Has anyone ever broke this
All Forums >> [OEM Discussions] >> Arctic Cat >> Has anyone ever broke this Page: [1]
Has anyone ever broke this - 8/26/2008 11:57:03 AM
squirrel500
Its the upper bracket tabs for the front diff.  BOTH SIDES.............
Thumbnail Image
Attachment (1)
2006 A/C 500m
26" 589s
2" rear lift
That all I will say on line
Hard Pack Arctic Cats
It all seems HardPack when you ride a CAT
2002 Honda recon 22" swampwitch
FMF ext
snorkel K/N
08 366 lime green with 26s 26s too big went back to 24" Why did A/C put 3.1 in the new quads?
THANK YOU STEEL HORSE. YOU KNOW WANT YAL DID. KEEP UP THE GOOD WORK
RE: Has anyone ever broke this - 8/26/2008 12:07:55 PM
squirrel500
another the red lines should be together....................
Attachment (1)
2006 A/C 500m
26" 589s
2" rear lift
FMF ext
snorkel K/N
(in reply to squirrel500)
RE: Has anyone ever broke this - 8/26/2008 12:15:21 PM
mudracer80
Its happened to lots of people.... I've been meaning to brace mine but I always forget when I have it apart.
06 Arctic Cat 665 V-TWIN 11.5:1 CWR450 cams
Swx full exhaust, dynatek
2" lift, ape'ed, lawed
jeted and clutched
Wifes Bike
07 Grizzly 660, 5.5" Ape lift,
clutch kit, custom snorkel,
30" Mudzillas, Rad Relocated
STEEL HORSES
RE: Has anyone ever broke this - 8/26/2008 12:16:47 PM
Cajun Ken
I've seen it on 2 or 3 bikes over the last 5 years or so. Not too common but it has happened. one of the guys told me he thought his was from slamming the front end down after wheelies. Another one is one of my buddies his broke then AC replaced his frame and He Broke it again.
I'd just find a welder and have it braced and re-welded.
Cajun Ken
2008 AC 700 H1
ITP T-4 Rims with 29.5x10 Outlaws
3.6 Gears
MX3500 Viper Winch with Synthetic Rope
Home Made Lift
http://www.myspace.com/kenandnatalie
RE: Has anyone ever broke this - 8/26/2008 12:23:12 PM
squirrel500
I was going to do it myself, but would like to know or see pics of one that was welded and braced up.  I ll call SH today and ask what they do.  I shoulod get a new frame cause I still have warranty but who knows how long that will last...........    I think it was from pulling a friends rhino out of a pond this weekend.  The front was bounsing alittle bit.
< Message edited by squirrel500 -- 8/26/2008 12:25:42 PM >
2006 A/C 500m
26" 589s
2" rear lift
FMF ext
snorkel K/N
(in reply to Cajun Ken)
RE: Has anyone ever broke this - 8/26/2008 1:21:48 PM
8upwithmud
I broke mine and have seen and fixed several others.  I even broke the front mounting tabs for my rear diff.  I just took some 1/4"x 1" bar stock as long as the cross brace on the frame, welded two mounting tabs on it.  Then I cut holes in the cross brace big enough for the tabs to fit through.  Installed the bracket in the cross brace from the front and welded in place.  This allowed me to lower the differential in the frame which helps on CV angle.  Not much, but some.
Thumbnail Image
Attachment (1)
< Message edited by 8upwithmud -- 8/26/2008 1:30:30 PM >
RE: Has anyone ever broke this - 8/26/2008 1:31:29 PM
8upwithmud
Pic 2
Attachment (1)
05 Evil Twin
Bored, stroked, camed, ported, polished,
piped, jetted, snorkeled, clutched, geared,
dynateked, Gorrilla'd, lifted, and lawed.
13 axles
6 motors
6 differentials
1 fan
? belts
04 500M with 28 laws
05 400A with 27 lites
06 Night Rod
http://myspace.com/leebo1973
........................HPAC.........................
.............Hard Pack Arctic Cats.............
(in reply to 8upwithmud)
RE: Has anyone ever broke this - 8/26/2008 1:33:51 PM
8upwithmud
Don't laugh at my welding, it works.
Thumbnail Image
Attachment (1)
05 Evil Twin
13 axles
6 motors
6 differentials
1 fan
? belts
06 Night Rod
RE: Has anyone ever broke this - 8/26/2008 1:37:53 PM
8upwithmud
Last one.
Thumbnail Image
Attachment (1)
05 Evil Twin
13 axles
6 motors
6 differentials
1 fan
? belts
06 Night Rod
RE: Has anyone ever broke this - 8/26/2008 1:45:06 PM
squirrel500
Thanks!  Those will help out alot.  Is that an 06 or older bike? It just looks diffrent then mine.  But will still work for what I need.
< Message edited by squirrel500 -- 8/26/2008 1:47:27 PM >
2006 A/C 500m
26" 589s
2" rear lift
FMF ext
snorkel K/N
RE: Has anyone ever broke this - 8/26/2008 1:49:45 PM
8upwithmud
It's an 05.  Should be the same.  Maybe it looks different because there is no radiator.  I put the same bracket on an 06 and an 04.  The 04 took a little more cutting, but it works the same.
