Jordan Petry
ORIGINAL: gmcz71 quote:
ORIGINAL: Jordan Petry quote:
ORIGINAL: gmcz71 And also, isnt there a saran Wrap trick Ive heard of for the boot before? Yep, what I did was I wrapped my CV boot in Saran Wrap, then I wrapped it in packing tape. It has held up for well over 1000 miles, no clicking, no leaking grease... It worked excellent. haha thanks, sounds like a solution. this tear is so small rubber cement or some sorta glue will probably fix it. but did those 1000 miles consist of a lot of mud? Nope, mostly gravel, cement or grass... Mostly hardpack trails... Occasionally a stream here or there. Also you could put rubber cement on the hole, wrap it in saran wrap, take a heat gun and shrink the saran wrap, repeat that process, then wrap it in packing tape. Or spend $50 and just replace it. I only did the saran wrap thing because I was in sort of a pinch and didn't want to run my CV dry for several hundred miles... I haven't replaced it yet because it has held up so well!
-1991 Honda 300 - SOLD -1999 Toyota 4Runner 4x4
