durallymax
out Im on the verge of cracking a piston or blowing a hole in one due to running over 2,000* of EGT all season. soooo,..... the motor is coming out. Heres whats going in. Mahle Cast pistons from trippin which feature a lubricity coating on the skirts, thermal coating on the tops and a remachined bowl all by him. Cost $2,300. Why no forged pistons you may ask?? Not streetable they are not designed for the rigors of dailr driving. Carrillo rods, yep the bad boys. THeyre expensive but worth it since I wanna do it right. The cost $3,125. Trippins billet main caps. For extra protection. Cost $600 plus machining. Clevite H bearings from trippin. ATI superdamper from trippin. Cost $440. Billet flex plate. Brand undecided. The whole rotating assembly will be balanced and blueprinted for 5,000RPM. Head studs and fire rings will keep the heads on and as for cylinder head mods I am yet undecided. If I get enough sponsor money stage II heads from trippin will o on, if not I may build them myself with few parts from him. Camshaft will be a HOT keyed puling camshaft from trippin as $912. Air will be Nathans MPI twins. Fuel will be Some sort of Twin CP3 system at a minimum price of $2,800 Injectors will hopefully be F3s if they ever get the LB7 ones made. Billet injector clamps will help keep them seated. thats about what I can remember, as you can see it will be expensive. I may be forgetting some things too. Tonite alone I scraped up $3,000 in sponsor money. More later.
