How to Relocate Radiator on KQ W/ Pics
All Forums >> [OEM Discussions] >> Suzuki >> How to Relocate Radiator on KQ W/ Pics Page: [1] 2   next >   >>
How to Relocate Radiator on KQ W/ Pics - 7/23/2007 9:47:48 AM
Solitude
Ok some people asked how to relocate a radiator on a King Quad, well I did mine and it was very very easy. Only took about a hour to do it. I used what looks like 1.2 inch wide alluminum bar that I had laying around the house, but you can use something stronger if you want but this works also.
How to remove Radiator:
Take off belly skid plate.
On the side where your oil filter is, towards the front on the bottom left hand side you will see a 10MM bolt (This is were the antifreeze comes out) and drain that, while draining take off radiator cap (of course dont do it while its hot)
Undo temp sensor at the top back of the radiator
Undo clamps to the hoses on top and bottom
Then the fan will have a wire coming from it, follow that and disconnect.
Then there will be two 10MM bolts holding the radiator on, undo those and pull the radiator out.
Bracket:
What I did was cut the bar in have, then layed it out on my rack. There is two bars heading up and down your your King and the radiator is about that wide, so where the alluminum crossed the rack bar I bent it up to the angle I wanted the radiator. The I just cut the alluminum bar past the rack bar and bolted it down. Then for the nipple that the radiator sits on, I still used the alluminum bar and cut a hole in the end and bent that end up to about 23* and then that nipple will sit in that and the other end of the bar will be U-Bolted to the rack bar.
Finishing up:
Once everything is secure run your new hoses from engine to the radiator, the top hose goes to the top of radiator and bottom hose goes to bottom of radiator. You will need to extend the wire you disconnected at the top of the radiator. The fan wire will be long enough. Also I took off that expanded metal looking plastic peice and ran all my hoses and wire up through there. Then just screw back in the drain bolt and start burping the radiator.
Of course there is other ways to do this but this is how I did mine and once again it works.
Thumbnail Image
Attachment (1)
07 Yamaha Yellow Rhino 660 SE - 2" Lift with 27" Zillas on Chrome 112's
06 Suzuki King Quad 700 EFI - 8" SLC Lift with 29.5x10 Outlaws on Black Torks
04 Honda Rubicon 500 GPS
02 Yamaha Grizzly 660 SE - 26" Mudlites on ITP SS 212's
94 Honda 300 - 2" Lift with 27x9.5 Outlaws on Black ITP SS 212's
RE: How to Relocate Radiator on KQ W/ Pics - 7/23/2007 9:49:45 AM
Solitude
Pics
Thumbnail Image
Attachment (1)
(in reply to Solitude)
RE: How to Relocate Radiator on KQ W/ Pics - 7/23/2007 9:50:47 AM
Solitude
Another
Thumbnail Image
Attachment (1)
RE: How to Relocate Radiator on KQ W/ Pics - 7/23/2007 9:52:01 AM
Solitude
2 More
Thumbnail Image
Attachment (1)
RE: How to Relocate Radiator on KQ W/ Pics - 7/23/2007 9:53:21 AM
Solitude
Last One
Thumbnail Image
Attachment (1)
RE: How to Relocate Radiator on KQ W/ Pics - 2/7/2008 5:48:15 PM
full mod. king quad
Heres another way to do it.......
2001 Yamaha Kodiak
2005 King Quad GREEN
http://www.us-atv.com/
RE: How to Relocate Radiator on KQ W/ Pics - 2/7/2008 5:52:14 PM
full mod. king quad
This was before i washed it....And the reason why i wanted to do the relocate.
2001 Yamaha Kodiak
(in reply to full mod. king quad)
RE: How to Relocate Radiator on KQ W/ Pics - 2/7/2008 5:55:06 PM
full mod. king quad
This is about 2 hours later and about a half gallon of aluminum acid.
2001 Yamaha Kodiak
RE: How to Relocate Radiator on KQ W/ Pics - 2/7/2008 5:57:29 PM
full mod. king quad
I had to cut all the center bars off to get it a low as possible.
2001 Yamaha Kodiak
RE: How to Relocate Radiator on KQ W/ Pics - 2/7/2008 6:01:13 PM
full mod. king quad
Drilled holes for the hoses........I tried to use the factory vent hole but the radiuator was to close to the body panel.
