Need some info on diff gear ratios.
All Forums >> [OEM Discussions] >> Yamaha >> Need some info on diff gear ratios. Page: [1]
Need some info on diff gear ratios. - 7/25/2008 12:49:41 AM
gotmuddy
IRS big bear rear diff gear ratio, 450/660 rhino rear diff gear ratio please. kthxbye.
www.****
Tires for sale
ORIGINAL: baf004
That'll buff right out.
RE: Need some info on diff gear ratios. - 7/25/2008 9:20:37 AM
LiveForMud
pretty much all yamahas bigger than the 250s use 3.6:1 gears (33/9)... grizzlys, big bears, wolverines, kodiaks, bruins, etc etc
the old timberwolfs used lower 4.16:1 gears (46/11).
2005 RED AC 500M (on vacation for now)
Remote mounted g.o.r.i.l.l.a. 3k lb winch
PC680 battery
iEquus 8068 3 3/8" tach
Reloc'd radiator
26-in XTRs
some other stuff
!seals, !brakes, !traction, !money, !sanity...
Dad's NEW ride- 06 Foreman S 4WD
(in reply to gotmuddy)
RE: Need some info on diff gear ratios. - 7/25/2008 10:40:43 AM
gotmuddy
thanks for the info.  I wonder if the rhino diffs are lower.
www.****
Tires for sale
ORIGINAL: baf004
(in reply to LiveForMud)
RE: Need some info on diff gear ratios. - 7/25/2008 11:11:22 AM
LiveForMud
from the parts diagrams i've seen, the rhinos use the same 33/9 gear set in the diffs.
i've been trying to cross-reference parts from the 450 and 660/700 engines... the 450's trans is geared a fair bit lower and could be a big help to the 660/700 grizzlys if the parts will swap over. need someone with some experience in these engines to check this out.
PC680 battery
Reloc'd radiator
26-in XTRs
some other stuff
RE: Need some info on diff gear ratios. - 7/25/2008 1:37:50 PM
YAMAFORD
Not meaning to steal the thread but I checked on this last time I had my cases apart. The rhino has a lower middle drive gear (450 even lower) than the 660 grizzly. The problems are that the rhino also has a tendancy to eat engine cases due to the fact that the cases are bored a little thinner to get the larger gear to fit thuse weakening the case.  The second problem,,, althogh I have no proof of this becouse I have not phisicaly seen the middle gear for a rhino but I think it is the gear that alows the engines to be installed backwards. Hey If you could get it to work you would have 2 reverse gears and be able to back out of the nastiest of stuff!
As for the trans there are to many differences.
Kelvin " MuD PiT MafiA "
http://www.creekbottomtrailrides.com/
MINE
04 660 black
27x10 SB's snorkle, rad relocate, 1 ****, 686, clutch kit
WIFES
660 RHINO CAMO 28INCH VAMPS
DADS
03 660 wetlands camo
snorkle,rad relocate ****s on all 4, 29.5 outlaws on ss112 sra wheels
600 grizzly backup
0.219
