Solitude
Ok everyone wants to know what Rim/Tire combo it will take to run 29.5 Outlaws on a King Quad. Im going to do a write up so u guys know what you will need to run the Outlaws. Im going to think of every combo I can and some of yall can add what I dont. This is either from personal experience or from what Ive seen or heard. Ive never cut the back bar on mine, and I dont have the inner fenders so Im not sure about them. Heres the combos. Also all of this is with the 3" Lift. FRONT COMBOS 29.5x10 Front IRS Wheels - Works best and wont rub. Come close and may hit the floorboards but only at turn and spring compressed. 29.5x10 Front SRA Wheels - Works but hits the floorboard when you turn. 29.5x10 Front IRS Wheels W/ 1" Spacer - Works but hits the floorboard when you turn. 29.5x12 Front IRS Wheels - Works but hits the floorboard alot when you turn. 29.5x12 Front SRA Wheels - Not possible with stock floorboards. REAR COMBOS 29.5x10 Rear IRS Wheels - This app. needed to cut rear floorboard brace. 29.5x10 Rear IRS Wheels W/ 1.5" Spacer - Works great, no rubbing. 29.5x10 Rear SRA Wheels - Works great, no rubbing. 29.5x12 Rear IRS Wheels - Cut rear brace and possibly add 1/1.5" Spacer. 29.5x12 Rear SRA Wheels- Works great, no rubbing. Ok I hope this helps most of yall. Thanks
2007 Yamaha Yellow Rhino 660 SE 2006 Suzuki SLC King Quad 700 EFI 2004 Honda Rubicon 500 GPS 2002 Yamaha Grizzly 660 SE 1994 Honda 300