2001 Yamaha Kodiak
RE: How to Relocate Radiator on KQ W/ Pics - 2/7/2008 6:04:00 PM
full mod. king quad
Finished product.....Low enough to still use my third light
2001 Yamaha Kodiak
RE: How to Relocate Radiator on KQ W/ Pics - 2/7/2008 6:05:28 PM
full mod. king quad
A little closer.
2001 Yamaha Kodiak
RE: How to Relocate Radiator on KQ W/ Pics - 2/7/2008 6:16:22 PM
full mod. king quad
Oh, BTW, i only had to make one bracket, the one in the front (was the bottom) of the radiator, the bracket started out as a grinder wrench, i just enlarged the hole so the factory rubber bushing would fit and then i just bent a 80 degree angle and cut it to fit then welded it to the rack. On the top side i just carefully bent the tabs that were already on the radiator so they would fit right into the holes that were already drilled in the front rack. I didn't have to extend any of the wiring, i did have to take the factory zip ties of of the wires to give them enough slack to reach, i put the overflow bottle on the frame close enough to reuse the tubing on it.
2001 Yamaha Kodiak
RE: How to Relocate Radiator on KQ W/ Pics - 2/7/2008 6:26:47 PM
king_quadder
What about the fan? Are you going to mount it under the rad and have it push back throught he rad? Very clean install, nice job!
HL Forum moderator
Waiting for my next new toy!
RE: How to Relocate Radiator on KQ W/ Pics - 2/7/2008 6:45:23 PM
full mod. king quad
Yeah, it's a tight fit but the fan is under there........Thanks for the feedback!
2001 Yamaha Kodiak
(in reply to king_quadder)
RE: How to Relocate Radiator on KQ W/ Pics - 2/7/2008 6:47:08 PM
Solitude
Yea man that looks really good. Those factory tabs scared me when I saw that because its very easy to seperate the sides of it if there any pressure pulling against it. So everything on that set up is pretty permanate huh? Looks good.
RE: How to Relocate Radiator on KQ W/ Pics - 2/7/2008 6:54:49 PM
full mod. king quad
Oh yeah, it's permanent, I mean i could easily weld the cross tubes back in but as for the holes, well thats another story.
I was sure to be careful with the tabs and the rack actually added strenth to the radiator.
Thanks for the feedback....I really like how it turned out.
2001 Yamaha Kodiak
RE: How to Relocate Radiator on KQ W/ Pics - 2/10/2008 8:11:11 PM
Buzsaw
I did one this weekend I have to get pic's
RE: How to Relocate Radiator on KQ W/ Pics - 2/10/2008 10:01:26 PM
Freestyle
Please get some pics we would like to see them!
08 750 King Quad
3" Xtreme Lift
30X9 Sliverback's
Vision Buckshot Wheels
Twin Air Filter
Full Custom Snorkle
Crankcase mod with Filter
Sealed Pull Start
Greased Shifter
Sealed display
Took spark arrester out
Warn XT 25 rope winch
"Team Scuba"
www.myspace.com/thefreemans620
(in reply to Buzsaw)
RE: How to Relocate Radiator on KQ W/ Pics - 2/11/2008 6:01:12 PM
full mod. king quad
I LOVE IT !!!! It worked like a charm!!!!
2001 Yamaha Kodiak
(in reply to Freestyle)
RE: How to Relocate Radiator on KQ W/ Pics - 2/11/2008 6:02:24 PM
full mod. king quad
2001 Yamaha Kodiak
RE: How to Relocate Radiator on KQ W/ Pics - 2/19/2008 8:27:58 PM
one bad prairie650
How hard is it to fill it up with it laying down like that?
