meatman
you should use 1 1/2 pipe, spaflex can be bought at homedepot or lowes and it can be gluded to pvc or abs, you may need to come out of the air box with 2" then reduce it to 1 1/2. as far as vent lines you should have at least 1 or 2 on the rear diff, and the crankcase vent should go to the airbox. make sure you use dielectric grease on all your plugs.
07 honda rincon 680, 3" lift, 27" mud bugs, full skid plates, daul "no cut" snorkels, and then some
