rancherben
I like the idea of one just because after working through a hole past rack deep in the water and mud its just a little piece of mind if you get stuck or something shuts down. If you do a water wheelie you are not going to get water in the exhaust and if it dies in a wheelie you are not going to get near as much water in the exhaust when it pops back up out of the water. A little water traped is alot better than the river giving a constant supply of water.
06 h-1 snorkeles, radiator relocated with roll cage, custom jet kit, glass pack,warn3000, HL spacers,29.5outlaws, vision 161 briusers, front spring spacers, rear prowler springs, gorrila axles x4, custom 2" lift, Speedwerx clutch springs and rollers. You can talk smack if you can back it up
