How do you guy's like your dif lock finger trigger thing?
All Forums >> [OEM Discussions] >> Kawasaki >> How do you guy's like your dif lock finger trigger thing? Page: [1]
How do you guy's like your dif lock finger trigger thing? - 11/25/2008 3:52:14 PM
UGAfan
I am leaning towards buying a BF650i I  was wandering how good  the locker is? I have had 3 AC's and they have a lever you flip to lock the front end. I really enjoyed this set up because you could lock it and climb all over the bike to keep the tires down. I have gotten unstuck buy climbing onto the front rack while holding on to the handle bars facing backwards or with on hand on the throttle side of the bars and both feet on the right foot peg. So how easy is the BF locker? do ya"ll like it in techical ridding?   Thanks for the feed back.
RE: How do you guy's like your dif lock finger trigger ... - 11/25/2008 3:58:09 PM
redGrizz
It doesn't "LOCK" w/o the "pen-lock" that is aftermaket and holds the yellow lever in place to ensure maximum engagement at all times in 4wd
Team N2Deep
07 Grizz 660
28x9.5 Laws
Chrome ss212's
"C"ustom-Locks!
HL Triple Flow Radiator
HL Temp Gauge
HL 2" lift
HL Lift Springs
Gorilla Axles
Bayou Snorkels
More to come!
(in reply to UGAfan)
RE: How do you guy's like your dif lock finger trigger ... - 11/25/2008 4:16:28 PM
UGAfan
Holly cow! what an easy fix. Thanks for the help. Why isn"t kawi installing these at the factory?
(in reply to redGrizz)
RE: How do you guy's like your dif lock finger trigger ... - 11/25/2008 5:33:34 PM
jd2210
A lot of guys have and like the pen lock. I don't and love the lever for what I do. I like to know exactly how much i'm locking it up and then unlocking when I'm turning and so on. Different strokes for different folks. I can go a lot of places my can-am buddy can't simply because his has to tun so many times before the front lock up. I like knowing it will be 4wd when I tell it to be.
2007 Brute Force 650i
SS112 Rims with 4 28x12x12 Swamp Witches
High Lifter Outlaw Super Duty Extreme Clutch Maroon Primary Yellow Secondary
MIMB Snorkel
2500 lb Warn
1985 Honda Big Red 250
Beat
My Pictures and Videos
RE: How do you guy's like your dif lock finger trigger ... - 11/25/2008 6:12:42 PM
swamp bomb
i agree. i like the lever on the brute vs can am visco lock diff. its alot  nicer for the slow techniqual parts of the trail.
08 FCP BRUTE 750 "O.C"
30X10 MUDLITE XXL
08 CAN-AM RENEGADE 500
28x10 S!LVERBACKS
VID
RE: How do you guy's like your dif lock finger trigger ... - 11/25/2008 6:40:57 PM
ALMOST30S
I have the penn lock and have maybe only used it once.The lever maybe 5 times
Team MUD PIMPZ!
THIS BIKE IS FOR SALE!!! YOU KNOW YOU WANT IT!!!7900 0B0
1984 yamaha breeze brute force 500
lift-f150 torsion keys up front and 2inch blocks in the rear
SCUBA GEAR
30x12x15 big horns
flowmaster exhaust
cookie cutter cdi
APC headlights
Transmission work
RIMs-u wont believe it!ROUND ONES!how crazy is that?
Peg leg limited slip 4wd lock
smitty built brushguard
Flux capacitor motor puttin out 19 rwhp!
THIS BIKE IS FOR SALE!!YOU KNOW YOU WANT IT!
(in reply to swamp bomb)
RE: How do you guy's like your dif lock finger trigger ... - 11/25/2008 6:45:34 PM
superbogger750
ORIGINAL: ALMOST30S
Im with you i dont even know if mine works.
06 ORANGE FCP BF750
08 Kawasaki Teryx
Team MudATV/GORILLA AXLE powered by Flynt's Customs Performance
Betsill #77
08 WINS
2nd Place Pro A Firecracker Bash
3rd Place Open Class Mudacross Southern Ridge
1st Place 700 up Southern Ridge
1st Place 700 up Mudders Mag Mud Run
2nd Place Pro A Tenn. Mudfest PSR
(in reply to ALMOST30S)
RE: How do you guy's like your dif lock finger trigger ... - 11/25/2008 6:50:34 PM
phreebsd
i'll be getting a penlock.
i use the locker when crawling this rock pile at the creek to get into the tunnel.
