to 65 psi yet. It will help oil pressure when it's cold though, but I would be careful with it, because it might go too high when the oil is cold, and strip those plastic gears. I wonder if that's the reason it's there in the first place. (to keep from stripping the gears when really cold)
< Message edited by mrrpm -- 8/29/2008 3:38:19 PM >
'07 Renegade 800 Turbo
'07 Renegade 800 Stock, Oldest boys machine
RE: Oil Pressure Regulator Mod - 8/29/2008 5:12:06 PM
Buck Nasty
You are probably checking your pressure at idle. Normal oil pressure is 26psi at 1250rpm's and 61psi at 6000rpm's.
The shim for the regulator is one of the changes can am made for the 800r, and all the factory can am boys have always run the shim. Its obviously there for a reason.
(in reply to mrrpm)
RE: Oil Pressure Regulator Mod - 8/29/2008 5:39:22 PM
mrrpm
Yes 26 is normal, mine just holds around 5-10psi at idle, around 40 at 9500, with 50wt. oil in it. (I'm talking hot) The manual says it supposed to start working at 65psi. On mine, it doesn't do anything because it never gets to 65 anyway, I guess the turbo bleeds off too much, I don't know. How much pressure does yours hold?
RE: Oil Pressure Regulator Mod - 8/29/2008 5:52:55 PM
Buck Nasty
I have never checked mine and I don't run but 5w-30 so it may be less than yours. Unless your oil feed line is alot bigger than mine.
(in reply to mrrpm)
RE: Oil Pressure Regulator Mod - 8/29/2008 6:00:58 PM
mrrpm
Check it, when I first checked mine, it scared me to death! This motor has been together the longest, and has made the most power so far, so I guess it's ok. I have a restrictor in the turbo line too, actually the bolt that goes into the turbo has a real small hole in it, to help keep so much oil out of the turbo, smokes less like this. Did you restrict your oil any?
RE: Oil Pressure Regulator Mod - 8/29/2008 6:10:16 PM
Buck Nasty
No I didn't restrict it but the line I used is rather small. The hole in the fitting is less than 1/8 inch.
(in reply to mrrpm)