02 prairie 650 HL liftkit,HL liftsprings,moose power mod,29.5's relocated radiator,andHL clutch kit,snorkels,HMF utility exhaust,jet kit,K&N air filter
Post #: 22
RE: How to Relocate Radiator on KQ W/ Pics - 2/19/2008 8:47:30 PM
99dodgeram
I'm not real sure but i think you would fill it up before you mounted it
2007 Kingquad 700
HMF Swamp Series exhaust
EPI clutch kit
3" lift
ITP SS108 wheels
28" mudzillas
Chrome shifter knob
Audio Pipe
01 warrior : for sale
2006 Dodge 2500 CTD
Project truck
1999 dodge 1500
10" lift on 37's
Coming soon: 1 ton's, more lift and 40"+ tires
http://s6.photobucket.com/albums/y207/jaswilson19/
(in reply to one bad prairie650)
Post #: 23
RE: How to Relocate Radiator on KQ W/ Pics - 2/19/2008 9:46:54 PM
full mod. king quad
ORIGINAL: one bad prairie650
That is a very good question, how i did it is i found a really steep hill (like a ditch) and nose the quad almost straight down and then you have to turn the handlebars all the way, then you have to bend a funnel so it will fit between your pod and your radiator. It was a pain but i don't have any leaks so i wont have to do it often. That was the only way i could get all the air "burped" out of the system. I do all my adding to my overflow bottle mounted below the radiator.
2001 Yamaha Kodiak
Post #: 24
RE: How to Relocate Radiator on KQ W/ Pics - 2/20/2008 5:57:48 PM
dentman29
Those are sweet installs. Gonna try and do my Vinson this weekend, but I want to angle it like solitudes so I can Re-do my snorkels in the middle.
04 VINSON LIMITED
29.5 LAWS
H/L 2" LIFT
GO-RI-LI-LI-LI-LA AXLES
ITP TYPE 5 C- SERIES WHEELS
SNORKEL KIT
EBC BRAKES
CLEAR LED TAILLIGHT
CUSTOM RADIATOR RELOCATION
HMF EXHAUST
DYNOJET KIT
UNI FILTERS
....ORDERED....
EPI CLUTCH KIT
.......AND THE LIST KEEPS GROWING!!
Post #: 25
RE: How to Relocate Radiator on KQ W/ Pics - 2/20/2008 6:31:17 PM
full mod. king quad
Be sure to take plenty of pics, i'd like to see it.
2001 Yamaha Kodiak
(in reply to dentman29)
Post #: 26
RE: How to Relocate Radiator on KQ W/ Pics - 2/20/2008 9:37:11 PM
Solitude
Thats what I like about mine, I can move it to the middle if I want like in this pic.
Thumbnail Image
Attachment (1)
Post #: 27
RE: How to Relocate Radiator on KQ W/ Pics - 2/21/2008 7:17:53 PM
dentman29
Yep that's what i've got planned...Will get some pics up when done. If my camera is fixed
04 VINSON LIMITED
29.5 LAWS
H/L 2" LIFT
SNORKEL KIT
EBC BRAKES
CLEAR LED TAILLIGHT
HMF EXHAUST
DYNOJET KIT
UNI FILTERS
....ORDERED....
EPI CLUTCH KIT
Post #: 28
RE: How to Relocate Radiator on KQ W/ Pics - 4/16/2008 10:00:55 PM
full mod. king quad
Update on my radiator re-locate, since i cut all of my cross tubes out of my front rack it made it somewhat weak, i had to add a bracket below the plastic to add strength to the rack, the bracket is simple and it's not necessary unless you cut all the tubes out. You really don't need to cut all the tubes out of the rack unless you wan't the radiator to be low enough to get the most use out of your third headlight. If anyone needs me to take pics of the bracket just post in this thread or PM me and i'll snap some.
Andy
2001 Yamaha Kodiak
Post #: 29
RE: How to Relocate Radiator on KQ W/ Pics - 4/17/2008 9:03:09 PM
4man0822
ORIGINAL: king_quadder
      Andy does some very nice looking work, I like use of the third light myself & will prolly go this route, when not if I do this!  Dam that peer pressure is a mutha!  Yall are gonna make me a pure mudder yet! Ha! Ha! You guys & the folks I ride with regularly!  Later & nice job again Andy....Brandon
4 a single, she hauls!!
filter, 27" Swamp Fox Plus, ATV Audiopipe, with the Bazookas(I love this thing)& **** 2500XT W/syn rope 05 500 Foreman 26"589 M+S 0n black C-4's, HMF Utility series, with jet, & UNI filter, boot guards& kimpex b
Post #: 30
