How To Tighten The Belt....?
All Forums >> [OEM Discussions] >> Kawasaki >> How To Tighten The Belt....? Page: [1] 2 3   next >   >>
How To Tighten The Belt....? - 4/10/2006 11:43:00 AM  1 votes
KAWAma750
whats this i been seeing u tight the belt 22mm or 25mm where do u do that......or how... im gonna install my clutch kit tomorrow and i need help... im gonna install the pink primary and red secondary and k54 weighs...to run 29.5's     ....HELP PLEASE
< Message edited by trapper -- 4/15/2006 5:20:20 PM >
05 bf 750...camo! hmf-pennland slip/on exhaust, dynojet kit, hl lift kit.....k&n filter.. dynatek cdi....29.5's 10 and 12's on climax wheels...cunstom snorkel and temp gauge
RE: how to tight the belt....? - 4/10/2006 11:54:21 AM  3 votes
mudcrazee
I'll copy and paste some info I've typed on this, be patient and I'll help as much as I can.
The belt deflection can be measured by placing a straight edge "ruler" ontop of the belt from the secondary to the primary. Using approx. 13 lbs of pressure with your finger, push down on the belt in the center between the primary and secondary. With another ruler or tape measure, in mm or inches measure how far down the belt goes from the straight edge "ruler" you laid across the top of the primary and secondary. This is your deflection. For the BF, normal deflection is 22mm-27mm or 0.87~1.06in. I have found that 22mm-25mm is the best. If you are around 27mm your gonna want to tighten it. The way the belt is tightened is to remove a determined shim out of the secondary sheave by measuring the shims in the sheave and determining how many mm you need to decrease. (The rule of thumb is: 0.1mm (0.004in.) change in spacer thickness equals about 1.3 mm(0.051in) change in belt deflection.) There are 5 shims availabable with different thicknesses. When Kawi shimmed your quad they put in your secondary what they needed to get your belt in proper deflection. Some people have 2 shims, some have 3. Others can be purchased at your kawi dealer.
What happens when you remove a shim for tightening, the secondary sheaves move closer to the housing while the primary stays the same. This is what tightens your belt.
3 tools you absolutely need are the spring compressor, circlip remover and primary puller. All the rest are usually in a metric tool kit: 10mm socket CVT cover, 19mm socket for primary, 27mm socket for secondary. Flat tip screwdriver to take out the four bushings that hold the secondary together. Broomstick to hold the primary. 1/4 drive or extension hold the secondary pretty good if you can wedge it in the outer sheave and floorboard just right. Brake cleaner to clean out all the belt dust and trash and moly grease for the little bushings and the O rings on the secondary shafts. Oh and a torque wrench so you don't drive the primary back in to far. You can measure the outer sheaves on both in relation to the top of the inside CVT fixed casing if you don't have a torque wrench prior to removing them so when you tighten them back up you get the primary back to the same measurement and whatever you shim the secondary down to should be minus in your new measurement when your done.
To get to the shims, you have to remove the primary clutch and take off the belt. Then remove the secondary and place it into the spring compressor, make a mark on each sheave so when you put it back together they are the same, compress it, remove the circlip and decompress the spring. Pop out the bushing in the center of the sheaves and pull apart. You should then see the shims. If you have a gap tool, you can measure the shims and determine which one to take out to acheive the desired new deflection based on what your starting deflection was.
< Message edited by mudcrazee -- 4/10/2006 12:22:10 PM >
2005 Camo BF 750, SSATV 2" lift, JE Pistons, HL Rack Radiator, 29.5's on ITP 5's, BS, 2" Exhaust Snorkel, Dyna CDI, HL Module, HL Extreme Clutch, HL Diamond Bumper and Bash. BFWDP
2007 EE Rhino660 28" Outlaws on Castlerocks, Stereo system, EBC Brakes.
http://community.webshots.com/user/mudcrazee
http://www.southernswampboyz.com
(in reply to KAWAma750)
RE: how to tight the belt....? - 4/10/2006 7:22:48 PM
neverrideahonda
Yep, Mary hit it on the head. But it is a pain the first time. Use an impact wrench to take of the secondary.
Chad Broadus
www.undergroundatv.com
Home of Team Tipsy aka "The Party Crowd"
If you don't stand behind our military, maybe you should try standing in front of them.
