Just bought a brute and need help ASAP
All Forums >> [OEM Discussions] >> Kawasaki >> Just bought a brute and need help ASAP Page: [1]
Just bought a brute and need help ASAP - 10/13/2008 9:57:11 PM
fourplayatv700
Ok I'll tell you what I got first, I know ya'll all know of the big MSI brute force that Glenn Cooper use to own. Well I own it now. Get down to the point, Glenn met me at Winn Dixie in Florida to pick it up. So he cranked it up and ran perfect and drove it up on my trailer. All the oil had been changed and had a new filter on it. And the motor has just had a new big bore 840 kit in it with steel sleeves. He said he had about 50 hours of break in time on the motor. So anyways everything was fine and no oil leaks or nothing. Well after I left him I drove about 3 hours down the road and stopped at a gas station to get gas in my truck. Well while the gas was pumping I decided to go crank it up on the trailer. Well when I did I started it up and it was a little hard to crank. But finally it cranked and I gave it a little gas and all of a sudden I heard a noise and looked and shut it off and I had oil pouring out from under neath it. I got my buddy to crank it back up so I could see where it was coming from and it was coming from the top of the oil filter. Finally got back home to Louisiana, and pulled the oil filter off the bike and the top of the inside of the oil filter was blowed out like the bike built up pressure in the motor to cause it to happen. And the filter with oil in it and my engine oil was real strong with gas in it. So I thought maybe the filter might of been bad so I went and bought a brand new Kawasaki oil filter and put on it and changed the engine oil. Then I tried to crank it back up again and it was kinda hard to start at first and then finally it fired over and I gave it a little gas and it done the same thing again. I have done had three oil filters on this bike and they have all done the same thing. And I don't know how the ride home from Florida on a trailer could of caused this to happen.
I'm gonna call Flynt tomorrow to ask him what he thinks might be the problem. Can Flynt or someone that knows Kawasaki real well help me.
President of "Team Four Play"- There is always four play involved before you can play in any whole.
Bike: Team Fourplay MSI Brute
02 GMC Z71
3" body lift
chrome roll bar & 5 KCs
cowl induction hood
chromed out
5% tint (where you can't see up in my windows)
20" Lexanis on 33" Dick Cepek Fun Countrys
some goodies under the hood
RE: Just bought a brute and need help ASAP - 10/14/2008 12:01:37 AM
GoatManx
Need a picture of that oil filter and although not likely easy to get a picture of where it mounts on the motor to really see whats going on.
Brute Force 840 V-Twin
(in reply to fourplayatv700)
RE: Just bought a brute and need help ASAP - 10/14/2008 2:48:26 AM
dbmachine
most of the time the gas in the oil is caused by not plugging the air intake snorkel as the bike is towed..
(in reply to GoatManx)
RE: Just bought a brute and need help ASAP - 10/14/2008 5:32:34 AM
ZacksBF
ORIGINAL: dbmachine
Exactly!
Plug the snorkles for towing on carb bikes or they have a tendency to flood bad. That would explain the hard starting condition and I would imagine if you pull the dipstick and smell it your going to smell gas there too.
2007 Kawasaki Brute Force 750i
2 inch lift
29.5 Laws on ITP SS112 wheels
red secondary spring
rad relocated to rack
MIMB center snorkles
2500lb Warn Winch
The wife's
She is picky and we are STILL shoping, lol
(in reply to dbmachine)
RE: Just bought a brute and need help ASAP - 10/14/2008 5:52:19 AM
fl650mudder
ORIGINAL: ZacksBF
ORIGINAL: dbmachine
Exactly!
It also makes the area where the oil is become overfilled because you have all that gas plus the oil so maybe that is where the pressure is coming fro mto cause it to blow.
