How to Snorkle King Quad W/ Pics
All Forums >> [OEM Discussions] >> Suzuki >> How to Snorkle King Quad W/ Pics Page: [1] 2 3 4 5   next >   >>
How to Snorkle King Quad W/ Pics - 7/20/2007 10:37:02 PM
Solitude
Hey guys, I have seen a ton of posts on how to snorkle a King Quad so I will do a write up so we can make it a sticky. I have snorkle my 06 King Quad but it will work with any year model. Some people may not like how I snorkled mine because of some of the materials I used and the way I sealed it up but I have had it done for almost a year now with no problems what so ever. They are other ways of doing it but this is what I used and how I did mine.
Materials:
1) 1-Box of 2 1/2 Shop Vac Hose
2) 5-90* Street Elbows with no necks on one end, and 1 Hard 90* 2"
3) 3-Male Threaded Connecters
4) 3-Female Threaded Connecters
5) 1-Section of 2" PVC (White or Black)
6) 2-Rolls of High Temp Duct Tape
7) 2-Rolls of Electrical Tape
8) 1-Tube of Black SiliconeII
9) Bag of Zip Ties and some Clamps
10) Some Screws to hold hose in PVC
11) 2 1/2 Cut out for the fenders
Steps for Belt Intake:
1) Ok first I took off the stock snorkle and engine covers.
2) Then I used the 3" end that comes in the Shop Vac hose and put the hose inside that.
3) Then used a screw to hold the hose inside the 3" end and used electrical tape to completly seal and block of the hose from the 3" end to about 5" up the Shop Vac Hose.
3) Then I put the High Temp Duck Tape over that about half way up the hose going to the right fender.
5) I then measured out how long I would need it to be from the bottom to the fender and then cut
6) After that I placed the Shop Vac Hose in one of the Female connecters and screwd and then taped it off to seal.
7) Cut a hole in fender with your cut out.
8) Cut out how long you want your snorkle with your section of 2" PVC and then use PVC Glue to hold it to the Male Connecter and one of your 90* Angles and then screw in and your done.
How to Snorkle Belt Exhuast:
1) Take off stock snorkle and rear tires.
2)Get 2 of your 90* street bends and 1 hard 2" 90* Glue your two street 90* together to make a half moon and then glue your hard 90* to the end with no neck to make a question mark looking configuration.
3) Then stick the Shop Vac hose into the other end of the street 90* and screw and tape off with the electrical tape and then 3 or 4 wraps of the 4) High Temp Duck Tape, all the way and make it about as long as the length of the KQ.
5) Then you will need to add alot of the High Temp Silicone to the outer edge of the hard 90* and stick it inside of your belt cover and then clamp down and wait till it drys (this is the part that alot of people dont like, but it works)
6) Feed the shop vac hose either on top or bottom of your drivetrain ( what I did here was take off my gas tank and drill two holes and then zip tied the hose up against the tank cover to keep it up and away from the drivetrain) and then run it on the left side of your machine right below the engine but right on the skid plate sandwiching it in with your floorboards.
7) Then measure out how long you will need and then stick the Hose into another Female connecter and screw and tape off.
8) Then follow #8 on the Belt intake and your done with the belt exhuast.
How to Snorkle the Air Intake:
1) Take Air Box off
2) Take top of the covering over where the air gets in, just easier to work with.
3) Find a peice of hard plat plastic big enough to cover the whole after you take out the rubber thing pointing down.
4) Place plastic over the whole and silicone tight.
5) Then say if your sitting on the bike you will need to cut a hole in the right side front of the airbox ( not the side top or bottom)
6) Then another peice will come in the Shop Vac Hose that fits perfect into the hole and more of the Hose fits into that to run to the fender.
7) You will need to screw and tape up that end and use the silicone to seal up the peice that goes into your airbox and your done with that part
8) Follow #8 on how to snorkle a belt intake and your done.
Thats all there is to it after painting and extending your vent lines and dielectric grease all your connections and spark plug. Like I said some people might not like the way I did it but it works. Please let me know if you need any help and I will also get better pics tommorrow. Thanks. Hope it helps.
Thumbnail Image
Attachment (1)
< Message edited by engie -- 1/16/2008 9:36:29 PM >
06' SLC Lifted King Quad 700 EFI For Sale: http://easttexas.craigslist.org/mcy/960791955.html
94' Honda 300 4x4
EDL's, ITP Black 212's, Lift, Progressive 512 Shocks, DJ Kit, K&N w/ Outerwears, Savant Floorboards, Gear Reduction, EPI Clutch Kit, XP Disk Brakes, Snorkles, Gutted Exhuast, Pro Grips
RE: How to Snorkle a King Quad W/ Pics - 7/20/2007 10:39:10 PM
Solitude
Belt Exhuast from the clutch cover on.
