minitrk
why do you "think" your not getting spark? either you are or you are not... check to see if you are, pull the plug out put the wire back onto the plug and lay it on the head and turn it over, spark or not? is it getting fuel? and yeah there is a fuse not sure where on a mule
04 foreman 450 yellow - disk brakes - clutch kit - Triangle atv snorkle - jet - uni filter - perfex ltk - hl springs - 27 bi/tri claws on type 4s - warn 3.0 - warn bumper - plasma rope - sealed pull start - back up light - hmf eco - rear box/seat - fener protectors - f&r tow hooks - pod light shut off switch - full prm armour - reverse button override
