I need brake light schematic help.
All Forums >> [OEM Discussions] >> Can-Am BRP >> I need brake light schematic help. Page: [1]
I need brake light schematic help. - 8/23/2008 1:12:43 PM
Justin Q.
I'm in the process of changing my tail light to something a lil more custom. Well I figured mounting it would be the hard part but its easy. Now the wiring is driving me nuts. I've been around the block a time or two with 12v systems so I'm no amature. Just cant figure this one out.
There are 3 wires for the tail light on the bike. So of course one is going to be a ground. One a brake light, and one a running light. Well just my luck this isnt working out that easy. I cut the wire harness from the factory light so the wires I describe are harness to light wires.
Now I got a red, a black, and a white wire.
With the ignition on in any position the black wire is always hot.
Before I go into full detail of trial and errors anyone got an idea? If not I'll go write down my tests and post it. And its an led tail light also so I'm not to experienced with leds. The light itself works fine seperatly testing it on the battery.  And the factory light worked fine till a month ago when the bulb busted and I just havent bothered replacing it till now.
Penny for your thoughts..
2007 Can-am Outlander 650
30" Backs
14" Moto Sport Climax
Pipe lift front & rear
Aaen exhaust
Custom snorkels
Custom Suzuki SV taillight
PM me for the best atv mechanic in the baytown area.
RE: I need brake light schematic help. - 8/23/2008 3:15:13 PM
psycho ward
Here's a link 2 help u wire it up. Looks like they had the same problem.
http://aurorawheelers.com/forum5/3702.html
07' Can Am 800 renegade (stealth snorkeled), 28" S-Backs on vision 159 rims,Dalton clutch kit, BRP pre filter sock,UNI filter , HMF Penland pro pipe, BRP rear hitch,and Pro Taper handle bars with death grips, custom home made bumper with diamond plating,LED Brake light, 650 helix mod, and diamond plate home made front CV guards
04' Sea-Doo RXP Stage III + (81.3mph on GPS) and still tuning
(in reply to Justin Q.)
RE: I need brake light schematic help. - 8/23/2008 5:42:37 PM
Justin Q.
Thanks that looks like the explanation I needed. Now just to find time to try it out.
30" Backs
Aaen exhaust
Custom snorkels
(in reply to psycho ward)
RE: I need brake light schematic help. - 8/28/2008 9:30:48 PM
psycho ward
I found the solution to the LED wiring problem . You have to take the wires off the brake switch completely, then run a switched power source directly to one post on the switch. I took the + from the lighter socket. Then run a new wire from the other switch post, directly to the LED brake light wire. (red in my case) then hook the BRP black to the LED park light wire. (black in my case) Then the BRP red (- wire) to the LED ground (white wire). Now it works just like it's supposed to. The only problem u will have now is u won't be able to start the bike in gear now. If u hook the (start in gear) wires together it will scroll "BRAKE" across the display....thinking the brake lever is pulled. The only way to remedy this will be to get a "T" fitting and screw it in where switch on the master , and run a second switch just for those 2 wires.
RE: I need brake light schematic help. - 8/28/2008 10:22:18 PM
psycho ward
Here's a few pics
http://i145.photobucket.com/albums/r217/psychoward27/100_0222.jpg
http://i145.photobucket.com/albums/r217/psychoward27/100_0225.jpg
http://i145.photobucket.com/albums/r217/psychoward27/100_0226.jpg
http://i145.photobucket.com/albums/r217/psychoward27/100_0227.jpg
< Message edited by psycho ward -- 8/28/2008 10:26:41 PM >
RE: I need brake light schematic help. - 9/2/2008 11:09:40 AM
breederofkoi
If you've got one wire hot all the time and it never changes, that means they have the switches installed in the ground side of the circuit..  This is generally accepted as being safer than switching a hot leg and is becoming more and more common in todays electrical systems.
RE: I need brake light schematic help. - 9/2/2008 6:30:25 PM
Justin Q.
Psycho  thanks alot for the help and pics. I'm still holding off before doing it that way to further research using another set of relays to reverse it back to a hot lead. I cant wait to get it working and post up pics of my two custom projects.
30" Backs
Aaen exhaust
Custom snorkels
(in reply to breederofkoi)
RE: I need brake light schematic help. - 9/2/2008 6:35:28 PM
Justin Q.
Oh and btw yours looks like a major improvement.
30" Backs
Aaen exhaust
Custom snorkels
RE: I need brake light schematic help. - 9/14/2008 8:11:24 PM
chrisgrizzly660
Justin Q.
did you ever figure it out?
07 CanAm outlander 800 XT,
ITP C7, 27” Swamplites
Full SKidz, Pipe Lift
Gade Pegz
Fully Snorkeled (East Coast)
PT frame mod
Tamarack Box,
Warn 2500 Winch,
Garmin GPS.
HMF, UNI,
Symtec Heated grips.
Whole Bunch of lights on it.
Cumberland ATV riders
[url=www.aurorawheelers.com]Best CAN-AM Site Period[/url]
Windrock ATV Club Index
RE: I need brake light schematic help. - 10/5/2008 7:14:07 PM
psycho ward
ORIGINAL: Justin Q.
Thanks justin, I hope u like yours when finished also. I love mine.
