How to haul cooler on back rack???
All Forums >> [Most Popular Discussions] >> ATV Accessories >> How to haul cooler on back rack??? Page: [1] 2   next >   >>
How to haul cooler on back rack??? - 7/27/2008 2:20:26 PM
lapoolboy
After a weekend of fighting 3-4 bungee cords and my cooler moving all over my rack, I've decided to research making a more effective cooler holder.
I bought a Kimpex universal cooler/fuel can holder that bolts to the back of the rear rack.  This was a great idea, but it won't fit my back rack and the wheeler won't fit on my trailer with it on.  Sooooo, I'm going to sell that one I guess and make something else.
The only company I have found that makes ANYTHING for this purpose is Savant Mfg. They make an overpriced aluminum contraption that basically looks like a box that u-bolts to the rack.  Sit the cooler in it and run a bungee strap over the top.
I'm thinking about making something similar, but make it out of 3/4" or 1" PVC.  Basically a basket made around the bottom half of my cooler.  I can u-bolt it or ziptie it to my rack and sit the cooler in it.
Has anyone rigged something like this?  If so, pictures would be great!
I originally bought turnbuckles to hold the cooler in place, but I've heard stories of the eyelets on the cooler breaking, handles pulling out, ends of the cooler bulging out, etc. so I have abandoned that idea.
2008 Can-Am Outlander 800 (Viper Red)
RE: How to haul cooler on back rack??? - 7/27/2008 2:26:18 PM
kidsoncoffee
Ratchet Strap.................Never had mine come off and I beat the living **** out of it.
2008 Big Bear 400 4x4
Extreme Products 2" Lift
Custom 2" Snorkel
27" MudZillas
2 Front Apes
DynoJet Jet Kit
UNI Filter
55W Halogen on the Back
More to come......
1999 Yamaha Kodiak 400 4x4
2" Home made bracket lift
1.5" Snorkel
DynoJet Kit
UNI Filter
27" Swamplites on 14" ITPs
(in reply to lapoolboy)
RE: How to haul cooler on back rack??? - 7/27/2008 2:40:03 PM
Jake450s
Personal experince-
Some type of box is a great place to start for gentle or "trail" riding.  Even in a box like Savant's or a home made one, bungees are hardly adequate, but a cambuckle strap would make that work quick and easy.
Now, if you're going into something rough, high speed bumps, jumps, possible (or likely?) tipovers, generally more aggressive riding that is more abusive to your cooler-
I use two plain old K-mart red ratchet straps.  Ones that were retired from ATV tie-down duty due to being poorly stored by leaving them in my truck for most of a year if they are in use or not.  No longer adequate for ATVs, but cut appropriately short and they are perfect for a cooler, and hold it very securely.
I have another means, but I'd say that an aluminum angle from the hardware store u-bolted to your rack on each side will limit side to side motion.  (Flats to the outside for the u-bolts, uprights to the inside, cooler would sit directly on the rack, and it need not be the full length of the cooler, just from one rack bar to the next would be fine).  With one strap hooked to the rack in front of the cooler, the strap routed up and over the cooler, and the remaining one hooked behind the cooler, the hooks are pretty effective at limiting fore and aft motion, as well as of course keeping the lid shut, the contents in, and the cooler planted down firmly.
Ratchets are of course not the easiest, but they don't stretch once they're in place, and they can be set just a shade tighter than a cambuckle.  Once you find the system and hook points that work and do it a couple of times, it's just as quick if not quicker than wrestling several bungee cords over the thing, and sits put very well  So long as you don't actually roll over onto it, you can tip th bike and the lid stays tight enough to keep most of the water and ice in.
RE: How to haul cooler on back rack??? - 7/27/2008 2:57:44 PM
lapoolboy
I like the angle bracket idea.  I can put on on each end and run the bungee up and over to hold it down and keep the lid closed.
I can also take 3/4" rubber heater hose and split it to put over the rack tubes where the cooler will sit.
Hmmmm, you got my thinking wheels turning....
Seems like I'd need to slip something over the angle aluminum to keep it from digging into the side of the plastic cooler.
< Message edited by lapoolboy -- 7/27/2008 3:05:48 PM >
(in reply to Jake450s)
RE: How to haul cooler on back rack??? - 7/27/2008 3:44:40 PM
Black Redneck
since i've got a specific cooler just for ridn. I took a piece of 3/4" conduit, cut the length of the cooler and 2 u bolts and drilled holes in the bottom of the cooler with the conduit on the inside and used the u bolts to attach the whole thing to my rack.  the u bolt holes actually allow water to drip out and act as a drain plug.  A buddy of mine did his like that but put a nut on both the  inside and outside of the cooler and used a strip of rubber bicycle inner tube as a sealant and tightened her down.  Works well for us.  I also went to Academy and bought an igloo latch to put on mine so when I did water wheelies all my adult beverages wouldn't fall out and also so I can reach back while ridn and get a "soda" and latch it back without even stopn.  Sometimes the time betwen rest stops is just too long.
