NEED HELP CLEANING DIFF
All Forums >> [OEM Discussions] >> Arctic Cat >> NEED HELP CLEANING DIFF Page: [1]
NEED HELP CLEANING DIFF - 7/23/2008 12:34:10 AM
jaidendarrell
i figured while i got everything taken apart for the lift kit to be installed i should clean out the diffs and replace the gear oil in them.
Question 1
i know that the best way to clean them is to flush them with diesel, but how should i go about that?
do i just fill em up then drain em and repeat, or what?
Question 2
What weight of gear oil should i use to fill em back up? and is there  a sertain kind i should or should not use?
Question 3
how much do i refill the diffs with?
i would assume you just fill them until it is flush with the bottom of the fill whole, but im not sure.
also what happens if you get too much, or too little?
07 Arctic cat 700 LE, Custom snorkels, relocated radiator, 30" ITP's, warn 2500 with synthetic cable, Speed works belt/clutch kit, reverse override mod.
RE: NEED HELP CLEANING DIFF - 7/23/2008 1:36:23 AM
redneck36049
#1. the way i didnt it was jack all for tires up and fill with diesal (sp) and let then run it for a lil while then flush a few times with some good oil.
#2. i use lucas 80w/90 ( i ithnk that is the weight AC calls for)
#3. i cant remeber how much to put in them but check your owners manual and i just put a lil less than what it calls for
2007 ARCTIC CAT 650 H1 - in rehab for a mud addiction
LE BUMPERS
2.5 WARN WINCH
RAD. RELOCATED
SNORKLED
HMF
DYNOJET
CLUTCHED
4.0S
29.5 LAWS ON TORKS
6" MONKEY LIFT
AUDIO PIPE
SOON TO COME: CANT SAY BUT IT WILL BE BAD
WANT A CAT CALL STEEL HORSES WISH I DID
MY PICS http://www.myspace.com/redneck36049
(in reply to jaidendarrell)
RE: NEED HELP CLEANING DIFF - 7/23/2008 7:10:11 AM
BATTLE_CAT
I put 8 oz. of 90 wt. front and rear...The owners manual calls for a little more than that though. I also buy the cheapest gear oil I can find because I change it after every ride.
Arctic Cat....nuff said.
(in reply to redneck36049)
RE: NEED HELP CLEANING DIFF - 7/23/2008 7:42:52 AM
bustedknuckles
As stated above Put it on jack stands. Run it 5 or 10 mins. in 4wd in high with the idle turned up enough to spin the wheels around 10 mph. Kill it drain the oil. Refill with diesel and repeat until clean. Front and rear take around 8 oz. I'm with BC on this one, I use the cheap 80w90. I change my diff oil so often it doesn't matter. Also might want to change all 4 diff seals when you tear it apart. Get the new updated ones.
TEAM STEELHORSES Supporter
CATVOS
"APE" Axle
08 ThunderCat
08 650H1
(in reply to BATTLE_CAT)
RE: NEED HELP CLEANING DIFF - 7/23/2008 8:35:09 AM
BLACKCATT
ORIGINAL: bustedknuckles
Ditto!!!!!!!!!!
2005 650 H1 LE
"Original H1 Kitty!"
29.5 x 12 Laws on type 5s
4.0s
2" lift
Rad & oil cooler up top
2" snorkles & sealed
Clutch...
Drilled rollers
Secondary spring mod
Secondary cage mod
3.6 mm shim on primary (super low!)
Carb drilled & clipped
Gutted stock pipe & 2" exhaust snorkel
No more 8" lift = No more burnt boots!
(in reply to bustedknuckles)
RE: NEED HELP CLEANING DIFF - 7/23/2008 10:59:45 AM
jaidendarrell
can this be done with no axles or anything attached? or should i wate untill i get everything on to work on cleaning and refilling the diff
(in reply to BLACKCATT)
RE: NEED HELP CLEANING DIFF - 7/23/2008 3:03:38 PM
HESS
The last time My seals went bad, I didnt have time to change them out so I let my Dealer change them, and he said that he put the new ones in, and I rode about 20 miles and and there leaking really bad....Not to sure if it was the seals or the installer.....