(in reply to mudcrazee)
RE: how to tight the belt....? - 4/10/2006 7:33:01 PM
CamoBrute
that first time it is a little tricky, but after that, there is nothing to it.  Just take your time and pay close attention, and enjoy learning how everything works in there.  Once again, Exceptional write up Mudcrazee
High Lifter Pro Staff Member
05 Camo Brute Force - Motor work by Chapman Performance, 28" Outlaws on Type 6 (for the good stuff), 26" Mud Bugs on Delta series, Dyna CDI, HMF Utility Exhaust, Dyno Jet Kit, Warn 3.0, Snorkle Kit - 2 2" air intake (I said motor work by Chapaman Performance), Garmin eTrex Legend GPS, and a LUNNY attached
2 Honda Rubicons
(in reply to neverrideahonda)
RE: how to tight the belt....? - 4/10/2006 7:36:33 PM  1 votes
mudcrazee
Thanks guys, If I missed something please post it.
(in reply to CamoBrute)
RE: how to tight the belt....? - 4/10/2006 8:24:02 PM
breakinbrute
can you tighten the belt with just the secondary?
06' Outlander 800 w/ 25' Hole Shot ATR'S on SS 108's-4sale/ 26" XTR's on 12" c-7's-4sale..HMF w/ GEN 3 Optimizer and K&N Air...soon 14" ss112's on xtr's
RE: how to tight the belt....? - 4/10/2006 9:52:54 PM
MONSTERQUADMANIAC
Yes that is the only way to tighten it up.
Parting out 3 BF 750's. PM me with any parts you need.
31x9.5's and 112's 4/110
http://www.highlifter.com/forum/m_3135958/mpage_1/key_/tm.htm#3145024
Dynatek CDI BF 750 http://www.highlifter.com/forum/m_3136441/mpage_1/key_/tm.htm#3144377
BF 750 Cylinders http://www.highlifter.com/forum/m_3136444/mpage_1/key_/tm.htm#3144385
2008 Renegade 800 "X" Edition
R.I.P. Justin Danner Price
04/03/81 - 11/17/2008
(in reply to breakinbrute)
RE: how to tight the belt....? - 4/11/2006 9:20:54 AM  2 votes
mudcrazee
ORIGINAL: breakinbrute
If your asking if you only have to remove the secondary, we tried that with the belt on and it wouldn't work without removing the primary. Keep in mind if you choose to roll the belt off like a chain, then your going to stretch it and risk damaging the secondary sheaves and also by stretching the belt your original measurement for deflection will be off some. But like monsterquadmaniac stated, the shims for tightening and also loosening the belt are located in between the secondary sheaves.
RE: how to tight the belt....? - 4/11/2006 4:30:20 PM
neverrideahonda
Do it with someone who has done it before the first time. It isn't hard, but tricky!
Chad Broadus
RE: how to tight the belt....? - 4/11/2006 4:46:45 PM  1 votes
mudcrazee
ORIGINAL: neverrideahonda
RE: how to tight the belt....? - 4/13/2006 4:49:44 PM
mudcrazee
We installed a HL extreme clutch on camoeigers BF750 today. In my webshots, you will find pictures of the job. I included a brief description for each picture. If you have any question, please ask.
RE: how to tight the belt....? - 4/13/2006 5:10:30 PM
superbogger
well mary you continue to impress me!!!!! umm umm umm cant believe i didnt knock some of that knowledge out of you when i hit you in the head with that box haha lol jk girl. but again sorry for that! you have no idea how bad i felt! WOW!!!!!!!! haha glad that oquered 5 minutes over...haha
BIG pink BRUTE(THE ORIGINAL PINK PANTHER)
(sold but not forgottin by any means)
(reserved space for 09 brute)
lookin for a team
RE: how to tight the belt....? - 4/13/2006 5:21:02 PM
mudcrazee
I still have a little knot LOL. My eyelid turned red, black, blue and yellow. Just think, I'll have a scar to remind me of you everytime I look at it. Good thing you don't live closer, I might have to get more insurance LOL, LMFAO.
(in reply to superbogger)
RE: how to tight the belt....? - 4/13/2006 5:38:20 PM
Derag2
I need to tighten my belt, accually need a new one, kinda smoked the old when got some water in there somehow lol..........    It sounds like quite the process to get the belt tightness right......
05 BF750 <----- FOR SALE $5,700
Warn 3.0Ce
Steel skids
27" mudbugs, 12Rear 8fronts ( for now ) sweet tire
12" ITP Type 7 10X better in person than in a pic...
RE: how to tight the belt....? - 4/13/2006 5:40:04 PM
mudcrazee
test
Thumbnail Image
Attachment (1)
RE: how to tight the belt....? - 4/13/2006 5:43:34 PM
mudcrazee
ORIGINAL: Derag2
It's really not that bad. Follow this post, I'm probably going to post the pictures on here step by step.
