gravehunter
The MST's do infact have a very noticably flatter profile than the Witches. To try and show this we set a level on top of the tires so you can see the gap under the level. There you will see how the Witch is more rounded. We set the tires at different pressures and took the same pics so you can see the profile difference at what pressure you normally run on your quad. To save having to many pics here i will post a couple and the rest you can see at the Webshots link in the first post. The pictures are labled with what pressure is in them. Both of the MST and the Witch. We took pics and measerments for fronts at: 3.5, 5, 7, 10, and 15 psi. This is the MST at 3.5lbs And the Witch in the post below at the same pressure. The MST's look even flatter in person than these pics show, but its the best i could do. Thumbnail Image
Attachment (1)
2007 Thunder Candy Blue Brute Force 750. Mods so far: HMF Swamp series exhaust, Dyna CDI, Venom 3000# winch, 2" centered intake snorkels. Red EPI secondary, Pink EPI primary. Symtec Winter pack, Prairie 700 handlebars. Army storage box, Moose hand guards. 28" MST's on Vision wheels, 2" SS ATV Plus lift kit
