BLACKCATT
Depends how much you want to spend!!??? Mud Pro is sweet! Regular 700 H1 would be cheaper, but has 3.1s in it. You would want to swap in the 4.0s right away! You can probably still find a 650 H1 and get a geat deal with the 09' models coming out. Either way, you will be happy with any of the bigger cats IMO.
2005 650 H1 LE "Original H1 Kitty!" 29.5 x 12 Laws on type 5s 4.0s 2" lift Rad & oil cooler up top 2" snorkles & sealed Clutch... Drilled rollers Secondary spring mod Secondary cage mod 3.6 mm shim on primary (super low!) Carb drilled & clipped Gutted stock pipe & 2" exhaust snorkel No more 8" lift = No more burnt boots!
