H E L P -- B I G -- PROBLEMS
All Forums >> [OEM Discussions] >> Polaris >> H E L P -- B I G -- PROBLEMS Page: [1]
H E L P -- B I G -- PROBLEMS - 11/29/2008 11:01:43 AM
BIG500HO
I rolled my bike a fwe weeks ago ended up with water in the oil and did not change right away now bike wont start even with new oil in it what else should i do the chock cable is froze up also it that makes a diffrence it was working before it went swimming but now not working all this happened in Crosby so any help or davice would be great....
RE: H E L P -- B I G -- PROBLEMS - 11/29/2008 11:30:06 AM
GSSFC
Water in the gas and now water in the carb which has frozen?
Tim
(in reply to BIG500HO)
RE: H E L P -- B I G -- PROBLEMS - 11/29/2008 11:30:08 AM
RidinDirty90
Need a little more info, does it turn over? did you run it after it got wet and now it just wont start or has it not started since the sinking?
first try changing the spark plug if it still wont start it probly has water in the carb, drain the bowl(screw on the side/bottom of carb bowl) and pull the fuel lines loose from the carb and blow them out. Pull the choke cable loose from the carb and try to free it up with some cable lube. You might have water in your gas tank too but probly not, you might change that too. dont forget to check your diffs/tranny oil .
GPC
04' Polaris 600
29's and jams
95'magnum 425
12" custom lift 29's
08 RZR (sold)
05 Polaris 700 (sold)
07 Sportsman 90 10" custom lift (sold)
05 Sportsman 800 8" lift (sold)
02 Sportsman 700 (sold)
RE: H E L P -- B I G -- PROBLEMS - 11/29/2008 12:06:27 PM
Chevync20
Not changing that oil right away can have bad effects, you may has rust in and around the cylinder, you may have bent the rod, could be numerous things need some more info
2007 Yamaha Grizzly Camo 700FI
26" Mudbugs
EHS racing Airbox Lid
EHS racing Cone intake
2500lb Warn Winch
(in reply to RidinDirty90)
RE: H E L P -- B I G -- PROBLEMS - 11/29/2008 12:19:32 PM
RCB2875
I would do all above and also put a small amount of Marvel Mystery Oil in the cylinder through the spark plug hole and let it sit for a while. After a day or at least a few hours turn the motor over a few times to blow out the oil.( spark plug out ) This will hep free the rings if they are stuck but not if they have seized to the piston. Flush, flush, and re flush the entire system. Hope this helps.
(in reply to Chevync20)
RE: H E L P -- B I G -- PROBLEMS - 11/29/2008 12:22:26 PM
RidinDirty90
you can also flush the motor with deisel, that gets it pretty clean.
GPC
04' Polaris 600
29's and jams
95'magnum 425
08 RZR (sold)
(in reply to RCB2875)
RE: H E L P -- B I G -- PROBLEMS - 12/1/2008 9:23:35 PM
BIG500HO
Yes i guess i left out that it did run after that because i drove it back to the trailer then went home and oil was fine but next day was milky. now it will turn over but wont start will change spark plugand drain the bole on the carb and check the gas. thanks for all the input, ridindirty90 were do you get your parts from. The reason i ask is because i live in League City TX off of 45 and 518 their is a dealer by me but teir prices are way out of control.......