2006 AC 700 EFI
Custom snorks
4 - 27x9x14 Swamp Lites on black SS 108's (trail tires)
4 - 29.5x10x12 Laws on LE wheels (mud tires)
HMF Utility
Optimizer
Outlaw clutch kit
LE Bumpers
Rad Reloc
XPatv 2" lift
Custom Tunes
Eqqis temp and volt gauges
TEAM YO MONEY
"FUN ON YO DIME"
"Keep talkin smack and I'll make ya famous"
RE: How to haul cooler on back rack??? - 7/27/2008 4:45:59 PM
flatout_Grizz
I bolted mine to the rack also works great
(in reply to Black Redneck)
RE: How to haul cooler on back rack??? - 7/27/2008 5:49:29 PM
Jake450s
ORIGINAL: Black Redneck
...the u bolt holes actually allow water to drip out and act as a drain plug.
That's just wrong...  The water keeps the sodees colder than the ice does.
RE: How to haul cooler on back rack??? - 7/27/2008 5:55:01 PM
Jake450s
ORIGINAL: lapoolboy
If you're not sure what I'm talking about, it's in the stand up bins with the threaded rod and the chinsey tin perforated angles.  It's got well rounded and smooth edges, aluminum slides very well anyhow.  You'll have to smooth where you cut it to length of course.
RE: How to haul cooler on back rack??? - 7/27/2008 5:57:39 PM
Black Redneck
Oh trust me, it doesn't drip out that fast.
2006 AC 700 EFI
Custom snorks
HMF Utility
Optimizer
Outlaw clutch kit
LE Bumpers
Rad Reloc
XPatv 2" lift
Custom Tunes
TEAM YO MONEY
"FUN ON YO DIME"
RE: How to haul cooler on back rack??? - 7/27/2008 6:10:10 PM
Voodoo
I just use TIGHT Bungees....it does not move at all....
Voodoo
09 Outty 800R Red
HMF
PCIII
Woods 12:1 High Compression Pistons
RE: How to haul cooler on back rack??? - 7/27/2008 9:41:10 PM
Massmudman
My ammo cans can hold 20 beers and they don't move side to side, real nice fit if you get the 50 cal boxes. Works great in the winter but in summer I have to take less "road sodas" so I can fit some ice in there too.
2006 Black Rubicon
550 BBK w/ Cam Ported & Polished
K&N Oil and Air Filter & Dyno Jet Kit
Rerouted vent lines
HMF Swamp Series
EPI Clutch Kit
HL Lift & Springs
Pull Start Leak Shield
Honda By Moose Skids & A-arm Guards
Dual 3000# Viper Winches / Front and Rear
60" Fisher Plow
Custom Bucket Attachment
27" MST'S on HL XL2'S
HL Hitch lift
50 watt backup lights (bright)(smashed too!)
Dynotuned
(in reply to Voodoo)
RE: How to haul cooler on back rack??? - 7/27/2008 10:15:08 PM
James Chapman
Ummm just use 1 ratchet strap...Wha kind of question is this lol?!?!
Support our Military and their mission
00 Dakota 4wd
BFG A/T's
Cherry Bomb
She's fast . She's real fast.
Past bike 08 brute
(in reply to Massmudman)
RE: How to haul cooler on back rack??? - 7/28/2008 6:31:33 PM
Jake450s
It depends where and how you ride.  Sometimes one is just fine.  I've got one of the bigger Igloo Playmates (with the flip over handlle/lid and the button on the side) and that rides just fine that way with one strap through the handle, but it only holds eight sodas or water and lots of ice, because it's designed for aluminum cans but I typically only take plastic bottles, so it's light.  My bigger cooler that holds about twenty of the same bottles very nicely (little room left for ice) had two older siblings destroyed becasue one strap didn't distribute the bumps over enough area of the plastic.  A good bump and the back of the cooler spread open, the  lid pushed down inside, the hinge broke on the other one in the same fasion...  Two straps to spread the impacts and it's a lot happier if there's any "terrain" involved in the ride.
(in reply to James Chapman)
RE: How to haul cooler on back rack??? - 7/28/2008 8:45:48 PM
05RancherMan
I use one ratchet strap, holds mine down with no problem and I got a big ice chest.
MY Toys
2007 Yellow Rancher 420 4x4ES
26" 589's on Itp Type 7 Wheels
HL Lift Springs
HL Lift
HL 1.5" Wheel Spacers (4)
Custom Snorkle
Warn 2.5 RT winch
Aluminum CV guards
Homemade audiopipe
1997 Yamaha Big Bear 350
Sold: 2005 Rancher 350 4x4 with stuff.
