wylieboy3
I have a 2006 750 Brute Force. I went riding a couple of weeks back, and toward the end of the ride, it started acting like a plug or coil pack was breaking down. It started out backfiring or popping a little, and then it would clear up and run fine. I didn't think that much about it, because it was running too good. I replaced both plugs, and it is still doing it. I thought that maybe I had some trash in the carbs, so I pulled them, and cleaned them out. One had a little bit of mud in the bowl, but the other one was clean. While I was that far in, I adjusted the valves. They were a little loose, but not much. Still, after doing all of that, it is still not right. In one way, it seems like it isn't getting enough gas, but it is getting plenty. One thing I thought wasn't quite right was that it seemed to be blowing some of the gas back up, and not sucking it down the carb. One of the times that we were trying things, the rear exhaust pipe going to the muffler got real red? We then took off the muffler to make sure that it wasn't stopped up, and still no change, just real loud. If anyone has any ideas, I would love to hear them. Thanks in advance...
