Ideas: Catastrophic or semi minor?
All Forums >> [OEM Discussions] >> Kawasaki >> Ideas: Catastrophic or semi minor? Page: [1]
Ideas: Catastrophic or semi minor? - 11/25/2008 1:22:50 PM
nicholsonmotorsports
So I'm taking the brute to get it looked at at the end of the week and just thought I would get on here and play around and see the ideas that are come up with that could be wrong.  I am feeling a slight loss of power, it smokes every now and again, and is burning quite a large amount of oil.  Oh and Saturday I was riding and we hit a wide open strip and it slowly lost more and more power until it was barely sputtering to run a measley 5 mph.  Turned it off let it sit for a few minutes fired it back up and it went back to the slighty power loss.  When I say slight power loss the bike won't run over 25mph and the motor just sounds like it is struggling pretty bad to do that.
06 750 Brute Force
-Pro Circuit exhaust
-28" Laws
-MIMB Snorkels
-Audio Tube
06 GSXR750
-Jardine Gp1 Exhaust
360 Sprint Car
-750 hp
-1350lbs
RE: Ideas: Catastrophic or semi minor? - 11/25/2008 1:34:21 PM
CrazyWhiteBo
Sounds like it needs some new rings.
"Ridin' Deep"
-'03 Yamaha Grizzly 660-
Black ITP Type 7's w/29.5 Outlaws
HL Lift
Extreme Snorkels
HMF Pipe
Cam
UNI Filter
DynoJet Kit
HL Extreme Clutch Kit
Radaitor Relocated
Aluminum Bumper Cover
Aluminum A-Arm Gaurds
Gorilla Axles
www.myspace.com/crazywhitebo
(in reply to nicholsonmotorsports)
RE: Ideas: Catastrophic or semi minor? - 11/25/2008 1:38:20 PM
Thats what I was guessing.  That and probably valve adjustment/job.  Hoping thats all it is anyway.....
06 750 Brute Force
-28" Laws
-MIMB Snorkels
-Audio Tube
06 GSXR750
360 Sprint Car
-750 hp
-1350lbs
(in reply to CrazyWhiteBo)
RE: Ideas: Catastrophic or semi minor? - 11/25/2008 1:50:33 PM
BRUTE750ii
ORIGINAL: CrazyWhiteBo
agreed
PINNEN AINT EASY....
2008 BRUTE 750
2500 WARN WINCH
27' OUTLAW MST'S
12' ITP SS108'S
RICOCHET SKIDS
QUOTE FROM MIZZEL 420- THEM BIG 26 INCH OUTLAWS
RE: Ideas: Catastrophic or semi minor? - 11/25/2008 2:11:38 PM
phreebsd
have you verified that both cylinders are firing?
2008 Kawasaki Brute Force 750
Outlaws - 27x9.5 F, 27x12 R
1" Spacers
HL 2" Lift
Lime Green Secondary
M.I.M.B Snorkles
Viper Max 4000 with Amsteel Blue synthetic
2007 Kawasaki Prairie 360
Mudbugs - 26x10 F, 26x12 R
Twin Air filter
Viper 3000lb winch
Visit the NEW! MudInMyBlood Forum
TEAM ROLLIN' DEEP 2009
(in reply to BRUTE750ii)
RE: Ideas: Catastrophic or semi minor? - 11/25/2008 3:05:32 PM
No I didn't actually.  I was so hung up on it being the rings I didnt even think bout that.  Thanks I will definitly check that when I get the plastics off.  I was just leaning a lot more towards the rings since its burning oil.
06 750 Brute Force
-28" Laws
-MIMB Snorkels
-Audio Tube
06 GSXR750
360 Sprint Car
-750 hp
-1350lbs
(in reply to phreebsd)
RE: Ideas: Catastrophic or semi minor? - 11/25/2008 3:08:16 PM
Also if I am lucky enough for it to only need rings anyone know a ball park figure on what that should cost?
06 750 Brute Force
-28" Laws
-MIMB Snorkels
-Audio Tube
06 GSXR750
360 Sprint Car
-750 hp
-1350lbs
RE: Ideas: Catastrophic or semi minor? - 11/25/2008 3:25:49 PM
phreebsd
well i would think it potentially smoke from the unburnt fuel from dropping a cylinder
u said it smoked from time to time. i know it wouldnt have very much power on 1 cylinder.
I think fuel smoke is black. what color is your smoke?
1" Spacers
HL 2" Lift
M.I.M.B Snorkles
Twin Air filter
Viper 3000lb winch
RE: Ideas: Catastrophic or semi minor? - 11/25/2008 3:30:03 PM
White which is another reason I was leanin towards rings.