RE: How to haul cooler on back rack??? - 7/28/2008 8:51:20 PM
06Grizzwald
ORIGINAL: lapoolboy
I'm trying to respond to your PMs, but your box is full.
06 Kawaski Brute Force**SOLD**
11:1 Wiseco Pistons
Mudbuster Cams
SuperTrapp Mudslinger
UNI Filter
31's on Black ITP SS 212's
2" XPATV Lift
06 Polaris 700 **SOLD**
3" R-u-b-b-e-r-d-o-w-n Customs Lift
30" Mudzillas on 14" ITP ss 112's
http://community.webshots.com/user/awil24
RE: How to haul cooler on back rack??? - 7/28/2008 11:47:50 PM
MuddyBear
ORIGINAL: kidsoncoffee
Oh ya agree!!!! Never had mine fall off with the strap and I have been through **** and high water!
(in reply to kidsoncoffee)
RE: How to haul cooler on back rack??? - 7/29/2008 7:26:40 AM
southernarrogant
a good ratchet strap hasn't ever come loose in 1500mile of riding!
2005 Suzuki Eiger (manual)
28/9.50/12 Laws all the way around
Epi clutch kit
Dyno jet kit
Carb spring cut
K&N filter
Highlifter 2" lift
HMF Utility exhaust
Snorkel
(in reply to MuddyBear)
RE: How to haul cooler on back rack??? - 7/29/2008 7:41:58 AM
C1iffBurton
i use one strap throw the handels and down to the rack, u pull it tight enough it wont go anywheres...only thing i dont like about this is that you gotta undo the strap to get a beverage out of it which is a pain in the bottom...i have also put a bungee over the top of it to hold the lid down and ran a ratchet strap to each handle on each side of it and that was sufficent cept when i got into water it would want to tip forward and backwards...there are some guys that i have ridden with that got some bolts with a eyelet on one end and then some sort of piece for the other end and they drilled a hole in the side of there cooler and ran the eyelet bolt through it and fastened it down and then somehow put another hook type bolt on the rack side and then the middle piece has one of those twisty type things, i know how it was made and they go through crap and back and it looks like it holds up pretty good to there abuse...but i think u just untwist the middle section on each side of the cooler and unhook it from the rack and empty the water cuz we all use those small white igloo coolers that dont have a drain on them at all
MINE*08 big bear 400, 27" skinny outlaws, CRSbear custom snorkel, Gumbo03 custom lift, oil cooler relocated, fan switch, audiopipe, viper 2500 max
--TEAM ANYTING GOES RACING--
R.I.P. JAYSON MATTHEW PARKER
(in reply to southernarrogant)
RE: How to haul cooler on back rack??? - 7/29/2008 8:32:08 AM
toodeep
i made a holder out of a old atv sprayer frame i had laying around, sit the cooler in and a bungee over the top and is good to go. i attach it to the racks with 2 j bolts and has been through a few wrecks, tip overs, and some hard riding (when the cans are all silver bullets and your not drinking coors )
and if all else fails just get some soft coolers and use a cargo box to hold them
95 TRX300FW 01 TRX500FA
My Pics
Mud Performance
(in reply to C1iffBurton)
RE: How to haul cooler on back rack??? - 7/29/2008 10:15:54 AM
Greg G
Check out my pics, I made a pvc holder for a soft cooler and mounted on my front rack.  It was real good till I had a tip over and it broke.  I think I had about $10 and a couple hours in it.
Greg G
'04 Yamaha Grizzly, HMF, DynoJet, KnN w/ProDesign, Tamarack Box, Yamaha Windshield, custom cooler holder, Hella lights, Warn 2500 & bumper, HL rims 28x12 MSTs, HL springs, 1.5 in lift soon
05 BigBear, RidenRest seat back, mesh rack extension, 27x9,27x11 Titan M/T, ProComp lights, ITP type 6 rims coming soon.
http://s221.photobucket.com/albums/dd94/mpdxtreme/
(in reply to toodeep)
RE: How to haul cooler on back rack??? - 7/29/2008 2:15:45 PM
waterboy_700
Homemade "beer box" with backrest bolted to the rack.
Made out of 1x shelf lumber, rubber coated, and insulated.  Backrest is covered in rubber rug padding we had in the warehouse, and trimmed out the sides with diamond tread aluminum.  It is anchored to the rear rack from the bottom with conduit straps.
TEAM CREEK BOTTOM #13
'07 Rhino 450 - a few "pimpin" goodies
'05 Prarie 700 - BIG ORANGE!
'00 Big Bear 400 - tricked out!
