Getting trouble codes from your ECU on king
All Forums >> [OEM Discussions] >> Suzuki >> Getting trouble codes from your ECU on king Page: [1] 2   next >   >>
Getting trouble codes from your ECU on king - 3/20/2008 11:49:51 PM
full mod. king quad
Ok guys, i thought this would be a good thread to do on the King so everyone will know how to retreive trouble codes from the ECU.
To begin with, the service manual tells says that you need a $15.00 "mode select switch" (P/N 09930-82720) to go into dealer mode (allows you to get the codes).
This is nothing more than a factory connector that jumps two of the factory terminals to each other, you can do away with having the switch by using a peice of wire, paper clip, bread tie or anything that will fit in the dianostic port on your King.
2001 Yamaha Kodiak
2005 King Quad GREEN
http://www.us-atv.com/
RE: Getting trouble codes from your ECU on king - 3/20/2008 11:52:00 PM
full mod. king quad
Here are some pictures of the mode select switch.
2001 Yamaha Kodiak
(in reply to full mod. king quad)
RE: Getting trouble codes from your ECU on king - 3/20/2008 11:57:43 PM
full mod. king quad
The mode select connector is located under the seat just behind the battery and it will have a black rubber cap on it.
2001 Yamaha Kodiak
RE: Getting trouble codes from your ECU on king - 3/20/2008 11:59:40 PM
full mod. king quad
Heres a look at it with the cap off.
2001 Yamaha Kodiak
RE: Getting trouble codes from your ECU on king - 3/21/2008 12:02:01 AM
full mod. king quad
With the locking clip on the connector on the top, you'll need to jump both of the terminals on the right side of the connector, one is on top of the other.
2001 Yamaha Kodiak
RE: Getting trouble codes from your ECU on king - 3/21/2008 12:03:07 AM
full mod. king quad
I used a bread tie as a jumper in this pic.
2001 Yamaha Kodiak
RE: Getting trouble codes from your ECU on king - 3/21/2008 12:04:17 AM
full mod. king quad
You can see it better in this pic, although its blurred.
2001 Yamaha Kodiak
RE: Getting trouble codes from your ECU on king - 3/21/2008 12:10:55 AM
full mod. king quad
Ok, so you get the idea on the jumper wire, so now you need to look at your pod (with the key in the on position) and look at the bottom of the screen where your hours are normally displayed. You should see this if there are no codes stored on the ECU.
-C 00 is a default code, or all clear code.
< Message edited by full mod. king quad -- 3/21/2008 12:53:59 PM >
2001 Yamaha Kodiak
RE: Getting trouble codes from your ECU on king - 3/21/2008 12:19:54 AM
full mod. king quad
If the "00" is replaced with a number then you may have a malfunction in that particular part.
C 12  Crankshaft position sensor
C 13  Intake air pressure sensor
C 14  Throttle postion sensor
C 15  Engine coolant temperature sensor
C 20  Differential lock relay
C 21  Intake air temperature sensor
C 23  Tip over sensor
C 24  Ignition signal (ignition coil)
C 32  Injector signal
C 40  Idle speed control valve
C 41  Fuel pump control system
2001 Yamaha Kodiak
RE: Getting trouble codes from your ECU on king - 3/21/2008 12:24:31 AM
full mod. king quad
Throttle position sensor: (crank the engine to run this test) The line before the "C 00" is telling you if the TPS is centered or not, for example, if it says this, _C 00, then you need to loosen the screws on the TPS and slightly turn it counter clockwise until the line centers up, it needs t look like this, -C 00.
< Message edited by full mod. king quad -- 3/21/2008 12:54:57 PM >
2001 Yamaha Kodiak
RE: Getting trouble codes from your ECU on king - 3/21/2008 9:44:24 AM
Dugs
I have the VDI Copperhead on my KQ 700 07 and if I want to chek for some codes I have to install the original ecu of my KQ in order to have a reading and I can do it without starting the engine.
King Quad 700 07 oversize 27x11r12, lift kit 2", vdi copperhead, Dalton clutch kit.
RE: Getting trouble codes from your ECU on king - 3/21/2008 10:24:37 AM
full mod. king quad
Thats a good question Dugs, i dont have the VDI so i dont know if it has diagnostic capabilities, but i do know that if you unplug the ECU before you retreive the codes it will erase them until they come back again.
2001 Yamaha Kodiak
(in reply to Dugs)
RE: Getting trouble codes from your ECU on king - 3/21/2008 2:37:20 PM
engie
yeah, you have to put in the stock ECU to run diagnostics...
Currently building 4 race motors and awaiting the class breakdowns to start on the rest!!!
A second place trophy is only useful as a doorstop!
RE: Getting trouble codes from your ECU on king - 3/24/2008 2:37:42 AM
kingkris06
the VDI has  the diagnostics but instead of the COO on the moniter the light on the VDI will blink dot or dash
see your instruction booklet for the table of codes
06 kingquad black,VDI,twin air filter,dalton clutch, 1 in moose lift,M109R, warn bush gaurd 27x9/12x12 swamplite, 28x9/11x12 589mt
02 rubicon lift kit, k and n,28x10/12x12 mudzillas, 27x10/12x12mud bugs, 26x9/12x12 mud lites highlifter disk brakes warn unlocker (sold)
(in reply to engie)
RE: Getting trouble codes from your ECU on king - 4/23/2008 8:34:05 PM
toughgrizz06
where is the throttle positioning sensor located
2005 King Quad 700
29.5 laws
2" highlifter lift
Douglas spyder wheels
Twin Air Filter
(in reply to kingkris06)
RE: Getting trouble codes from your ECU on king - 4/23/2008 8:44:24 PM
full mod. king quad
On the side of the throttle body, it's #5.