East Coast Dirty Boys Mud Bog Team #77
2006 Brute 750 - Lime Green with a little FCP!!! High Lifter radiator, Chrome XL2 wheels with 29.5 Outlaws, Dyna Tech, Big Gun Exhaust, 2008 front end with High Lifter bumper and bash plate, High Lifter skid plates, M.I.M.B. center snorkels
HERS 2005 BLUE Brute 750 - (This is the slow bike)28" Outlaws, HMF, Dyno Jets, Center snorks, Moose Module
(in reply to ZacksBF)
RE: Just bought a brute and need help ASAP - 10/14/2008 1:15:00 PM
Bootlegger
Will a rubber Glove work to cover the air box snorkel? If not can I use a Ziplock baggy with rubber bands around it?
Kawasaki Brute Force 750i Snow Camo
M.I.M.B Snorkels and some other Mods
"Team Cumberland Mudders"
Barnett #10
Sponsored by: X Brand, HelmetMan.com, Interco Tire, Mud-Throwers.com
Powered by: Lansford Kawasaki & Suzuki
MudandDirt.com
(in reply to fl650mudder)
RE: Just bought a brute and need help ASAP - 10/14/2008 1:39:21 PM
PUDDLE JUMPER
anything will work as long as it dont blow off
SUNBEAM RED LE TERYX!
28" bugs "YOU AINT STUCK TILL YA RUN OUT OF GAS"
msa-nukes
audiopipe
snorks
dyna
jet kit
xpatv lift
clutch mod
k&N billet intake
night owl hids
http://www.teryxforums.net
http://www.teryxhq.com
(in reply to Bootlegger)
RE: Just bought a brute and need help ASAP - 10/14/2008 4:39:46 PM
Metal Man
Thats the first thing that popped in my head when reading this was flooded cylinders from hauling it with the snorkels unplugged.
Long story short i once seen a guy pour oil down the oil/air breather of a Ford 4000 tractor thinking it was the oil spout and it filled the cylinders with oil. When he tried to start it it had so much pressure build up it blew 3 freeze plugs out of the block.
08 750 FI Brute Force Team Green
VFJ Stage 3 Spider Mod
Snorkels www.mudinmyblood.net
28" Zillas
ITP SS 112's
H.I.D Head Lights (super bright)
http://img294.imageshack.us/img294/551/newtires1gk8.jpg
01 AC 400 4x4(cant kill it!)
(in reply to PUDDLE JUMPER)
RE: Just bought a brute and need help ASAP - 10/14/2008 5:02:41 PM
phreebsd
bootlegger, this only applied to carb'd bikes.
If yours is 08 dont worry.
2008 Kawasaki Brute Force 750
Outlaws - 27x9.5 F, 27x12 R
1" Spacers
HL 2" Lift
Lime Green Secondary
M.I.M.B Snorkles
Viper Max 4000 with Amsteel Blue synthetic
2007 Kawasaki Prairie 360
Mudbugs - 26x10 F, 26x12 R
Twin Air filter
Viper 3000lb winch
Visit the NEW! MudInMyBlood Forum
TEAM ROLLIN' DEEP 2009
RE: Just bought a brute and need help ASAP - 10/14/2008 5:06:59 PM
fourplayatv700
thanks guys for the info, but ya'll don't think anything in the bottom end is stopped up from the new motor build, cause the bike was drowned before the build and sometimes people go back together with one they don't tear the bottom end down and clean out the sand and mud in one. They just like to rebuild the top end instead of the whole motor.
02 GMC Z71
3" body lift
cowl induction hood
chromed out
(in reply to Metal Man)
RE: Just bought a brute and need help ASAP - 10/14/2008 5:12:25 PM
fourplayatv700
And also why would it still be flooded and hard to start after I changed the oil and the thing had done sat like a whole week. Cause I didn't put the new oil into it until the next Friday night and new filter. So it had been sitting there with the blowed out one and oil with gas in it for over a week before I changed it.
02 GMC Z71
3" body lift
cowl induction hood
chromed out
RE: Just bought a brute and need help ASAP - 10/14/2008 5:31:40 PM
Metal Man
 Maybe flynt or one of the motor guys will chime in here this evening.
