How-to #4: removing the swingarm locknut from your SRA Honda (with pics)
All Forums >> [OEM Discussions] >> Honda >> How-to #4: removing the swingarm locknut from your SRA Honda (with pics) Page: [1]
How-to #4: removing the swingarm locknut from your SRA ... - 2/2/2008 4:56:39 PM
Dynamo
If you’ve ever removed the swingarm from your straight axle Honda ATV, you’ve seen the locknut on the right side swingarm bolt. This locknut requires a special tool that is not easily obtained and a little on the expensive side. You can make your own tool to allow easy removal/installation of the swingarm locknut. (This does not apply to the Rancher 420 as it uses through-bolts to fasten the swingarm.)
This is the locknut in question.
And here is the special Honda locknut tool.
To make your own locknut removal tool, grab an old 1" impact socket and grind/cut the end to form four equally sized tabs that fit into the locknut’s notches. A bench grinder and rotary tool with cutting disc make this an easy modification. Here is what the modified socket should look like.
Just fit the socket on a ratchet or breaker bar and you can easily remove/reinstall your swingarm’s locknut. I have heard of people using a punch and hammer to remove/reinstall this locknut, but I would advise against this for two reasons. First, the threads can be damaged if the punch slips. Second, the locknut needs to be tightened to a torque of 83 ft/lbs. You will never be able to tighten the locknut to 83 ft/lbs with a punch and hammer and it could back out while riding the ATV, creating a safety hazard. So take a few minutes to fabricate this easy-to-make tool and you’ll save yourself a lot of headaches... and some money.
RE: How-to #4: removing the swingarm locknut from your ... - 2/2/2008 5:16:55 PM
MuddnMason
Yet another fine post Dynamo!
Phillip
High Lifter Moderating Team
(in reply to Dynamo)
RE: How-to #4: removing the swingarm locknut from your ... - 2/2/2008 5:21:27 PM
Flordia__redneck
Hey do you think you could make people some of them and sell them. You got this and the plastic rivit tool. Go and get say 20 cheap sockets and plies make some and sell them for X amount plus shipping. I will buy one as long as the price is right.
GiT-R-DiD
ORIGINAL: M_R_M
somebody must of pee'd in his dew
(in reply to MuddnMason)
RE: How-to #4: removing the swingarm locknut from your ... - 2/3/2008 1:59:57 AM
oldtrx
kinda looks like a bmx bike 4 prong freewheel remover.
http://www.danscomp.com/811033.php?cat=TOOLS
-abunch of stuff i dont need
-http://www.youtube.com/user/oldtrx2
-www.gaorc.com
-www.myspace.com/haro_bikes_91
ORIGINAL: ydopen
ORIGINAL: white
with a passenger my tires rub my fenders will highlifter springs fix the problem or does my wife need to lose weight
(in reply to Flordia__redneck)
RE: How-to #4: removing the swingarm locknut from your ... - 3/10/2008 7:03:50 PM
Jake450s
ORIGINAL: Dynamo
...You can make your own...
You must have a whole rack of cut up sockets by now.    Mine isn't so perdy, but I put a piece on the side like the factory one so I can hold the bolt still while I tighten the lock nut.  It's kind of ugly and nearly worn out, cause I should have made the tabs thicker.  So is the nut from using a worn out socket.  Do you find that the lock nuts don't move much, or that the light torqing isn't so critical?  Just curious, as mine need doing again.
RE: How-to #4: removing the swingarm locknut from your ... - 8/28/2008 6:04:15 PM
oldtrx
does it have to be a socket or can i make this using pipe?
-www.gaorc.com
ORIGINAL: ydopen
ORIGINAL: white
(in reply to Jake450s)
RE: How-to #4: removing the swingarm locknut from your ... - 8/28/2008 6:44:43 PM
backwoodsbigred
I use a similar hom made tool for the clutch on my 200x. Very good and detailed post
(in reply to oldtrx)
RE: How-to #4: removing the swingarm locknut from your ... - 8/28/2008 7:37:07 PM
Jake450s
ORIGINAL: oldtrx
Does it have to be a socket?  Absolutely not.
Why is a socket the easiest answer?  Because of a good quality metal (so the little "tangs" will hold up), and because of the ease of attaching a ratchet to it.
RE: How-to #4: removing the swingarm locknut from your ... - 8/28/2008 10:09:36 PM
ATVtech
ORIGINAL: Jake450s
ORIGINAL: Dynamo
I use the official Honda tool that allows me to hold the swingarm bolt (as yours does).  The reason I made this socket is because someone had stolen my Honda tool and I needed something until I got another one.  I was in too much of a hurry to weld a handle on the side of the socket.  I have found that if the threads on both the swingarm bolt and the locknut are in good shape, holding the swingarm bolt isn't necessary.  Is it better?  Yes.  Is it absolutely necessary?  No.  Just hand tighten the locknut and then torque it down and the swingarm bolt shouldn't move much at all (if the threads are in good condition).
< Message edited by ATVtech -- 8/28/2008 10:11:48 PM >
ATVtech - Baddest Man on High Lifter
RE: How-to #4: removing the swingarm locknut from your ... - 8/29/2008 12:08:35 PM
rick39452
i made a tool to take the swingarm bolts out i just welded to bolts together and took the bolts right off
07 rancher 420 - vision wheels
04 recon 250 2wd - rancher 420 wheels & tires
02 rancher 350 2wd - 25in mudlites (mudslicks)
NEED REAR END FOR 350 RANCHER
WILL TRADE ONE FOR TRUCK
My Pics
(in reply to ATVtech)
RE: How-to #4: removing the swingarm locknut from your ... - 8/29/2008 4:10:36 PM
foreman2000
ORIGINAL: rick39452
YOU DID WHAT???
2000 honda foreman es
custom snorkle
hl lift kit & springs
27 X 10 & 27 X 12 s-backs
hl clutch kit
ebc primary clutches
hmf pipe & uni filter
dynojet 126 and needle
hl spool locker
hl un locker
3000 lb warn
reverse button mod
AND ONE EVIL MONKEY!
*new* 2006 yamaha rhino
upgraded to lcd display
yamaha roof and windsheild
alum stick stops and skids
brp cdi 28 X 10 laws ful
(in reply to rick39452)
RE: How-to #4: removing the swingarm locknut from your ... - 8/29/2008 4:21:00 PM
450ForemanDaniel
What can I use on the other side? Don't have a allen head that big.
03 Foreman 450es
Front-29.5 Swamp Lites
Rear-29.5 Outlaws
itp wheels
2" HL Lift
snorkel (snorkit)
HL spool lock
HMF Utility
HL Lift Springs
14% Gear Reduc.
UNI Filter
Dyno Jet Kit
Viper Max 4000
Strobes and LED's
Reverse Mod
Ammo Boxes
(in reply to foreman2000)
RE: How-to #4: removing the swingarm locknut from your ... - 8/29/2008 4:26:00 PM
toodeep
ORIGINAL: rick39452
this is the alternative to a 17mm allen socket, use a bolt with a 17mm head and weld a nut to it or another bolt and make your own.
95 TRX300FW 01 TRX500FA
My Pics
Mud Performance