2001 Yamaha Kodiak
(in reply to toughgrizz06)
RE: Getting trouble codes from your ECU on king - 4/23/2008 9:12:22 PM
toughgrizz06
It is spring loaded and everytime i turn it it kills the engine
RE: Getting trouble codes from your ECU on king - 4/23/2008 9:14:50 PM
toughgrizz06
also what happens when i get it centered   the line just goes from the top to bottom when i turn it
2005 King Quad 700
29.5 laws
2" highlifter lift
Twin Air Filter
RE: Getting trouble codes from your ECU on king - 4/23/2008 9:32:49 PM
full mod. king quad
ORIGINAL: toughgrizz06
It is spring loaded and everytime i turn it it kills the engine, also, what happens when i get it centered   the line just goes from the top to bottom when i turn it.
You have to turn it slowly, don't loosen the screws all the way, leave them snug then make your adjustment, you don't have to turn it much at all.
Andy
2001 Yamaha Kodiak
RE: Getting trouble codes from your ECU on king - 4/23/2008 10:05:15 PM
toughgrizz06
ok man i figured it out and it feels like i got my bottom end power back.  Didn't know that a little sensor like that could shut down that machine like that.....thanks for the help man, i know alot more about my bike now with everybody's help on here.  Thanks guys you are great.
2005 King Quad 700
29.5 laws
2" highlifter lift
Twin Air Filter
RE: Getting trouble codes from your ECU on king - 5/18/2008 5:06:30 PM
justinemerick
I did the bread tie thing and get the  -00 code, but where my odometer reading is, it still says Err.  I had the battery disconnected for a while, since it was dead, and it has been there ever since.  Any suggestions?
RE: Getting trouble codes from your ECU on king - 5/18/2008 5:10:14 PM
full mod. king quad
Is the red kill swicth located on the left handlebar in the on position?
2001 Yamaha Kodiak
(in reply to justinemerick)
Post #: 22
RE: Getting trouble codes from your ECU on king - 5/18/2008 5:33:53 PM
king_quadder
It says "check" when the kill switch is on. Turn the key off and just disconnect the ecm then plug it back in, mine did the same thing!
HL Forum moderator
Waiting for my next new toy!
Post #: 23
RE: Getting trouble codes from your ECU on king - 5/18/2008 6:39:42 PM
full mod. king quad
ORIGINAL: king_quadder
Oh it's been a while since i got to turn a key on, sorry guys.......
2001 Yamaha Kodiak
(in reply to king_quadder)
Post #: 24
RE: Getting trouble codes from your ECU on king - 5/18/2008 6:44:08 PM
king_quadder
Soon Andy soon, are you getting another king? Or maybe looking at something else.....maybe "yellow"?
HL Forum moderator
Post #: 25
RE: Getting trouble codes from your ECU on king - 5/18/2008 9:07:16 PM
justinemerick
Should I pull that big plug off the ECM?  I always turn the machine off/on with the key, so I assume I'm in the on position.
Post #: 26
RE: Getting trouble codes from your ECU on king - 5/19/2008 7:59:52 AM
linearauto
I am having the problem of my 08 750 not running right. I changed out my exhaust but put my stockpipe back on and the bike still doesn't run good. The bike wont idle right , hard time starting , and seems to back fire at times.  I dont want to by a programmer if not needed. Any help I would greatly appreciate . Do you know any suzuki tech in the Houston area?
Twisted Custom Atv's
Spring , Tx
2008 Brute 750
Full Snorkels
3" lift
Moose Programmer
31" LAWS
Clutch kit
HMF Pipe
2008 Polaris RZR 800
UT theme Bike
6" Catvos Lift
14"SS212's
31"LAWS
Custom Cage
CustomPaint
Ostrich Seats
2008 Kingquad 750
3"inch extreme lift
29.5 LAW'S
Bub's Big Bore Pipe
Full Snorkeled
EPI Clutch Kit
Post #: 27
RE: Getting trouble codes from your ECU on king - 5/19/2008 10:01:14 AM
Solitude
I feel left out here cause my wheeler has never seen a Error Code since day one, but I really wanna try this out haha.
07 Yamaha Yellow Rhino 660 SE - 2" Lift with 27" Zillas on Chrome 112's
06 Suzuki King Quad 700 EFI - 8" SLC Lift with 29.5x10 Outlaws on Black Torks
04 Honda Rubicon 500 GPS
02 Yamaha Grizzly 660 SE - 26" Mudlites on ITP SS 212's
94 Honda 300 - 2" Lift with 27x9.5 Outlaws on Black ITP SS 212's
(in reply to linearauto)
Post #: 28
RE: Getting trouble codes from your ECU on king - 5/19/2008 4:47:02 PM
kq700rider
ORIGINAL: linearauto
U dont have a choice.   If your going to run a aftermarket pipe, you have to buy one of the programmers out there. As far as your other post, you can not reflash the ecm like your wanting.
06 KQ 700 Black, 29.5 Outlaw Tires, VDI, HMF, M109inj, ITP Series 5 rims, 1.5" HL Spacers, HL Clutch/lime green spring,Coop Mod, HL Springs, HL Radiator & Relocation kit, 3"XPATV Lift, Fully Snorkeled, Twin Air, Warn XT25 and a few other things
Pictures & Videos
Post #: 29
RE: Getting trouble codes from your ECU on king - 5/19/2008 11:39:00 PM
kegvinson
need help no err codes,but the exhaust header pipe is turning cherry red.and the bike runs real rough after a few min.
Post #: 30
0.906
