HEADLIGHT SURGING
HEADLIGHT SURGING
All Forums >> [OEM Discussions] >> Polaris >> HEADLIGHT SURGING Page: [1]
HEADLIGHT SURGING - 10/20/2008 8:39:03 PM
monster malibu
The lights on my 99 Polaris Sportsman 500 4x4 surge alot (bright to dim, bright to dim). I was wondering if anybody here had this problem with their bike or knew how to fix this?
RE: HEADLIGHT SURGING - 10/21/2008 7:54:55 AM
Swampthang
Its the surge from your cooling fan coming on.
Sportsman 500 EFI
blown w/ nitrous oxide
12' snorkels
44" super swampers
20" lift
9.9 Mercury outboard
Lowrance depth finder
(in reply to monster malibu)
RE: HEADLIGHT SURGING - 10/21/2008 6:17:38 PM
142fast
you may want to check your circut breaker in the front of the wheeler under the plastic by the radiator
I just changed mine on my 2002 it was rusted out . My lights were blinking.
2005 700 EFI popo
28"Mudlites,and 29.5 laws?
HC,
2" highlifter lift,
800 pri,
Team helix
epi sec spring
1" spacer in front,
1 1/2" in back,
Tunes
2002 500 camo popo
snorkeled intake for belt
27" Mudlites and she also rides my old stock tires from the 700
Check out what I've been up to here
http://4wheelingmn.blogspot.com/
(in reply to Swampthang)
RE: HEADLIGHT SURGING - 10/21/2008 6:31:52 PM
monster malibu
The lights surge whether the bike is cold or warm. Will the circuit breaker on my 99 Sportsman be in the front by the radiator like the 02?
(in reply to 142fast)
RE: HEADLIGHT SURGING - 11/1/2008 5:45:18 PM
monster malibu
I found the circuit breaker for the lights on the 99 Sportsman next to the battery and the connections were clean. The surging light problem was a busted ground wire inside the head light pod making a enough contact to keep the lights still working (barely).
RE: HEADLIGHT SURGING - 11/6/2008 4:25:23 AM
monster malibu
I rode to my deer blind last night and the head lights still surge from time to time. Anybody have any other ideas?
RE: HEADLIGHT SURGING - 11/6/2008 9:21:28 AM
ouch1175
Check all your grounds, battery connections and your stator. Make sure all connections are clean. Bad connections can cause real problems. I would look real hard at the fan. Even when everything else is in good working order the fan can cause enough drain on the system to make your headlight surge.
"That musta hurt"
'06 POPO 500
28" MST's
Some Wheels
The puller outer thing
"custom" flywheel cover
a little bit of lift
lots of scratches...
RE: HEADLIGHT SURGING - 11/6/2008 3:11:13 PM
rzrw30s
I know mine were doing it right before i replaced them with the hids. I just bought a brand new 08 800 stealth and it was doing it the first time i took it out up until the hids. I just thought it was normal. Not sure if the fan was kicking on or not but i do know that the h.i.d.s do not do it.
Team Throwed Offroad
2008 Polaris RzR (Party Bike)
2008 Kawasaki Brute Force 750 (Race Bike)
2008 Polaris 800 Stealth (Deer Camp Bike)
2008 40' Cyclone Toyhauler
2008 Ford F250
(in reply to ouch1175)
RE: HEADLIGHT SURGING - 11/6/2008 7:26:43 PM
monster malibu
Why won't the HID lights surge like the stock lights, don't the HID's require a steady 12volts?
(in reply to rzrw30s)
