jksimpson
ORIGINAL: speedy81304 the moose module with the 6 deg key is good also, I had it done to mine also, but its more work then pluging a CDI unit in place. and you dont need to wrench and replace gaskets and seals. the new adjustable unit, you can add up to 6 deg advance with no damage. also if you have problems and need to go back to stock its easy unplug and put the oem unit back on. I say DYNA, Is the new adjustable unit for the 08's just wondering havent seen one for the 05-07's.. what year is this bike too... id just say my response because 6* plus moose is the farthest you can advance your timing with causing it to "retard" this is if your looking for the most performance.. if your just looking for most performance with a plug and play only... dyna for sure... offers more than moose and cheaper than the vdi...
750brute force Simpson#18 "Team Cumberland Mudders" "Sponsors" X Brand, HelmetMan.com, Interco Tire, Mud-Throwers.com, and XtremeClean my vid http://www.youtube.com/watch?v=uF2C_Ek4hRo
