Honda hitch lift
Honda hitch lift
All Forums >> [OEM Discussions] >> Honda >> Honda hitch lift Page: [1]
Honda hitch lift - 11/21/2008 8:28:27 PM
TheBig450ES
How does it work? is it worth it ?
RE: Honda hitch lift - 11/21/2008 8:36:52 PM
Chevync20
No because it may lift your hitch but your hitch isnt your lowest point and also rotating the axle will cause the rear shaft to bend and if you do that gotta split the cases to fix a bent output shaft.
I had an 04 450 and from what I saw I would not get this lift, I looked at it a couple years ago and almost all negative feed back
2007 Yamaha Grizzly Camo 700FI
26" Mudbugs
EHS racing Airbox Lid
EHS racing Cone intake
2500lb Warn Winch
(in reply to TheBig450ES)
RE: Honda hitch lift - 11/21/2008 9:10:53 PM
TheBig450ES
i heard some just bend it up
(in reply to Chevync20)
RE: Honda hitch lift - 11/21/2008 9:27:58 PM
Chevync20
Yea but your rear diff is gonna be lower than the hitch, if your serious about mudding it might look into get an axle paddle?
26" Mudbugs
2500lb Warn Winch
RE: Honda hitch lift - 11/22/2008 4:41:00 PM
Kyle
i just made my own. all you need are sum longer bolts (grade 8 works best) and about 50 flat washers and your good to go. ive found it comes in handy if you frame out, that way your hitch is probably up outa the mud and you dont have to dig out from around it to hook up the strap
2008 Polaris 500 efi
2" HL lift
front rack extender
ammo cans for storage
polaris LE wheels
2004 Honda Foreman 450 *RETIRED*
27" 589's
ITP type 7's
2" HL lift
full HL skid plates
strategicaly placed pvc pipe
3000 lb. superwinch
uni air filter........ 7000 miles and goin strong