COMING SOON to a pit near you:
'06 650 Brute SRA!
http://myspace.com/waterboy425
http://creekbottomtrailrides.com
http://moremudd.com
(in reply to Greg G)
RE: How to haul cooler on back rack??? - 7/29/2008 2:17:00 PM
waterboy_700
Another shot...
'06 650 Brute SRA!
http://moremudd.com
(in reply to waterboy_700)
Post #: 22
RE: How to haul cooler on back rack??? - 7/29/2008 2:18:04 PM
waterboy_700
Rear view...
'06 650 Brute SRA!
http://moremudd.com
Post #: 23
RE: How to haul cooler on back rack??? - 7/29/2008 2:21:28 PM
Bump530
i made a angle iron frame that fits tightly around the bottom of my ice chest.  then i use some turnbuckles from the loop on the handle to a hook on the frame i built.  the frame is actually built onto my back rest....never comes off..and if u dont have any good loops on the ice chest, just use some eyebolts with a metal plate on front and back...works great.  i also use a bungee longways over the top to keep it form comin open.  and u dont even have to remove the bungee to get ur coke out...LMFAO
Team BS - Bayou Slingers
'08 Brute 750
-31x11 Laws on SS112, 6" Gorilla Lift, Full HMF, HL Springs, Clutch Kit, PCIII, Rad Relocated, Snorkels, HC Pistons
'94 Honda 300 4x4
-27x9.5 Laws, 2" Lift w/ Adjustable Rear Shock, K&N, Snorkel, Clutch Kit, Jet Kit, FO-14
SOLD: 2007 Foreman w/ alot of goodies
Post #: 24
RE: How to haul cooler on back rack??? - 7/29/2008 9:55:43 PM
lapoolboy
Ok, I have my Igloo Marine 25 quart cooler now.  I also have a box full of 3/4" PVC elbows and tees and some PVC glue.  I'm going to make my own custom cooler rack out of 3/4" PVC pipe.  I am going to dye the pipe and fittings black.  I am going to ziptie it to my back rack with beefy 1/2" wide zipties and the cooler will sit right down in it.  I will post pics when I'm done.
Post #: 25
RE: How to haul cooler on back rack??? - 7/31/2008 2:32:30 PM
Mrmojorisan
sometimes it's all in how you strap it.  I used two eyebolts with fender washers for an anchoring point.  Use tight black rubber bungies and it doesn't move... I rode the quad hard and fast like that with no movement
Thumbnail Image
Attachment (1)
'08 Rhino 700 EFI
27" 589's
Aluminum Roof
Stereo
4000lb Viper Max Winch
Light Bar
Skinning / Gutting Lights
Bag Scabbard
Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, wine in the other, body thoroughly used up, totally worn out and screaming... ****, What a ride!!
Post #: 26
RE: How to haul cooler on back rack??? - 7/31/2008 2:49:22 PM
Pizzim
well if you have a dedicated Wheeler cooler just drill holes in it with the spacing for you rack use a thin peice of stainless inside of the cooler with the threads of the bolts on the bottom (outside) of the cooler. Seal up the holes and take another peice of stainlessand bolt it to the bottom of the cooler leaving spacing below those bolts (they need to be about 3") then use another peice of stainless (this time with foam tape) that is bent to fit abround your rack and use a set of bolts ot tighten it down thus holding the cooler tightly to the rack.
At this point a simply bungie should keep the lid closed.
I dont know how it will work for an atv im gona have to try it but it always worked for us with the trucks but we never removed them
(in reply to Mrmojorisan)
Post #: 27
RE: How to haul cooler on back rack??? - 7/31/2008 8:25:12 PM
HoldMyBeer69
That's cool...
2007 Arctic Cat 650 H1
SS112 w/27"Swamplites
AC LE Rims with 28" Laws
Custom Dry Box/MP3 System
EPI Clutch Kit
08 Air Intake(Stopped "Splash Over")
LE Bumpers
Customized Drink Holder
3000 lb Warn
TEAM YO MONEY
"FUN ON YO DIME"
Post #: 28
RE: How to haul cooler on back rack??? - 7/31/2008 9:21:05 PM
1badcatLA
i bought a softpack cooler from academy its camoflage and it has built on straps to strap it to the rack. it holds a 12 pack easy with ice maybe more never tried.
http://www.academy.com/index.php?page=content&target=products/outdoors/hunting/backpacks&start=10&selectedSKU=0374-02207-0005
07 H1
le wheels and bumper
29.5's
speedwerx exhaust
dynojet
dalton clutch kit
rad on top
snorkled
viper mx3000
custom tunes
spring spacers
Hard Pack Arctic Cats
"It All Seems Hard Pack When You Ride A Cat"
(in reply to HoldMyBeer69)
Post #: 29
RE: How to haul cooler on back rack??? - 7/31/2008 9:36:48 PM
jallement1054
