bansheefan03
unless you always have a problem putting on the clutch cover then it really dont matter. if you do it on all four just stick grease on the part that engages the clutch to hold it all in place and just remember the centrifugal clutch has left hand threads
2006 rhino 660 29.5 swamplites,lift,rear steer,snorkled 98 300 376 bbk,4.5mm stroked crank,ported head,ids2,snorkle,lift,body lift,locker,EDL/ silverbacks ,axle paddle,459 cam,gear reduction,clutch kit,warn 424,chrome XL2 wheels,katana oil cooler,400ex carb soon to come ex head, disc brakes 98 300 8" lift, ape axles,gear reduction,xl2 wheels, axle paddle,high compression piston, clutch kit,459 cam,big red timing c
