ncmudman
Well, I have a Kodiak 450, and my brother has a foreman 500 2x4. The 500 definatly has more power, simply because of it being a 5-speed. BUT, in a drag race on pavement, I actually take him off the line and hold him all the way through his 4th gear. Mind you we both have HMFs, re-jetted, and aftermarket air filters. Plus his weighs a good bit less than mine. As far as the ride comfort goes, there is no denying the comfort of the IRS Yamaha. In rough, choppy terrain, there is absolutly no comparision. BUT, the 500 fells more planted to the ground, because it's a bit lighter, wider, and the SRA. It can slide a bit easier, and when taking turns at higher speeds, it does not have the body roll of an IRS. However, once you get used to it, you can make an IRS ATV keep up with the SRA. Believe it or not, the wieght balance of the 500 is near perfect, because he can go place that I simply can't in 2x4. To me the Kodiak is too front heavy, meaning that it looses traction to the rear tire way too easy. There are some hillclimbs that I simply can't go up in 2x4, and he goes right up them, fighting to keep the front end down. As long as he doesn't run out of ground clearence, or get into mud, he can keep up. I could go on, but these are my thoughts. I don't have expierience with the Rancher 420, but my dad owns the 350. While it is a fun quad to play aound on, it's not in the the league of these 2, but I hear the 420 is right in the mix of the 450 and 500. Both are excellent ATV's but if I were to do it over again, I'd still go with the Yamaha.
My Vids http://youtube.com/profile_videos?user=NCMudman&p=r http://vids.myspace.com/index.cfm?fuseaction=vids.individual&VideoID=19900752 MINE: 2006 RED KODIAK 450 2.5 Warn RT Winch, Aluminum Products skids & CV Gaurds, HMF, Twin Air air filter, re-jetted, 25" MSTs OTHER ATV'S: 06 Foreman 500 2x4- HMF, UNI, re-jetted, Maxxis All Traks (Brothers) 01 Rancher 350ES 2x4 stock (Dads) Past ATV's AC 250 Honda Recon 87 TRX 125 00 Chevy Z71-Pro Comp Xtreme M/Ts, Dynomax Bullet exhaust
