4man0822
ROKNOUT Hey man, I took some Ultra Black & ran a good bead around the gasket, put in on the cover & ran another bead on the inside part, then installed. Be really careful not to wipe it all off while matching up to the bike! The Ultra Black, even when dry does not get hard enough to spread/cause a gap in the cover. Let it set, then you can get a lil mirror to look under the cover to see if it has a good seal/needs to be touched up. I had a similar issue with my 750, just once!! Hopefully this helps, if not, maybe try to find another cover! 1 last idea, make sure the cvt plug is getting a really good seal! Later Brandon
I'm just some dumb, not plumb dumb, huh!! My new ride= 08 750 King Quad Belt snorked, VDI, M109R injector, EPI yellow spring, 18 gram weights, 2mm shim mod(Coop 45 mod) Twin Air & Yoshi=WOW! 4 a single, she hauls!! "STOLEN"--- 07 700 Camo King Yoshi Pipe, PC3, UNI filter, 27" Swamp Fox Plus, ATV Audiopipe, with the Bazookas(I love this thing)& Gorilla 2500XT W/syn rope 05 500 Foreman 26"589 M+S 0n black C-4's, HMF Utility series, with jet, & UNI filter, boot guards& kimpex b