05 Evil Twin
13 axles
6 motors
6 differentials
1 fan
? belts
06 Night Rod
RE: Has anyone ever broke this - 9/25/2008 12:23:24 PM
squirrel500
ORIGINAL: 8upwithmud
Last one.
Thumbnail Image
How long are the tabs that go to the diff?   And should I worry about the angle of the diff?  If its not at the right angle it would put stress on the drive shaft right?
2006 A/C 500m
26" 589s
2" rear lift
FMF ext
snorkel K/N
RE: Has anyone ever broke this - 9/25/2008 3:29:04 PM
8upwithmud
I can't remember how long they are but I wrote all of the measurements down.  I will post when I get home.  Yes the diff must be level in the frame and centered to prevent more stress on one axle or the other.  And like I said earlier, I did lower it in the frame maybe 3/8 of an inch.
05 Evil Twin
13 axles
6 motors
6 differentials
1 fan
? belts
06 Night Rod
RE: Has anyone ever broke this - 9/26/2008 7:41:17 AM
8upwithmud
1 1/4" to the center of the bolt hole.
05 Evil Twin
13 axles
6 motors
6 differentials
1 fan
? belts
06 Night Rod
RE: Has anyone ever broke this - 9/26/2008 8:33:58 AM
squirrel500
Thanks!  Here are some pics of what I did.  I hope it works.
Thumbnail Image
Attachment (1)
2006 A/C 500m
26" 589s
2" rear lift
FMF ext
snorkel K/N
RE: Has anyone ever broke this - 9/26/2008 8:35:52 AM
squirrel500
another
Thumbnail Image
Attachment (1)
2006 A/C 500m
26" 589s
2" rear lift
FMF ext
snorkel K/N
RE: Has anyone ever broke this - 9/26/2008 8:36:54 AM
squirrel500
and  I night of messed up here. I weilded the spacers to the new tabs.  It will make it easer to put back together but will be tight.
Attachment (1)
< Message edited by squirrel500 -- 9/26/2008 8:39:28 AM >
2006 A/C 500m
26" 589s
2" rear lift
FMF ext
snorkel K/N
RE: Has anyone ever broke this - 9/26/2008 8:40:44 AM
squirrel500
top befor paint.  Sorry the pics suck but you get the point.
Thumbnail Image
Attachment (1)
2006 A/C 500m
26" 589s
2" rear lift
FMF ext
snorkel K/N
RE: Has anyone ever broke this - 9/26/2008 12:09:17 PM
8upwithmud
ORIGINAL: squirrel500
Yeah, it might be a little tight.  Good idea though.  I forgot to say, when I welded my ears, I put a really thin washer between the housing the ears to allow some clearance.  Just enough to allow the diff to go in and still pull up tight.
Looks solid now.  You should be done with that.
05 Evil Twin
13 axles
6 motors
6 differentials
1 fan
? belts
06 Night Rod
RE: Has anyone ever broke this - 9/29/2008 7:16:14 AM
XLCat
Happened to me with 28" swamp lites on an 05 500m.  Dealer welded it up under warranty.  What a cop out.  I would have hit him up for a new frame, but I knew he wasn't good for it and the bike was already sold by the time I got it back from the dealer anyways.
2007 700 GRIZZLY---Outlaw MSTs: 26x9.5, 26x12; Warn 3000 w Amsteel, (4) CEC 1" spacers, UNI air filter, 1.25" bar relocation, removed shifter lockout, exhaust tip, 9003 SilverStars, (8) 660 weights
1986 TRX200SX parts donor
1985 ATC70---detailed, open air filter, gutted exhaust, jetted, 200sx throttle housing & cable, stripped everything that doesn't make it go!
RE: Has anyone ever broke this - 9/29/2008 8:37:16 AM
squirrel500
Ive got it all back together sunday. Ill  take some good pics today.  I even got the rad up top now.
2006 A/C 500m
26" 589s
2" rear lift
FMF ext
snorkel K/N
(in reply to XLCat)
RE: Has anyone ever broke this - 9/30/2008 8:38:14 AM
squirrel500
sorry
< Message edited by squirrel500 -- 9/30/2008 8:42:41 AM >
2006 A/C 500m
26" 589s
2" rear lift
FMF ext
snorkel K/N
Post #: 22
RE: Has anyone ever broke this - 9/30/2008 8:44:13 AM
squirrel500
http://pic40.picturetrail.com:80/VOL370/10120287/18209671/336685117.jpg
http://pic40.picturetrail.com:80/VOL370/10120287/18209671/336685116.jpg
http://pic40.picturetrail.com:80/VOL370/10120287/18209671/336685114.jpg
http://pic40.picturetrail.com:80/VOL370/10120287/18209671/336685111.jpg
http://pic40.picturetrail.com:80/VOL370/10120287/18209671/336685109.jpg
2006 A/C 500m
26" 589s
2" rear lift
FMF ext
snorkel K/N
Post #: 23