28" Zillas
ITP SS 112's
RE: Just bought a brute and need help ASAP - 10/14/2008 7:42:26 PM
greg_bingham
A: if you drained the oil and refilled, the problem should not repeat itself.
B: I've seen this happen to a KZ1000, it blasted the oil filter cap off the bottom of the cases- in that case and this the same thing is happening- the oil is not able to go anywhere, and come out the path of least resistance- the oil filter.
something is wrong in your engine, it needs to be inspected.
greg
** shut up and party **
RE: Just bought a brute and need help ASAP - 10/14/2008 7:49:11 PM
MUD DAWG
my thoughts exacyly!
ORIGINAL: fl650mudder
ORIGINAL: ZacksBF
ORIGINAL: dbmachine
Exactly!
RE: Just bought a brute and need help ASAP - 10/14/2008 8:21:57 PM
flynt
Couple of things I'm thinking...
1: I wonder what kind of oil pressure it's making while it's running before it pops the hole in the filter. If when the motor was assembled they used the wrong rod bearings it could be too tight causing excessive oil pressure. My drag bike makes nearly 100psi when it's cold and have had no problems as of yet.
2: I wonder if the oil pressure check valve is malfunctioning. I'd install a k&n oil filter, I think they use a check valve in the filter that may keep it from blowing, but it won't be filtering.
I don't have a solution for this problem, but would like to take a look at the check valve... This is the culprit, I'd suspect...
warranty? what warranty?
06 FCP Brute Force 926 Dirty South Custom Drag Intakes and Drag Exhaust. SS Powersports Porting.
www.youtube.com/flyntc
(in reply to MUD DAWG)
RE: Just bought a brute and need help ASAP - 10/15/2008 4:00:17 PM
ALMOST30S
Man that blows.. .literally
Team MUD PIMPZ!
THIS BIKE IS FOR SALE!!! YOU KNOW YOU WANT IT!!!7900 0B0
1984 yamaha breeze brute force 500
lift-f150 torsion keys up front and 2inch blocks in the rear
SCUBA GEAR
30x12x15 big horns
flowmaster exhaust
cookie cutter cdi
APC headlights
Transmission work
RIMs-u wont believe it!ROUND ONES!how crazy is that?
Peg leg limited slip 4wd lock
smitty built brushguard
Flux capacitor motor puttin out 19 rwhp!
THIS BIKE IS FOR SALE!!YOU KNOW YOU WANT IT!
(in reply to flynt)
RE: Just bought a brute and need help ASAP - 10/15/2008 9:29:00 PM
ohio_redneck
a tennis ball works great in the end of the snorks
05 750i, 90 miles on new moter, supertrap mudslinger pipe, moose power module ,rejetted, k&n air filter ,clutch kit ,28in maxxis mudzillas, motorsport castle rock wheels
(in reply to ALMOST30S)
RE: Just bought a brute and need help ASAP - 10/15/2008 9:36:24 PM
ALMOST30S
ORIGINAL: ohio_redneck
x2. .thats what i use. .pops in there tightly
Team MUD PIMPZ!
SCUBA GEAR
30x12x15 big horns
flowmaster exhaust
cookie cutter cdi
APC headlights
Transmission work
(in reply to ohio_redneck)
RE: Just bought a brute and need help ASAP - 10/15/2008 9:56:47 PM
outlawbro
i use a 2" hand tite plug
05 BRUTE 750
05 DODGE RAM 3500 5.9 CTD
CUMMINS GUYS ARE KEEPIN' IT STRAIGHT. THOSE OTHER BOYS SWING BOTH WAYS
RE: Just bought a brute and need help ASAP - 10/17/2008 9:15:22 AM
fourplayatv700
thanks guys for all the info and thanks flynt, you helped out a bunch
02 GMC Z71
3" body lift
cowl induction hood
chromed out
(in reply to outlawbro)
