LIMP MODE????
LIMP MODE????
All Forums >> [Off-Road Vehicles] >> Truck Discussions >> LIMP MODE???? Page: [1]
LIMP MODE???? - 7/23/2008 1:04:25 AM
msbogger
Is there any way you can take this off i am thinking of getting a 2007 duramax and plan on putting a edge juice hot tune on it or a ppe tuner and dont want to always have it slippin in limp mode any help guys
-------SOLD---------
2004 arctic cat 400 4x4 25 itp 589's on itp type 5
26 outlaws on stock wheels
warn 2500
ac front bumper
1 inch spacers on front
outlaw clutch kit
dyno jet kit
supertrapp ids2 muffler
custom audio setup
RE: LIMP MODE???? - 7/23/2008 8:17:26 AM
camozuki
The more you default to limp mode the weaker the tranny gets. Get a Transgo Jr. kit for the tranny and try not to beat on it too much. You could always get a built tranny if you want to play a lot. You can clear the code with most programmers.
2005 Suzuki Vinson
2007 GMC Classic CCSB 4X4 Duramax/Ally
American and Proud
(in reply to msbogger)
RE: LIMP MODE???? - 7/23/2008 2:02:55 PM
FF1501
The limp mode is made to protect the tranny.  If it does not have it you got a blown tranny.  Spend the money and build it or get a less hp program...
HIS 07' FCP TEAM GREEN BRUTE
HERS 05' FCP SILVER BRUTE Waiting on WISE
SOUTHERN SWAMP BOYZ
Coppell Firefighters Assoc. Local #3178
http://myspace.com/dbs_snorkles
(in reply to camozuki)
RE: LIMP MODE???? - 7/23/2008 2:55:41 PM
Flordia__redneck
I hate it when it goes limp, can't get anything done
GiT-R-DiD
ORIGINAL: M_R_M
somebody must of pee'd in his dew
(in reply to FF1501)
RE: LIMP MODE???? - 7/23/2008 4:07:27 PM
msbogger
well i want it to be fast and put out some good smoke. i hear ppe is the way to go but can i leave it on high tune. i really want the edge because of the shift on the fly that makes it fun
warn 2500
ac front bumper
outlaw clutch kit
dyno jet kit
custom audio setup
(in reply to Flordia__redneck)
RE: LIMP MODE???? - 7/23/2008 4:10:07 PM
msbogger
i also hear efi live is the best but i dont know anybody in or around mississippi that could tune it for me. i'm not the good with the laptop and motor stuff
warn 2500
ac front bumper
outlaw clutch kit
dyno jet kit
custom audio setup
RE: LIMP MODE???? - 7/23/2008 6:31:40 PM
camozuki
Go to http://www.dieselplace.com/forum/index.php .
Anything you want to know about the Duramax is there. I am camozuki there also.
2005 Suzuki Vinson
American and Proud
RE: LIMP MODE???? - 7/25/2008 10:31:54 PM
RUBICONWRECKER
should have got a truck with a stick. then u dont have 2 worry about burning up the trany just a clutch
2001 RUBICON aka the tow truck
26IN OUTLAWS bigger 2 come
FMF MEGA MAX 2
LUCAS OIL ADITIVES
WARN BUMPER CUSTUMIZED
3000lb WINCH on front soon on back also
1998 & 2001 BANSHEE
both mostly stock with some mods 4 now
2004 DS650 armadillo plus2 a arms, plus2 durablue axle,
anti fade axle nut,custom cams,high comp piston,big gun system,razr2 front and rear
SENSLESSOFFROAD
RE: LIMP MODE???? - 7/29/2008 5:07:01 PM
durallymax
You can take it off but your not going to go any faster.
The reason the truck goes into limp mode is because it detects too much transmission slippage when the torque converter is locked up. So if it goes into tlimp mode your slipping the tranny too much. If you disable limp mode, your still going to slip it and not go anywhere.
Its there to protect the tranny without it you WILL burn up your stock trans.
I dont know of any way to disable it except with EFI Live, ive never even looked for a way to disable it through my EFI Live because it is there for a reason. If you cant afford to build up your tranny you cant afford to run big tunes.
The Edge wont limp a trans. The PPE will. 100hp is about the most the ally will take before it slips.
(in reply to RUBICONWRECKER)
RE: LIMP MODE???? - 7/29/2008 5:35:37 PM
FF1501
We have tried the EFI tranny tuning and it seemed to make it run hotter.  Not Good.  Just a stock tuning with the built tranny is all you need.  The main reason people us the EFI tranny tuning is for the defueling that occures when it shifts.
SOUTHERN SWAMP BOYZ
(in reply to durallymax)
RE: LIMP MODE???? - 7/29/2008 6:01:23 PM
durallymax
The defueling is in the engine calibration not the tranny calibration.
I only use the tranny tuning for making pulling and racing tunes.
RE: LIMP MODE???? - 7/29/2008 7:22:25 PM
FF1501
OK..  The tranny tells the engine to defuel.  It is a tranny file.  I can send you the EFI file if you need it....
SOUTHERN SWAMP BOYZ
RE: LIMP MODE???? - 7/29/2008 7:35:38 PM
durallymax
Im looking at it right now.
The tables responsible for the defueling effect during shifts are. These are all in engine calibration.
B1106 - Peak Torque Vs RPM
B0741 - Torque Limited Injection Quantity
B1102 - Base Torque
Please enlighten me with this tranny file. We are talking Duramax/Allison correct.
RE: LIMP MODE???? - 8/1/2008 11:51:06 AM
nonnieselman
Go with a built Trans with a nice converter and you can beat the crap out of it then... and the smoke thing is pretty pointless IMO unless you just like burning the good ole expensive Diesel.
There are several guys out there that can send you a custom tuned ECM.
2005 Red Foreman 4x4 S
-Rubi Rims w/ 26" MST
2000 Silverado ECSB
LQ4 4L80E STS Nitrous
RE: LIMP MODE???? - 8/1/2008 6:32:55 PM
durallymax
moonshine is a ridiculous tune. If you have a built trans contact the boys at ridgerunner diesel. Not sure if they have it for the LBZ yet.
McRat knows his way around LLYs and LBZs.
(in reply to nonnieselman)
0.500
