My custom taillight.
All Forums >> [OEM Discussions] >> Can-Am BRP >> My custom taillight. Page: [1]
My custom taillight. - 10/4/2008 3:58:28 PM
Justin Q.
Well my little project kept getting delayed since I started on it months ago. But today I finally found time to get it put together. And special thanks to Psycho ward for helping my figure out the wiring. Now some people may not like it, and some may but it still puts a smile on my face. I hardly ever get the biggest or fastest of anything so I normally go for the custom look. But here's some pics. Its an aftermarket clear taillight off a Suzuki SV 650.
With the headlights
And the brake lights
The new light is all siliconed up tight and hopefully I wont see any water floating in it. And there are also amber led turn signals in it which I may just wire up to a flasher or wig wag switch one of these days. To further improve the looks I'm ordering the rear fairing for the motorcycle to fill in the blank space more. Check it out and hope you like it.
2007 Can-am Outlander 650
30" Backs
14" Moto Sport Climax
Pipe lift front & rear
Aaen exhaust
Custom snorkels
Custom Suzuki SV taillight
PM me for the best atv mechanic in the baytown area.
RE: My custom taillight. - 10/4/2008 4:02:12 PM
Justin Q.
If anyone is curious about how to wire it here is the post with the exact description the way I did it.
http://www.highlifter.com/forum/m_2874500/mpage_1/key_led/tm.htm#2887338
Instead of 2 hot wires and one ground Can-am uses 2 grounds as the switch and one hot wire. This is a problem hooking up a normal led brake light so that post shows a way around that. There may be an easier way but this one gets the job done.
30" Backs
Aaen exhaust
Custom snorkels
(in reply to Justin Q.)
RE: My custom taillight. - 10/4/2008 4:14:59 PM
Justin Q.
Few more pics of the install.
The brake switch wires. One goes to the "brake lights" of the taillight, and the other is wired in with the power accessory plug (cigarette lighter) so that its only on with the ignition.
And I managed to lose the factory taillight harness and only had the one left on the bike, So I cut it off and rewired a 4 prong trailer harness in its place. I hate sodering wires so they are all just crimped together with connectors. As an extra step I filled the connectors with di-electric grease before hand, the used heat shrink, electrical tape, then finished it off with a wire loom.
And of course zip tied the wires out of the way. I'll try to get some good night pictures later.
30" Backs
Aaen exhaust
Custom snorkels
RE: My custom taillight. - 10/4/2008 5:25:35 PM
bushhog750
looks pretty good will look alot better with the rear fairing. since you have been in there with the wiring i havent even looked at mine yet is there a way to make the outlanders rear light not stay on all the time. like it lights up only when the brakes are applied any other time its off. i dont like how at night mine stays on all the time then gets brighter when you hit the brakes i want to do away with the constant on.
08 outlander 800 XT red- MaD Cannon tuned- center snorkled- vented- itp ss212's black- 29.5" outlaws- power commander- hmf pipe- uni filter- pipe lift- gorilla radiator relocate- ricochet skid plates- coolanol radiator fluid- crankcase vent mod- amsoil fluids- spider grips- sponsored by VISA and 60 hours a week.
RE: My custom taillight. - 10/5/2008 4:14:37 PM
Justin Q.
I believe you would need to  cut one of the wires on the taillight side to do that. Since I scrapped mine I don't recall which one it is. I do know the red wire is the hot so it would have to be one of the other wires. Just be sure not to cut on the factory harness side.
30" Backs
Aaen exhaust
Custom snorkels
(in reply to bushhog750)
RE: My custom taillight. - 10/5/2008 7:18:45 PM
psycho ward
I'm pretty sure it was the black wire that was hot with key on .
Justin that looks great. I need a new one already, as I got rear ended in the swamp cross race @ creekbottom friday night, and cracked it. Now water gets in it. But I did end up winning that race at least...lol
< Message edited by psycho ward -- 10/5/2008 7:22:53 PM >
07' Can Am 800 renegade (stealth snorkeled), 28" S-Backs on vision 159 rims,Dalton clutch kit, BRP pre filter sock,UNI filter , HMF Penland pro pipe, BRP rear hitch,and Pro Taper handle bars with death grips, custom home made bumper with diamond plating,LED Brake light, 650 helix mod, and diamond plate home made front CV guards
04' Sea-Doo RXP Stage III + (81.3mph on GPS) and still tuning
RE: My custom taillight. - 10/5/2008 8:23:11 PM
bushhog750
psycho ward would you know if its possible to just get my brake light to come on with only an application of the brakes. the rest of the time be off. i dont wanna go to my garage and start snipping wires and have to crimp them back together if some one knows which wire it would be off the top of their head.
(in reply to psycho ward)
RE: My custom taillight. - 10/5/2008 8:40:34 PM
psycho ward
I wouldn't know exactly witch wire would give yoyu that result, because the factory harness switches ground to activate the light, so power would still be needed.
RE: My custom taillight. - 10/5/2008 8:45:04 PM
bushhog750
yeah i see what your saying. did you go to the mudders mag run in doles psycho.
RE: My custom taillight. - 10/6/2008 7:36:57 PM
psycho ward
Yes, I was there. It was a great time! I'm still sore from the enduro bog event, wore me slap out! I Got rear ended in the Swamp cross, and broke my new tail light...lol.
RE: My custom taillight. - 10/6/2008 7:59:12 PM
bushhog750
were you in the enduro with boxslinger.
RE: My custom taillight. - 10/6/2008 9:14:16 PM
psycho ward
ORIGINAL: bushhog750
Yup, that was my crazy butt hangin off the front rack...lol
RE: My custom taillight. - 10/6/2008 9:56:52 PM
bushhog750
i wasnt there but talked to shawn. he said yall was tearing it up til he broke that shaft. i wish i could have made it. but work was being louzy and wouldnt let me come.
