HELP ASAP
HELP ASAP
All Forums >> [OEM Discussions] >> Kawasaki >> HELP ASAP Page: [1]
HELP ASAP - 11/17/2008 1:11:08 PM
Jdizzle
I am diagnosing a problem with my brute, i am 99% sure it fuel related so I took the fuel hose off of the carb and stuck it in a plastic bottle. I cranked the motor over and over and no fuel came out of the line,
when I go to start it shouldent fuel come out of the line? or does the carb create some kinda suction and fuel wont come out untill it is hooked up to the carb?
2007 hunter green Bruteforce 750
Fullskid's
Full Elka's
27' ITP XTR's
Warn 2.5
MIMB snorkel
HL radiator
Mike Walker oil cooler
moose 60' plow
many other little odds&ends
RE: HELP ASAP - 11/17/2008 1:15:32 PM
devildog12210
I am about 99% sure that there is a vacum created by the carbs. Thats why you have to plug the snorkals. Give us a little more info on the problem you are having?
"I think this is the most extraordinary collection of talent and of human knowledge that has ever been gathered together at the White House – with the possible exception of when Thomas Jefferson dined alone." JFK said welcoming fourty nine Nobel Prize winners to the White House in 1962
(in reply to Jdizzle)
RE: HELP ASAP - 11/17/2008 1:33:50 PM
Jdizzle
http://highlifter.com/forum/ATTN%3a_all_carb_experts%2c_please_help/m_3030172/tm.htm
I am 99% sure its a fuel problem, it has gotten worse and worse on starting
devdog should i suck on the hose and crank the motor to  try to test your theary? and yes I am being seriouse.
my buddy is droping of a volt meter to test to see if I am getting power to the pump
Fullskid's
Full Elka's
27' ITP XTR's
Warn 2.5
MIMB snorkel
HL radiator
moose 60' plow
(in reply to devildog12210)
RE: HELP ASAP - 11/17/2008 2:01:10 PM
WoodBoy
under your fender, where your fuel neck enters the tank.. there is a hose with a one way valve that runs into the frame.. its about 3" or 4" long.. check and make sure it is not clogged..
Alex Wood
www.myspace.com/brutus09
06 Brute YELLER
32x10x14 Silverbacks,14"SS106,1.5" Spacers 2" Lift,EPI clutch kit- Pink Prime Red Sec.,Dyna CDI,Center Snorkels,K&N and Outerwears,Climax Wheels,29.5x10x12s,Maxxis 8-Spokes,27" Mudbugs,Strobed Headlights,Spacers
Toyota Tacoma V6
Pro Comp Leveling Kit
33x12.50s on 17" RBP Rims
LOOKING FOR 31" LAWS AND WHEELS!!!
Maxxis 8-Spokes FOR SALE w/ Brute Tires!!
RE: HELP ASAP - 11/17/2008 2:25:38 PM
Jdizzle
ORIGINAL: WoodBoy
I ran that up to the pod but I tryed taking off the gas cap that did nothing. gotta be my pump
Fullskid's
Full Elka's
27' ITP XTR's
Warn 2.5
MIMB snorkel
HL radiator
moose 60' plow
(in reply to WoodBoy)
RE: HELP ASAP - 11/17/2008 4:54:10 PM
Jdizzle
My buddy told me to disconnect the other fuel line on the other end of the pump( the line from the tank into the pump) NOT the line from the pump to the carb. Well.... it looks like there is no line from the tank to the pump it looks like the pump is flush mounted to the tank. He was talking about the  line coming out from underneath the tank from a petcock but this does not seem  to have this??
Fullskid's
Full Elka's
27' ITP XTR's
Warn 2.5
MIMB snorkel
HL radiator
moose 60' plow
RE: HELP ASAP - 11/18/2008 4:17:26 PM
brutus50
you wont get fuel from that line unless it is hooked to carbs and yes there is a vacuum at the carbs. mine had the same prob and was clogged jets inside the carbs. had to take of the carbs and clean the pilot jets twice because of old gas sitting in it. try that before buying a fuel pump
'06 650 brute force with following mods:
HL snorkels
2" lift kit and lift springs
warn winch
jet kit
diamond plate bumper
29.5 OUTLAWS setting on ITP SS108's
wheel spacers, 1.5" rear- 1" front
Kelvar belt w/extreme clutch kit
ALL FROM HL
2007 Honda Rancher 420 (Camo):
27" Outlaw MST's setting on ITP SS108's (black)
2006 Suzuki Eiger 400:
27" Gators
2" HL lift
2007 Kawasaki 90:
for the little guy
