Gas in intake
Gas in intake
All Forums >> [Most Popular Discussions] >> Tech Questions >> Gas in intake Page: [1]
Gas in intake - 8/27/2008 3:15:42 PM
kingtimb1
 Im getting gas in my intake box. 2007 recon. I just put a snorkle on it does anyone know what might cause this?
RE: Gas in intake - 8/27/2008 3:24:08 PM
ChadBIGBEAR
i had seen the same thing on my bear the other day after it was jetted. its a lil harder to start now and i think my flooded out
07 Yamaha Big Bear, 27 Skinny Laws, HMF, Snorkle, K&N, Outerwear PreFilter, DynoJet Kit, HighLifter Clutch Kit
(in reply to kingtimb1)
RE: Gas in intake - 8/27/2008 3:25:43 PM
mud_dog450
2 possibilities:
1.  The float needle inside the carb is stuck in the open position.  This allows the weight of the gas in the tank to push fuel up through the carb into the intake tract, oftentimes resulting in gas filling up the airbox.  To fix this, you need to remove the float bowl and ensure the needle and seat are clean and clear of any debris.
2.  You have transported your Recon in your truck or on a trailer and the air passing by the snorkel drew air from the carburetor into the airbox.  This happens because as air passes the snorkel, it creates a vacuum in the snorkel, airbox, and the entire intake tract.  This vacuum literally pulls air from the engine backwards through the intake, carb, airbox, and finally the snorkel.  As the air flows through the carburetor, it draws gas from the carburetor, carries it, then deposits it into the airbox.
< Message edited by mud_dog450 -- 8/27/2008 3:26:47 PM >
The Mud Brothers
Goin' Deep Since 2004!
02 Grizz
Everything Snorkeled
Clutch Work
29.5 Laws on Vision Buckshots
Muddin Videos
RE: Gas in intake - 8/27/2008 3:27:16 PM
kingtimb1
It seems to happen after going down the interstate in the back of my truck could it be the vacume hose off the carb since i raised it from the wind
(in reply to ChadBIGBEAR)
RE: Gas in intake - 8/27/2008 3:28:45 PM
kingtimb1
Thanks it has to be the snorkle
(in reply to mud_dog450)
RE: Gas in intake - 8/27/2008 3:33:46 PM
mud_dog450
You can purchase a "screw-in" plug for PVC pipes that basically expand as you screw the plug in.
You can see them here.
http://webstore.petersenresources.com/hand.aspx
Or, if your snorkel is big enough, you can plug it with a tennis ball.
The Mud Brothers
02 Grizz
Clutch Work
Muddin Videos
RE: Gas in intake - 8/27/2008 3:35:44 PM
kingtimb1
Thanks
RE: Gas in intake - 8/27/2008 3:56:53 PM
YAMAFORD
a sock works too what ever you use dont forget to pull it out.
Kelvin http://photobucket.com/yamaford
funny vid
MINE
04 660 black
27x10 SB's snorkle, rad relocate, 1 ****, 686, clutch kit
WIFES
660 RHINO CAMO 28INCH VAMPS
DADS
03 660 wetlands camo
snorkle,rad relocate ****s on all 4, 29.5 outlaws on ss112 sra wheels
600 grizzly backu
RE: Gas in intake - 8/27/2008 3:59:21 PM
mud_dog450
The Mud Brothers
02 Grizz
Clutch Work
Muddin Videos
(in reply to YAMAFORD)
RE: Gas in intake - 8/27/2008 7:06:55 PM
Jake450s
Turning the fuel off helps a great deal.  It limits any possible "spillage" to what's in the bowl, which really is a tiny amount considering that the bowl is mostly full of the float and only a little bit full of fuel.  This should be standard practice any time the machine is trailered or carried, regardless of the snorkle.  Also when you park the machine for more than a little while.  Occasional "incidents" are quite normal, and while not expected every day, they do happen due to random chance on a machine that has absolutely nothing wrong with it.  Trouble is, if you don't check for it, you never know, you're driving with dilluted oil, you're trying to figure out why there's two gallons of gasoline spilled on the garage floor.
Capping the snorkle will also help tremendously.  Either the intake or exhaust valve is closed at all times, so if (when) the wind blows across the snorkle and creates a bit of low pressure in there, it sucks the fuel out of the bowl through the jets just like a drinking straw...  Capping the snorkle will prevent that little bit of fuel in the bowl from being pulled out of the jet, but it should not replace turning off the fuel during transport.
RE: Gas in intake - 8/27/2008 7:36:48 PM
bhmudder11
we have to put a rag in my freinds buddies snorkel or after we tow there is about 1-2in if gas in the air box.
TEAM ABS (Always Breaking Stuff)
MONEY WELL WASTED OFFROAD
07 AC 650 H1
BLACK ON BLACK
H.P.A.C.
You Know What It Means
(in reply to Jake450s)
0.469