2008 Kawasaki Brute Force 750
Outlaws - 27x9.5 F, 27x12 R
1" Spacers
HL 2" Lift
Lime Green Secondary
M.I.M.B Snorkles
Viper Max 4000 with Amsteel Blue synthetic
2007 Kawasaki Prairie 360
Mudbugs - 26x10 F, 26x12 R
Twin Air filter
Viper 3000lb winch
Visit the NEW! MudInMyBlood Forum
TEAM ROLLIN' DEEP 2009
RE: How do you guy's like your dif lock finger trigger ... - 11/25/2008 7:40:11 PM
UGAfan
OK what ya'll are saying makes sence I can see why you would want to slip it a little while turning. Also I bet if you have big tires you will break less axels with the lever.
New question, If you get the pen lock can you pull the lever in without totaly locking it? - do you pull in the lever and then push down the button and it stays in.
RE: How do you guy's like your dif lock finger trigger ... - 11/25/2008 7:56:58 PM
phreebsd
yep u gotta push the pin down once you pull it in.
squeeze it again and the pin pops up and it's unlocked.
1" Spacers
HL 2" Lift
M.I.M.B Snorkles
Twin Air filter
Viper 3000lb winch
RE: How do you guy's like your dif lock finger trigger ... - 11/25/2008 9:10:06 PM
CDNBrute750
Had one installed on my brute 750, fantastic, you know when it's locked and unlocked and it's not another electric actuator to fry, quick simple and cheap, period
RE: How do you guy's like your dif lock finger trigger ... - 11/25/2008 9:34:35 PM
ALMOST30S
ORIGINAL: superbogger750
ORIGINAL: ALMOST30S
Me either lol. . .I try to not ever use the diff lock because to me thats asking for trouble. . .31x11s on the front that was designed to turn what 25x9 all terrains?The way i see it is if you have it in 4wd and not diff locked that will let the front end slip if one of your tires catches a root or something like that.If you have the diff locked all that torque has to go somewhere aand im guessing either an axle or a blown front diff.So thats why i never use the pinn lock. .. .plus i havent needed to.Im not one to just pin the throttle in mud holes,i just let the tires do the work,thats what they were designed to do.but again thats just my opinion. .prolly not worth but a couple cents
Team MUD PIMPZ!
SCUBA GEAR
30x12x15 big horns
flowmaster exhaust
cookie cutter cdi
APC headlights
Transmission work
(in reply to superbogger750)
RE: How do you guy's like your dif lock finger trigger ... - 11/25/2008 9:38:17 PM
phreebsd
Good info. I'll give you 4 cents :)
1" Spacers
HL 2" Lift
M.I.M.B Snorkles
Twin Air filter
Viper 3000lb winch
RE: How do you guy's like your dif lock finger trigger ... - 11/25/2008 9:38:20 PM
superbogger750
ORIGINAL: ALMOST30S
ORIGINAL: ALMOST30S
Yep thats why alot of people are busting front diff's.
06 ORANGE FCP BF750
08 Kawasaki Teryx
Betsill #77
08 WINS
RE: How do you guy's like your dif lock finger trigger ... - 11/27/2008 8:03:43 PM
DrillersGoDeeper
USED MINE MAYBE TWICE!!  REALLY NO NEED SO FAR.
2008 BRUTE FORCE 750i  (FOR MUDDIN')
OUTLAWS 31X9X14 FRONT
OUTLAWS 31X11X14 REAR
14" "BLACK CHROME" MSA TROOPER WHEELS
2" X-TREME LIFT
HMF PENLAND SERIES EXHAUST
GORILLA RADIATOR RELOCATED
HIGHLIFTER TEMPERATURE GUAGE (FLUSH MOUNTED)
HIGHLIFTER OUTLAW SUPER DUTY CLUTCH KIT BY EPI
2006 BRUTE FORCE 750i  (FOR HUNTIN')
MOOSE POWER MODULE
HIGHLIFTER 2" LIFT
1" HL SPACERS ALL AROUND
STICK STOPPERS ALL AROUND
WARN 3000 LB. WINCH
RE: How do you guy's like your dif lock finger trigger ... - 11/27/2008 9:59:44 PM
ALMOST30S
ORIGINAL: phreebsd
BBBAALLLLINNNNN.. .lol
Team MUD PIMPZ!
SCUBA GEAR
30x12x15 big horns
flowmaster exhaust
cookie cutter cdi
APC headlights
Transmission work
(in reply to phreebsd)
RE: How do you guy's like your dif lock finger trigger ... - 11/27/2008 10:55:14 PM
phreebsd
ORIGINAL: ALMOST30S
ORIGINAL: phreebsd
that's how i roll son.. ROLLIN DEEP!!
1" Spacers
HL 2" Lift
M.I.M.B Snorkles
Twin Air filter
Viper 3000lb winch
RE: How do you guy's like your dif lock finger trigger ... - 11/28/2008 7:24:47 AM
jakedogg
I don't use mine at all.....