Thumbnail Image
Attachment (1)
94' Honda 300 4x4
(in reply to Solitude)
RE: How to Snorkle a King Quad W/ Pics - 7/20/2007 10:40:10 PM
Solitude
Over the Drivetrain
Thumbnail Image
Attachment (1)
94' Honda 300 4x4
RE: How to Snorkle a King Quad W/ Pics - 7/20/2007 10:41:41 PM
Solitude
Along the engine and floorboards.. and NO I have not had any problems with it leaking or puncturing.
Thumbnail Image
Attachment (1)
94' Honda 300 4x4
RE: How to Snorkle a King Quad W/ Pics - 7/20/2007 10:43:17 PM
Solitude
Heading up to fender.
Thumbnail Image
Attachment (1)
94' Honda 300 4x4
RE: How to Snorkle a King Quad W/ Pics - 7/20/2007 10:45:43 PM
Solitude
Belt Intake up to fender.
Thumbnail Image
Attachment (1)
94' Honda 300 4x4
RE: How to Snorkle a King Quad W/ Pics - 7/20/2007 10:46:50 PM
Solitude
Belt Intake
Thumbnail Image
Attachment (1)
94' Honda 300 4x4
RE: How to Snorkle a King Quad W/ Pics - 7/20/2007 10:48:39 PM
Solitude
New Airbox hole and intake snorkle.
Thumbnail Image
Attachment (1)
94' Honda 300 4x4
RE: How to Snorkle a King Quad W/ Pics - 7/20/2007 10:49:56 PM
Solitude
New hole into airbox so you see where it goes. I think that this is the best place to put a intake snorkle cause its a straight shop to the front fender.
Thumbnail Image
Attachment (1)
94' Honda 300 4x4
RE: How to Snorkle a King Quad W/ Pics - 7/20/2007 11:23:32 PM
Lets keep this post to snorkeling Suzuki quads,pic and advice ..
08 650H1 LE
Warn 3.0
Snorkeled,Rad racked
Custom gauges
muffler tweaked
Dyna Tech CDI
Custom clutch kit
4.0 gears
HL springs, HL spacers
Gorilla axles
29.5 Laws, custom LE wheels
30" MLs, Black Castle Roks
05 500m
Hidden Snorkel
muffler tweaked
HL temp gauge
26" 589MTs, ITP type 6s
H.ard P.ack A.rctic C.ats
RE: How to Snorkle a King Quad W/ Pics - 7/22/2007 10:51:42 AM
BIGandUGLY
Heres my rear manifold.
Thumbnail Image
Attachment (1)
07 King 700
EPI big tire clutch kit w/ wet springs
SS 108 wheels
27" Mudlite XTR's
2500lb winch
2mm primary shim mod
Homemade snorkel
XPATV 3" lift
TEAM XXL Bog Member
www.TEAMXXL.com
(in reply to GWC)
RE: How to Snorkle a King Quad W/ Pics - 7/22/2007 10:53:45 AM
BIGandUGLY
hose to the front.
Thumbnail Image
Attachment (1)
< Message edited by BIGandUGLY -- 7/22/2007 10:54:50 AM >
07 King 700
SS 108 wheels
27" Mudlite XTR's
2500lb winch
Homemade snorkel
XPATV 3" lift
TEAM XXL Bog Member
www.TEAMXXL.com
(in reply to BIGandUGLY)
RE: How to Snorkle a King Quad W/ Pics - 7/22/2007 10:57:32 AM
BIGandUGLY
Route to fender.
Thumbnail Image
Attachment (1)
07 King 700
SS 108 wheels
27" Mudlite XTR's
2500lb winch
Homemade snorkel
XPATV 3" lift
TEAM XXL Bog Member
www.TEAMXXL.com
RE: How to Snorkle a King Quad W/ Pics - 7/22/2007 11:01:58 AM
BIGandUGLY
This is the way I did the top fittings so I could adjust the lengths of the inlet and exhaust. Short for trails and long for subbing.
Thumbnail Image
Attachment (1)
07 King 700
SS 108 wheels
27" Mudlite XTR's
2500lb winch
Homemade snorkel
XPATV 3" lift
TEAM XXL Bog Member
www.TEAMXXL.com
RE: How to Snorkle a King Quad W/ Pics - 7/22/2007 11:06:06 AM
BIGandUGLY
I did my front in pvc because I liked the idea of a one piece manifold. This is before the mudflap.
Thumbnail Image
Attachment (1)
07 King 700
SS 108 wheels
27" Mudlite XTR's
2500lb winch
Homemade snorkel
XPATV 3" lift
TEAM XXL Bog Member
www.TEAMXXL.com
RE: How to Snorkle a King Quad W/ Pics - 7/22/2007 11:08:19 AM
BIGandUGLY
Here it is thru the plastic.