FOR SALE 02 Honda Foreman S
Solitude Built - Custom Snorkles, Snorkled HMF, DynoJet Kit, K&N,Outerwears,Bed Lined Racks-Bumpers-Snorkles-Floorboards, Front Grilla Axles, HL Lift 2", HL Clutch Kit, Spring Spacers, 29.5x10 Outlaws, Maxxis 8 Spoke Rims, Diamond Plate CV Guards-Bash Plate-Warnings
http://www.highlifter.com/forum/02_Project_Foreman_450_S%2fPartout/m_2951063/tm.htm
RE: NEED HELP CLEANING DIFF - 7/23/2008 9:07:22 PM
04articcat
gettin ready to order  seal from steel horses this week. the ones for the drive shafts also
sold
04 arctic cat
650 vtwin
hmf exhaust
fully snorkeled
dynatek cdi
28x9.5 laws
hl pro-series belt
k@n air filter
catvos 8in lift
**** axles
4.0 gears
odessey battery
hl clutch kit
22 inches of gc
(in reply to HESS)
RE: NEED HELP CLEANING DIFF - 7/24/2008 1:49:31 PM
exklueziv
anyone run grease in their diff? instead of oil.
'06 Arctic Cat Six-Fifty H1 LE
Front and Rear bumpers
SS 112s 14inch wheels on 27 mudlites
Clutch kit
Dyno Jet kit
Snorkeled
HMF pipe
HL springs
Gaxles with 2"lift
Rad remounted on top
And I have a TRV
(in reply to 04articcat)
RE: NEED HELP CLEANING DIFF - 7/24/2008 3:14:54 PM
If you run just grease the needle bearings that support the pinion will burn up.
What i do is pack the whole area around the diff seal with Lucas Red and Tacky marine grease and then fill the diff up with (i think) 80/140 weight oil, and by fill it up i do mean run it alittle low.
Only thing i ever found buy packing in the grease is if you pack the locker side real full it will not read "locked" as the grease stops it from having its ground.
I have been doing this for maybe 2yrs now and i dont have diff seals leak on me.
TeAm GeT YoU SoMe
Arctic Cat 08 650H1 LE
Arctic Cat 05 500m
To much to list
{MoKan, chapter}
"H.ard P.ack A.rctic C.ats"
It all seems HardPack when you ride a Cat.
MY PIX
(in reply to exklueziv)
RE: NEED HELP CLEANING DIFF - 7/24/2008 4:01:14 PM
outdrsmn82
why fill it a lil low? i been wanting to do the same thing. i dont ride THAT much water mostly not too deep rutted sloppy holes. but it definately covers the diff so i want to check to see if the fluids bad. not too much time with the new baby. i need to print my manual and see the process.
gwc where do you put  grease? is it inside where the seals are or is that when you change the seals?
06 AC 400M
BRUSH GUARD
FRONT BASKET
REAR SEAT
GUN RACK
LIQUID CADDY
VAMPS
VIPER 3000# W/AMSTEEL
55W HID LIGHTS
1 1/2" SPRING SPACERS
CUSTOM SNORKEL
CUSTOM POLK AUDIOPIPE
THE ONLY REASON YOU DONT OWN A CAT IS CUZ UR SCARED OF HEIGHTS. ITS OK I GET IT.
It all seems like hardpack on a ARCTIC CAT.
(in reply to GWC)
RE: NEED HELP CLEANING DIFF - 7/24/2008 4:49:37 PM
I run them alttile low just to make sure they dont get to full and then leak.
I pulled my axles out and packed the grease on the diff seal and behind it, this just help keep the diff fliud in the diff and water out i have had good luck with it. last time out we rode DEEP water all day and i did not have any water in my diffs at all none.
TeAm GeT YoU SoMe
Arctic Cat 05 500m
To much to list
{MoKan, chapter}
MY PIX
(in reply to outdrsmn82)
0.750