Brute Force 650 (SRA)
27" Laws on MSA Torks
28" Gators
Fully Snorkeled
Relocated Radiator
Dyna CDI
2" Lift
EPI Lime Green Secondary
Custom Skids & Bumper
Water Temp Gauge
Big Gun Exhaust
RE: How do you guy's like your dif lock finger trigger ... - 11/28/2008 7:37:04 AM
bushhog750
another reason people are busting front diffs is getting stuck in 2wd then just flipping the switch into 4wd and giving it he'll when the front end locks in it has to go somewhere. i think doing this is worse than using the diff lock.
08 outlander 800 XT red- MaD Cannon tuned- center snorkled- vented- itp ss212's black- 29.5" outlaws- power commander- hmf pipe- uni filter- pipe lift- gorilla radiator relocate- ricochet skid plates- coolanol radiator fluid- crankcase vent mod- amsoil fluids- spider grips- sponsored by VISA and 60 hours a week.
(in reply to jakedogg)
RE: How do you guy's like your dif lock finger trigger ... - 11/28/2008 11:50:44 AM
ALMOST30S
ORIGINAL: bushhog750
yeah thats true to. .if i get stuck in 2wd ill flip the switch and just barly bump the gas until i feel the front wheels lock in then ill give it a little more gas as needed.I cant tell you how many times i have seen somebody do what you said...get stuck in 2wd.flip the switch and floor it and BANG! the front locks in and sounds like a gun went off in the diff or it really did explode in there lol.I guess when people just dont know. . .they just dont know. .hopefully at least one person will learn from this thread and save them alot of money
Team MUD PIMPZ!
SCUBA GEAR
30x12x15 big horns
flowmaster exhaust
cookie cutter cdi
APC headlights
Transmission work
(in reply to bushhog750)
RE: How do you guy's like your dif lock finger trigger ... - 11/28/2008 11:59:43 AM
kristian
So if you get stuck in a hole in 2wd....its okay to switch over to 4wd as long as you ease into the gas until the front diff. fully locks in???
2006 BruteForce 750i
-30x11 Silverbacks
-ITP Black SS108's
-MIMB Snorkles
-UNI Filter
-Custom Exhaust
-Moose Power Module
-Relocated Radiator
-Jetted
-MTX Audiopipe
"Its A BruteForce...Your Either On It or Behind It!!!"
MY PICS: http://community.webshots.com/user/mallardslayer2
Myspace: http://www.myspace.com/mallardslayer2
RE: How do you guy's like your dif lock finger trigger ... - 11/28/2008 12:10:54 PM
bushhog750
yes just flip the switch and ease into the throttle to get it locked up. actually i dont even ease into the throttle i just bump it over until it engages once it engages and the light comes on the lcd display i will bump it a lil more just to make sure it engages on mine you can also feel it engage then i get after it but not until.
(in reply to kristian)
Post #: 22
RE: How do you guy's like your dif lock finger trigger ... - 11/28/2008 3:28:06 PM
ALMOST30S
yeh what he said. ..this will make your diff last alot longer. ..i guess just understanding how it works will too
Team MUD PIMPZ!
SCUBA GEAR
30x12x15 big horns
flowmaster exhaust
cookie cutter cdi
APC headlights
Transmission work
Post #: 23
RE: How do you guy's like your dif lock finger trigger ... - 11/28/2008 4:04:22 PM
speedy81304
better diff control in my eyes, you can conrtol how much your front end locks up, the move pressure means full lock. or you can go limited slip, or full open diff.
if you do get the BF get a penn lock, so you can go full lock with out holding the lever.
2004 KVF700 4x4. Adventure quad. built to go wear i wont to and not look back.
Making mine better then yours is worth the money well spent.
Post #: 24
RE: How do you guy's like your dif lock finger trigger ... - 12/5/2008 12:48:11 PM
mud_dobber
ive found that with the power this v-twin puts out, if u cant make it in regular 4wd... back up, and go past half throttle lol, the v twin makes enough power to basically jump through or over what you trying to do lol.
2008 Brute Force 650i
Thunder Candy Blue
SS212's wrapped with terracross's
Pocket Style Fender Flares
HMF
Quadboss Box
(in reply to speedy81304)
Post #: 25
RE: How do you guy's like your dif lock finger trigger ... - 12/6/2008 6:39:21 PM
ALMOST30S
backing up in mud is a big no no lol. ..well thick stuff it is
Team MUD PIMPZ!
SCUBA GEAR
30x12x15 big horns
flowmaster exhaust
cookie cutter cdi
APC headlights
Transmission work
(in reply to mud_dobber)
Post #: 26