Thumbnail Image
Attachment (1)
07 King 700
SS 108 wheels
27" Mudlite XTR's
2500lb winch
Homemade snorkel
XPATV 3" lift
TEAM XXL Bog Member
www.TEAMXXL.com
RE: How to Snorkle a King Quad W/ Pics - 7/22/2007 11:11:47 AM
BIGandUGLY
Here the mudflap is trimmed to go around the inlet and installed like factory.
Thumbnail Image
Attachment (1)
07 King 700
SS 108 wheels
27" Mudlite XTR's
2500lb winch
Homemade snorkel
XPATV 3" lift
TEAM XXL Bog Member
www.TEAMXXL.com
RE: How to Snorkle a King Quad W/ Pics - 7/22/2007 11:20:03 AM
BIGandUGLY
I used 1 1/2 inch pvc for my snorkel and rode yesterday for 4 hrs without a over heating problem. I used drain pipe with a slip joint so I could change the heigth as needed because the tall tubes get annoying on the trail to me.Total cost $84.00.   Heres a pic of the completed King.
Thumbnail Image
Attachment (1)
07 King 700
SS 108 wheels
27" Mudlite XTR's
2500lb winch
Homemade snorkel
XPATV 3" lift
TEAM XXL Bog Member
www.TEAMXXL.com
RE: How to Snorkle a King Quad AND Relocate the Radiator - 7/31/2007 6:59:08 AM
Big House
One question with the intake snorkel. I haven't really looked at the whole airbox but my question is how do you seal the top of the airbox and still maintain access to your filter.
2005 Suzuki KingQuad 700
26 inch Bighorns on ITP C4 wheels (for the trail)
28 inch Outlaws on MA Tork Black wheels (for the mud)
VDI!!! Snorkels Twinair air filter
3 inch xpatv lift: Yoshi Pipe
http://community.webshots.com/user/bighouse35
RE: How to Snorkle a King Quad AND Relocate the Radiator - 7/31/2007 6:08:51 PM
Solitude
 I use Marine Grease all around the seal. Never been that deep to try it cause I still havent built up the trust in it to test it out.
94' Honda 300 4x4
(in reply to Big House)
RE: How to Snorkle a King Quad AND Relocate the Radiator - 8/1/2007 3:10:19 PM
Big House
Maybe silicone gasket maker will work, also which would work better for airflow, 1 2 inch intake tube or 2 1.5 inch tubes.
RE: How to Snorkle a King Quad AND Relocate the Radiator - 8/9/2007 8:20:50 PM
tx700king
i had the guys in the pipe shop at work make me a custom gasket for mine ill get some specs on it. umm id say go with the 2 1.5's this bike only runs better with more air i used 2 1/2 to 3" on mine and worked great with 2 inch my bike kinda ran allitle hot and bogged down on take off. but i bought a new air box and the factory inlet sits so high anyhow i just took the snorkel back off. it will go fender deep with out the snorkel just got to watch the splashing the air box inlet sits right under the front seat good design
waiting to get cash for the new toy
06 kingquad 700 sold
06 foreman es for sale
Post #: 22
RE: How to Snorkle a King Quad AND Relocate the Radiator - 9/17/2007 9:24:52 PM
skipKQ
Did anyone have to get there air fuel re mapped or anything or its good to go? i want to get a programer anyways but jw about that b4 i snorkel...that belt exshust will suck in some water and that sucks
Post #: 23
RE: How to Snorkle a King Quad AND Relocate the Radiator - 9/18/2007 6:29:21 AM
Solitude
With the 2 1/2 Vaccum Hose that I used on the air intake was perfect. I put it in the stock air intake location and it was about the same size diameter, but just a little smaller, but I think it made it up since its a straight shot into the airbox with the new location.
94' Honda 300 4x4
(in reply to skipKQ)
Post #: 24
RE: How to Snorkle a King Quad AND Relocate the Radiator - 9/20/2007 3:22:20 PM
MudKing02
How different is the kingquad from the Vinson? Oh I have the manual so no belt drives to snorkel.
07 Vinson Manual 2" HL lift, Gators on Douglas Rattlesnakes, snorkel, jets, K&N, Warn RT 2500, carb slide mod
Post #: 25
RE: How to Snorkle a King Quad AND Relocate the Radiator - 9/20/2007 3:29:57 PM
Solitude
Very Different. Nothing the same. The Vinson Airbox is under the seat unlike the King with the Airbox where the gas tank normally is. Also there is a rubber couple already where the stock snorkle goes to where you can connect a 1.5 snorkle to there and run it up the front. Easy IMO.
94' Honda 300 4x4
(in reply to MudKing02)
Post #: 26
RE: How to Snorkle a King Quad AND Relocate the Radiator - 10/23/2007 4:47:51 PM
Solitude
Im about to redo all my snorkles, and I may do another write up on some updating that I have done to them.
94' Honda 300 4x4
Post #: 27
RE: How to Snorkle a King Quad AND Relocate the Radiator - 10/23/2007 4:58:14 PM
MudKing02
I can add directions to snorkel the Vinson now too.
Post #: 28
