I need help with my SNORKEL SET
All Forums >> [OEM Discussions] >> Arctic Cat >> I need help with my SNORKEL SET Page: [1]
I need help with my SNORKEL SET - 7/24/2008 8:18:30 PM
4wheelingaaron
I need some help with my snorkel set on my 08 Arctic Cat 500 Auto. I dont have enough air going. Should I turn around that peice that connects to the air box and T it so that I would have to pipes for the air intake, or should I just re-jet it? Also what should I do about on my transmission exaust. On the 08 there is only on pipe going in and one out for the trans. It is really tite if any of you have a 08 you know what I mean! Would putting a K&N air filter help out with the air intake sytem. I new to this so thanks for yalls help. Pictures would help the most.
Thumbnail Image
Attachment (1)
08 Lime Green Arctic Cat 500i Auto. Snorkeld.
RE: I need help with my SNORKEL SET - 7/24/2008 8:21:30 PM
badakodiak
man i got a 08650 h1, and i have a 2in snorkel and i have alot of bends in mine, and it was still getting way to much air, i have a 2" to 1 and a half reducer in mine until i get it rejeted, try taking your hand and covering up some of the pipe and see if it isnt getting too much air.
WILDCHILD CUSTOMS BOG TEAM
TEAM H.P.A.C
2008-artic cat 650 h1 black
k&n
ngk
hmf
2" lift
hl springs (powdercoated silver)
21" of GC
ss 212's
29.5 laws
slide mod
clutched
2007- brute force 750i candy blue
law'd
lift'd
snork'd
k&n'd
2004 kodiak 400 4x4 auto
2"hl lift kit
custom dual snorkels
28" EDL's
moose rear rack
ngk spark plug
2.5 warn
www.myspace.com/wildchildcustoms
(in reply to 4wheelingaaron)
RE: I need help with my SNORKEL SET - 7/24/2008 8:23:03 PM
4wheelingaaron
Well you have a good idea but....what I did a while back was take the air box off and drive it around and I had tuns of power again more than before...so thats when I figured out that I didnt have enough air.
(in reply to badakodiak)
RE: I need help with my SNORKEL SET - 7/24/2008 9:39:03 PM
mrmrezg
most people have to rejet because a 2" snorkel will let in more air than the carb is set up for. your best bet is to pull your spark plug and see what color it is. the whiter the plug the leaner the mix and the blacker the plug the richer the mix. so if you pull your plug and it is black then you are correct in assuming that you are not getting enough air. but i think it will be white.
---team anyting goes---
http://www.anytinggoes.com
http://www.myspace.com/mrmrezg
copyright BK Enterprises Inc.
RE: I need help with my SNORKEL SET - 7/25/2008 3:35:54 PM
mudman3298
just re jet it and be done with it
2007 SPORTSMAN 500
Dirtbmw20 RADIATOR BRACKET
29.5 LAWS
TURNER AXELS IN BACK
1.5 IN SPACERS
2IN PUCK LIFT
STEALTH SNORKELS
(in reply to mrmrezg)
RE: I need help with my SNORKEL SET - 7/25/2008 4:32:21 PM
4wheelingaaron
If I rejet it...what should I go with. Like what size and brand and all that. cuz inst there a lot of different types and sizes to go with.
(in reply to mudman3298)
0.281