(in reply to Derag2)
RE: how to tight the belt....? - 4/13/2006 6:08:38 PM
electricstart
This is a great site ,Thanks again
2008 bruteforce 750 Green
2008 bruteforce 750 black
Outlaw mst on itp ss 108
Itp terracross on ss 108 blk.
Ricochet skids
Bison bumpers
Warn 2500 winch
RE: how to tight the belt....? - 4/13/2006 10:04:37 PM
superbogger
mary are you trying to make me feel bad again lol!!!!!
lookin for a team
(in reply to electricstart)
RE: how to tight the belt....? - 4/13/2006 10:13:07 PM
STONEYBFORCE750
Thx mary. Great post mudchic
06 Camo BF 750, 29.5 Laws, ITP Type 7 Black Wheels, 1" Spacers, HL Springs, HL 2" Lift Kit, HL Extreme Clutch Kit, Dynojet Jet Kit, K&N Filter, HL ICM Power Pak, HMF Exhaust, Bayou Snorkel Kit, Exhaust snorkel, Warn 2.5ci Winch, Custom Grille Guard, Audio Formz radio, and usually a few silver bullets within reach.My Pics
RE: how to tight the belt....? - 4/13/2006 11:25:12 PM
camoeiger
thanks for the help today I learned alot now I can do it next time.
GREEN 2005 brute force 750, 29 laws, outlaw clutch kit, snorkled,diamond g rods and ends.
(in reply to STONEYBFORCE750)
RE: how to tight the belt....? - 4/14/2006 8:38:18 AM
mudcrazee
Thanks for all the thanks LOL. I'm pretty sure anyone can do this if they follow the service manual and keep it simple. Pictures I've always found are worth a thousand words.
(in reply to camoeiger)
RE: how to tight the belt....? - 4/14/2006 9:21:29 AM
BRmudder
Thx again mudcrazee and Jack for helping me with my loose belt.  Yep, wish we had taken some more pics while doing it to help these guys/gals out.  Next time!
Steven
His: '07 Outty 800
Gander Mountain - Greenhead (Eric)
Tuned by MAD Motorsports (THE John Cannon)
CATVOS LIFT - ODB (Scott)
Hers: '08 700H1
Philip's Arctic Cat - New Roads
Yard Work: '00 Quadmaster 500
SOUTHERN SWAMP BOYZ
MySpace
MyPics
Post #: 22
RE: how to tight the belt....? - 4/15/2006 11:49:04 AM
mudcrazee
Straight edge across primary and secondary.
Thumbnail Image
Attachment (1)
(in reply to BRmudder)
Post #: 23
RE: how to tight the belt....? - 4/15/2006 11:51:13 AM
mudcrazee
Measuring deflection pushing down with approx. 13 lbs of pressure. Belt deflection for the BF is 22mm-27mm. Anything over 25, I tighten.
Thumbnail Image
Attachment (1)
< Message edited by mudcrazee -- 4/15/2006 1:01:12 PM >
Post #: 24
RE: how to tight the belt....? - 4/15/2006 11:56:49 AM
mudcrazee
Removing primary with Kawis tool turn bolt to the right 19mm socket. You can wedge a broomstick or something similar to do this.
Thumbnail Image
Attachment (1)
< Message edited by mudcrazee -- 4/15/2006 12:06:27 PM >
Post #: 25
RE: how to tight the belt....? - 4/15/2006 12:03:19 PM
mudcrazee
Before you remove the primary and secondary you can take a measurement from the outer primary sheave and secondary sheave in relation to the inside face of the CVT cover so that when you go to reinstall both primary and secondary you have a measurement to tighten back to. This comes in very handy if you don't have a torque wrench as it will prevent you from overtightening. If you remove a shim from the secondary, your new secondary measurement will be minus the shim you took out, but the primary should be the same.
Thumbnail Image
Attachment (1)
Post #: 26
RE: how to tight the belt....? - 4/15/2006 12:05:51 PM
mudcrazee
Primary puller, insert into primary and thread to the right. 19mm
Thumbnail Image
Attachment (1)
Post #: 27
RE: how to tight the belt....? - 4/15/2006 12:06:41 PM
superbogger
umm umm umm mary is the girl!!!! i REALLY think you know watcha talkin about!! haha. i can do this stuff but couldnt put it in words and explain it like you for my life!!!
lookin for a team
Post #: 28
RE: how to tight the belt....? - 4/15/2006 12:08:42 PM
mudcrazee
Thread puller in using a socket until primary pops off. It takes some muscle.
Thumbnail Image
Attachment (1)
Post #: 29
RE: how to tight the belt....? - 4/15/2006 12:12:14 PM