06 750 Brute Force
-28" Laws
-MIMB Snorkels
-Audio Tube
06 GSXR750
360 Sprint Car
-750 hp
-1350lbs
RE: Ideas: Catastrophic or semi minor? - 11/25/2008 4:19:50 PM
BruteWise
you could have fowled a plug and only one cylinder is firing.  did the same thing to the wife's brute.  the choke was stuck open and just runnin rich rich and fixed it but it was too late for the plug.  change the plugs and see if it runs better.
have you done jetting changes after the snorkels?
and have you ever gotten water in the motor??
TEAM GORILLA POWERED BY CAN AM
Flynt's Custom Performance
Custom ATV of Shreveport
MaD MOTORSPORTS
Submarine Snorkels
**WISE #11**
SOUTHERN SWAMP BOYZ
"I AM NOT A NICE GUY.......I AM A WISE GUY!!"
RE: Ideas: Catastrophic or semi minor? - 11/25/2008 6:42:38 PM
ALMOST30S
ORIGINAL: BruteWise
did this too,my choke got stuck open also on one cylinder and it ran like garbage then.So ill never use the choke again lol.
Team MUD PIMPZ!
THIS BIKE IS FOR SALE!!! YOU KNOW YOU WANT IT!!!7900 0B0
1984 yamaha breeze brute force 500
lift-f150 torsion keys up front and 2inch blocks in the rear
SCUBA GEAR
30x12x15 big horns
flowmaster exhaust
cookie cutter cdi
APC headlights
Transmission work
RIMs-u wont believe it!ROUND ONES!how crazy is that?
Peg leg limited slip 4wd lock
smitty built brushguard
Flux capacitor motor puttin out 19 rwhp!
THIS BIKE IS FOR SALE!!YOU KNOW YOU WANT IT!
(in reply to BruteWise)
RE: Ideas: Catastrophic or semi minor? - 11/26/2008 9:55:31 AM
No I didn't rejet it after the snorkels but its been done for over a month now and actually seemed to run better right after they were installed.  No as far as I know I have not gotten any water in the motor.  Change the oil very regularly and is never milky or anything.  I understand what ya'll are saying about the plugs but that wouldn't make it burn oil.....I mean I'm putting a quart + at the very least in it after every ride.
< Message edited by nicholsonmotorsports -- 11/26/2008 9:59:57 AM >
06 750 Brute Force
-28" Laws
-MIMB Snorkels
-Audio Tube
06 GSXR750
360 Sprint Car
-750 hp
-1350lbs
(in reply to ALMOST30S)
RE: Ideas: Catastrophic or semi minor? - 11/26/2008 10:40:13 AM
phreebsd
if u do lots of wheelies, that's where your oil is going..
1" Spacers
HL 2" Lift
M.I.M.B Snorkles
Twin Air filter
Viper 3000lb winch
RE: Ideas: Catastrophic or semi minor? - 11/26/2008 10:46:40 AM
Lol. Yea I thought bout that also so this last ride when it actually hit the worst its been I made a point to not do any wheelies and still burnt oil.
06 750 Brute Force
-28" Laws
-MIMB Snorkels
-Audio Tube
06 GSXR750
360 Sprint Car
-750 hp
-1350lbs
RE: Ideas: Catastrophic or semi minor? - 11/26/2008 11:16:38 AM
phreebsd
my oil escapes to wheelie land.
I gotta do the catch can mod.
1" Spacers
HL 2" Lift
M.I.M.B Snorkles
Twin Air filter
Viper 3000lb winch
RE: Ideas: Catastrophic or semi minor? - 11/26/2008 11:39:41 AM
Not to get off the topic but Whats the catch can mod?
06 750 Brute Force
-28" Laws
-MIMB Snorkels
-Audio Tube
06 GSXR750
360 Sprint Car
-750 hp
-1350lbs
RE: Ideas: Catastrophic or semi minor? - 11/26/2008 12:11:55 PM
phreebsd
it catches the oil the is puked out the crank case vent and lets it drain back into the motor.
I can find the link to show u what it is if u would like. there's a write-up with pics.
1" Spacers
HL 2" Lift
M.I.M.B Snorkles
Twin Air filter
Viper 3000lb winch
RE: Ideas: Catastrophic or semi minor? - 11/26/2008 12:24:33 PM
phreebsd
here it is right here..
Catch Can Mod with Pics
http://www.highlifter.com/forum/m_1799258/mpage_1/key_Question%2cabout%2ctype%2cOil/tm.htm#1799258
1" Spacers
HL 2" Lift
M.I.M.B Snorkles
Twin Air filter
Viper 3000lb winch
